Direct Burial vs In-Wall for Outside use. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #31 of 39 Old 07-25-2014, 02:29 PM
Scott Oakley's Avatar
Quoted: 46 Post(s)
Liked: 90
Originally Posted by underminded999 View Post
Currently, I am using two pairs BIC's. One pair for the front porch/Carport, the second pair for the immediate backyard.
I am going to install two new pairs for this project. Two facing North, two facing south.
The wellhouse is 4'x4'. I am going to install them in the four corners, and am debating, if I want to make a 'swivel hinge' or just mount them flat. They come with a mounting bracket that will allow angling, but if I build a swivel hinge, then I would have more flexibility. However, my main goal for this immediate project is getting the wiring out there. I will worry about the specifics of mounting, after that.
The reason I mention that, is that is WHY I am running 8 wires, 2 four gangs.
The BIC's under the carport, are actually a bit too much. I may switch those out for something else, but that is not an immediate project.
To 'CharlesJ'. Is landscape wiring the same as direct burial? I see that it can be buried, but I am not sure if there are any other rules about landscape lighting that I am not aware of.
I appreciate everyone's interest, and thank you for your help.
Okay, I get it. I now understand your concern about the cost of cable. However, the fact remains: there is no substitute for direct burial cable that is the same or less cost that does not have some sort of potential of problems later on. Period, end of story. So, no offense, but you probably need to move on from there.
As to gauge, several of the reviews on Amazon mentioned that the BICs are 6 ohm. Therefore in my personal opinion, if it were me, 14 gauge would be minimum.
Your AVR has plenty of output so that's not an issue. But you will lose some output at your selector switch. Therefore, that with 6 ohm speakers, I'd be looking at 12 gauge, direct burial.
If all of that is still cost prohibitive, consider one speaker facing north, one facing south.
Best I can do for ya man. Keep us posted.
Scott
Panasonic 2013 55VT60
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
Scott Oakley is online now
post #32 of 39 Old 07-26-2014, 04:59 PM
CharlesJ's Avatar
Quoted: 449 Post(s)
Liked: 267
Yes, it is direct burial. And what I used and and have seen is high strand count and copper. And, not that expensive.
CharlesJ is offline
post #33 of 39 Old 07-27-2014, 12:44 PM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 625
One thing we may be losing sight of here is the overall application.
These are patio speakers! Even if there is some minor sound degradation from the long wires, who cares? If you want to do critical listening, an outside patio is hardly the place.
popalock and Skytrooper like this.
Glimmie is offline
post #34 of 39 Old 07-28-2014, 11:09 AM
Quoted: 46 Post(s)
Liked: 90
Right but if you're gonna dig a trench and 16 ga. is 10% cheaper (making that up) than say 12 ga and you know that larger gauge wire is easier on your amp, why the hell not spend the extra 10%? For me, its a piece of mind thing, knowing I did the job right.
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #35 of 39 Old 07-28-2014, 01:31 PM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 125
Going from 16 ga to 12 ga is more than double the price.
http://www.parts-express.com/cat/dir...aker-wire/1623
Belden 100ft of 16 ga is 45.47; 12 ga is 109.98
eta. 100ft of 16ga is about 20bucks, if one just wants to try it out before buying the expensive stuff.
koturban is offline
post #36 of 39 Old 07-28-2014, 02:29 PM
popalock's Avatar
Quoted: 1242 Post(s)
Liked: 1736
Just use that link I provided earlier. Remember the simple rule of thumb that every 3db you drop, you would need to double your power to reach X level. 20awg over 100ft runs would "work" so would 6awg....haha.
Personally, I try to make decisions like these with the thought of future proofing as much as possible...hence my suggestion for a run of CAT6.
Who knows, there might be that "one" time you throw a party and have access to some monster speakers and power. What if you ever feel froggy and want to throw an outdoor sub in the mix down the road?
Scott Oakley likes this.
popalock is offline
post #37 of 39 Old 07-29-2014, 07:16 AM
Quoted: 46 Post(s)
Liked: 90
Have we heard from the OP lately?
And point taken on the price difference, 12 - 16 -thanks. I knew it was more than 10% but I was making a point as stated. I was in HomeDepot this morning and because of this thread, I checked out landscape wire (used for outdoor lighting, direct burial, stranded). A 100 foot roll 12 ga was $58. The difference between it and 16 was $20 and the 16 was appreciably thinner. So for me, the extra $20 or $40 (for 2 rolls) is more than worth it. I hate having to re-do things.
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #38 of 39 Old 07-30-2014, 12:51 PM - Thread Starter
underminded999's Avatar
Quoted: 29 Post(s)
Sorry, I went MIA, on my own thread.
On Sunday, I got into my truck to price out stuff @ Home Depot, and my battery was dead. I tried jumping it, and then charging it, and then took it to Advance Auto, and it was dead, dead, dead. >4 cranking Amps.
I had to buy a new battery and that was about $120.
Anyway, the brake light sensor switch pad broke off. AA's cost was about $10. However, it didn't fit, so I had to go to the dealer. It only cost $7.70 w/tax, and took about 10 min to fix.
Time, energy, and effort...a litle less than $150, which happened to be my 14/4 direct burial speaker wire goal.
Soo, long story short, I have put this project off for a few weeks.
I am leaning heavily towards direct burial, and am beginning to think that I do not need the south facing pair of speakers. However, I only want to dig the trench once, so we'll see.
Thanks for everyone's input, and I will post back, once I begin...
underminded999 is offline
post #39 of 39 Old 08-02-2014, 09:15 AM
J_Palmer_Cass's Avatar
Quoted: 394 Post(s)
Liked: 118
A swimming pool is a much better place to do critical listening. Kind of interesting how things sound when no walls or ceilings are involved.
A boom box is enough for me. No wiring involved!
J_Palmer_Cass is offline
