layout for a large concrete studio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-24-2014, 11:37 AM - Thread Starter
Liked: 0
Hopefully, this is the right spot for "room design" type posts. I've got a studio space (as in art, not as in sound) that is both fortunately and unfortunately a high-ceilinged concrete box. Roughly 44' L x 22' W x 18' H, with a 14' deep mezzanine. (See pictures.)
Currently, I've got two large-ish cerwin vega 3-way speakers about 12' off the ground on a ledge in front of the main windows (see second photo), and a woefully underpowered Denon receiver.
http://www.hifiengine.com/manual_lib...n/dra-35.shtml
http://www.popsynth.com/cerwins.htm
The sound is pretty terrible. If I EQ the heck out of it, I can get a fairly well defined high-mid range - meaning that vocals are discernible and things don't sound muted, though it is sort of an echoey "big hall" sound that's tiring to listen to after only a couple minutes. But unless you're standing right underneath them, the bass is noticeably "thin", and cranking the volume results in a muddy mess.
I realize that this is to be expected, given the makeup of the room. But given the stipulation that I can't blanket the place in foam / shag carpeting, or rebuild it so it's oblong or whatever, does anyone have tips for how to get a cleaner, more balanced sound? Can I mitigate the drawbacks of the space through speaker selection and placement - maybe by clever location of some subs, and getting coverage for the rest of the range with more numerous, smaller speakers instead of hammering the sound through the space from two big ones?
ID:	178346   Click image for larger version
meeotch is offline
post #2 of 3 Old 07-25-2014, 12:18 PM
Alan P's Avatar
Quoted: 4773 Post(s)
Liked: 3406
Headphones?
Alan P is online now
post #3 of 3 Old 07-25-2014, 05:51 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
MartinLogan Electrostats or other line source speakers
http://www.martinlogan.com/product-list.php
They'll fire down the room with limited horizontal dispersion (less sidewall bounce), they're a line source so the sound level will fall off at -3db at a doulbling of distance vs -6db per doubling for a pointy source, they'll take advantage of the reflective wall (glass) behind the speakers, they won't fire upwards to excite the ceiling, and they look neat too, good for an arty studio environment.
Another interesting property of the electrostat - you can put your ear right up to it when it is playing at high volume - and it isn't "loud" - the sound output is spread over the area of the panel, so there is no "hot spot" like a midrange or tweeter to make you spill your cocktail if you happen to be standing too close to it while pondering the lastest Thomas Kincade.
Electrostats may be a little more directional than cone-type line source speakers.
Unless you want to blast everyone out of your exhibitions, then CerwinVega is (was?) the way to go!
Line vs Point
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
