Pre Wire Question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Roseval
post #1 of 10 Old 07-23-2014, 06:32 AM - Thread Starter
Liked: 0
Pre Wire Question
We are currently building a house and so my plan is to pre wire speakers all over the house and use the Sonos Amp systems. My thought process is to be using Multiple of them so we can control the Vol and different music in each room . Since the Sonos Amp controls the volume .... am I stupid to not wire up Volume controllers in each room? Thanks for any feedback you may have.
CaliberGSD is offline
post #2 of 10 Old 07-23-2014, 09:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
When you put wire in the wall, you don't necessarily have to fully terminate it. Coiling up 6 inches or more in a standard electrical box with a dummy plate at each end suffice.
When you prewire a house don't forget things like PC networking, telephone, and antenna (coax) wiring.
arnyk is offline
post #3 of 10 Old 07-23-2014, 03:25 PM
Roseval's Avatar
Quoted: 37 Post(s)
Liked: 25
As far as I know, Sonos is a wireless system and you control the amps volume wireless.
Makes me wonder what you wish to "wire'
mtn-tech likes this.
Roseval is offline
post #4 of 10 Old 07-23-2014, 06:25 PM - Thread Starter
Liked: 0
Sonos has Connect AMP's that you can use to hardwired speakers
post #5 of 10 Old 07-23-2014, 11:07 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
That is true, but the Connect Amp is intended to wirelessly connect to the Sonos system and power a local pair of speakers - again, there wouldn't be any pre-wiring needed.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #6 of 10 Old 07-23-2014, 11:17 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Would you not need to prewire a bit of A/C in that case?
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #7 of 10 Old 07-26-2014, 07:16 PM - Thread Starter
Liked: 0
How is there no prewire needed? I need to wire the in ceiling speakers? My question was about should I wire in vol controls.
post #8 of 10 Old 07-26-2014, 07:45 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Yes you need to prewire the ceiling speakers.
You could run this through the wall together if you ever wanted a volume buy why complicate when you know what you want on the other end (sonos Amp)
SMHarman is offline
post #9 of 10 Old 08-01-2014, 09:31 PM
Quoted: 311 Post(s)
Liked: 115
Hey, I hear you!
I read your Post correctly.
You're not stupid, in choosing not to add runs of CAT5 for the SONOS System (it's optional), during your prewire of your home. This being said, you will need to run speaker wire from the amplifiers to the various speakers in the house. Take any path that seems the most efficient to you, as long as they all end up at the appropriate amplifiers and you don't run your speaker wire within 6''s of any home AC wiring (NEC requirement).
As previously pointed out, you can send the audio over Wi-Fi to the speakers; however, that would require you to supply sufficient AC drops for your speaker distribution (there is currently no such things as a wireless speaker). I recommend using speaker wire, it's cheaper.
Best of luck.
Garidy is offline
post #10 of 10 Old 08-02-2014, 10:48 AM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
The biggest advantage of Sonos, (and much of its expense) is eliminating the need for in-wall wiring, which is the situation for many who don't want to tear apart walls or fish wires after the fact. The advantage goes away when one has the opportunity to run wiring before the sheetrock is put up.
Have you considered some of the whole home audio equipment, such as Russound, HTD, or Nuvo Technologies? These systems will centralize most of your signal processing and amplification, not to mention eliminating having a Connect to deal with in each room. Your options for controlling the audio will also expand to both wireless and in-wall controllers.
koturban is offline
