Anybody use Amazon brand HDMI cables? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By William
post #1 of 20 Old 07-25-2014, 10:33 AM - Thread Starter
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
If yes, how do you like them?
Any problems?
What company makes there cables?
http://www.amazon.com/AmazonBasics-H...ds=hdmi+cables
I'm trying to decide between those and Monoprice HDMI cables.
Don't want to blow a lot of coin on cables, but I also want good quality.
Thanks in advance.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #2 of 20 Old 07-25-2014, 10:44 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I have both amazon and MonoPrice HDMI cables and no complaints with either.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #3 of 20 Old 07-25-2014, 10:45 AM
underminded999's Avatar
Quoted: 29 Post(s)
The general consensus is: HDMI cables either work or don't. They transmit data....0's and 1's.
Sure there are now 2nd and 3rd gen HDMI, bust as long as any signal gets through, it worx.
With that said, if a cable is poorly manufactured, it may fail at the connection end, come unfrayed, et al.
However, I don't think anyone has had any problems with Monoprice's HDMI.
For the record I am using two HDMI cabled from Biglots, that cost $5 each, that I bought about two years ago.
No problems yet...
Now if your device has ARC, or is super new, you may want to go with an HDMI 2 cable, but if it's an older device, the cable should not matter. YMMV.
underminded999 is offline
post #4 of 20 Old 07-25-2014, 02:10 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
For 12ft or less, direct connection from source device to display, just about any cable is ok. If you are using an AVR, or ARC, or longer than 12ft, then at least go for Amazon or even monoprice redmere. I use ALL Amazon with Onkyo AVR to Sony Tv (nothing longer than 12ft), works perfectly fine. Longer runs you may start to see sparklies or colored snow in the picture. Then there's 4K to think about...
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #5 of 20 Old 07-26-2014, 12:57 PM
They_call_me_Roto's Avatar
Quoted: 254 Post(s)
Liked: 180
I use Mediabridge myself, which can be purchased from Amazon or direct through the companies website. Good quality cables that have served me well.
Packing a lot of sound into a small room.
268 square feet/2144 cubic feet
7.2 surround sound.
They_call_me_Roto is offline
post #6 of 20 Old 07-28-2014, 07:40 AM
Glimmie's Avatar
Quoted: 729 Post(s)
Liked: 592
Just installed a 25 foot Amazon house brand this weekend for a Roku on the bedroom tv.
No issues at all.
Glimmie is offline
post #7 of 20 Old 07-28-2014, 10:49 AM - Thread Starter
Quoted: 279 Post(s)
Liked: 105
Thanks for all the reply's!
post #8 of 20 Old 07-29-2014, 02:14 PM
Liked: 0
Hi, I had an amazon basics HDMI cable, and it's bad. Very bad. The cable has only been in my TV and Xbox/PS3 for about 1 month, and if you move it, green flickery lines go across the TV, and you have to have it in the right position all of the time. And tiny little spots flicker all of the time.
EpicFaceisEpic123 is offline
post #9 of 20 Old 07-30-2014, 11:34 AM
Glimmie's Avatar
Quoted: 729 Post(s)
Liked: 592
Well have you tried replacing it? Amazon has a great warranty. You may just have a damaged cable. Or it's possible one of your HDMI jacks is defective or just dirty.
Glimmie is offline
post #10 of 20 Old 08-02-2014, 01:07 AM
wxman's Avatar
Quoted: 3524 Post(s)
Liked: 2545
I have an odd glitch with Redmere cables. My setup is DirecTV>Oppo103D>Samsung F8500>to Onyko via HDMI 3 (ARC) all with Redmere cables. When using a standard HDMI cable from tv via HDMI3 (ARC), and with Anynet CEC turned on, I have no problems and ARC works just fine. I can turn on and off the receiver with tv remote and I get sound. However, when I use a redmere cable the final leg, I can turn receiver off and on with tv remote, but get no sound. I even switch the ends of the cable, and still no sound. I know the cable work fine as I tested it with another device directly to tv. Does the redmere cable require both the video and audio to pass through, and not just the audio?
LG 65EF9500
LG 65E6P
wxman is online now
post #11 of 20 Old 08-02-2014, 01:16 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Why didn't you simply return it? Or is it the hdmi ports on your equipment?
lovinthehd is offline
post #12 of 20 Old 08-02-2014, 07:35 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
Had the sparkles problem with my PS3. Tried many cables til I found one that worked. It is a no name brand with a clear jacket thru which you can see a braided shield. Many say all HDMI cables are the same, but not in my case.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #13 of 20 Old 08-02-2014, 07:53 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
No prob's with Amazon Basics cable here the ends are a little bigger than I prefer in that it *could * stress an HDMI board connection I prefer the thinner type Monoprice N Egg etc or other HDMI cables at Amazon.
I have quite a few inexpensive sometimes less than $1.00 ft no name cables that work fine and do not stress or weight the connectors .
~ $1.00 a ft is all one should need for HDMI cable anything over that for passive HDMI is money in the toilet or useless bling !
tubetwister is offline
post #14 of 20 Old 08-02-2014, 09:30 AM - Thread Starter
Quoted: 279 Post(s)
Liked: 105
Everyone seems to think that Monoprice is the best value, when it comes to connectors.
Sure they pretty much give you the cables, but they nail you with shipping charges.
post #15 of 20 Old 08-02-2014, 01:30 PM
Liked: 622
you know what they say pays to shop around I usually buy from Amazon any way just not necessarily they basics
brand because the ends are 2 big for my preferences other than that no problem with them + I have a prime membership .
post #16 of 20 Old 08-11-2014, 08:15 PM
Goldmember
Quoted: 28 Post(s)
Just chiming in to reiterate what Tubetwister stated about the Amazon cables having a slightly larger end for an ultra snug fit. Makes for a great cable that you're plugging in and leaving alone, but if you regularly plug and unplug you may prefer monoprice.
VeteranAVSMember is offline
post #17 of 20 Old 08-11-2014, 08:19 PM
CinemaAndy's Avatar
Quoted: 700 Post(s)
Liked: 136
I would take the Amazon HDMI cables over Monsters any day of the week. They are very good.
And the payoff is never certain: Some observers contend that a generation has already been trained to be content with the small screen.
Some servers can do non-encrypted playback to an A/V projector, but it's just a ridiculously expensive media player if you don't have a cinema projector.
CinemaAndy is offline
post #18 of 20 Old 08-15-2014, 11:33 PM
krisindahouse's Avatar
I would take audio quest cables any day of the week.
krisindahouse is offline
post #19 of 20 Old 08-16-2014, 01:04 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
why?
67jason is offline
post #20 of 20 Old 08-16-2014, 05:00 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Originally Posted by 67jason View Post
why?
I bet the key word here is take and not buy. I would 'take' them too over my Monoprice cables. I might even be willing to pay one extra buck just for the snob factor.
jake9 likes this.
William is offline
