Home Theater Cable 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-25-2014, 03:43 PM - Thread Starter
barasn's Avatar
Quoted: 35 Post(s)
Home Theater Cable 5.1 speakwe cable important at 5.1 system? what u use all ? can u advise me plz need like 40 feet suuround total and 15 feet front
barasn is offline
post #2 of 5 Old 07-26-2014, 04:01 PM
crn3371's Avatar
Quoted: 257 Post(s)
Liked: 206
Monoprice.
crn3371 is offline
post #3 of 5 Old 07-28-2014, 01:46 PM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
Originally Posted by barasn View Post
Home Theater Cable 5.1 speaker cable important at 5.1 system? what u use all ? can u advise me plz need like 40 feet suuround total and 15 feet front
It isn't going to make enough difference between the cheap home store brand on a roll and high quality wire that you can hear the difference. I would recommend 16 gauge (16AWG) or 14 gauge (14AWG) wire for front and rear. Wire off eBay is hit and miss - sometimes OK and sometimes junk with oxidized copper or cheap sticky plastic insulation. The standard home store brands are fine as is the "zip cord" / lamp wire which is sold by the foot unless you are doing in-wall wires which require special in-wall rated wire:
RCA 100-ft 14 AWG Standard Speaker Wire - about $30
25-ft 16-AWG 2-Conductor White Lamp Cord - about $9 each or by the foot at the store
What I use in my system is Belden 5000 series Cable - the 12AWG would be fine and can be purchased at Blue Jeans Cables by the foot as well as screw on spades, bananas or locking bananas. These can also be welded to the wire if you select the wire lengths and pay a little extra.
Blue Jeans Speaker Cables and Connectors
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #4 of 5 Old 07-28-2014, 01:55 PM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
This is what my Beldon 5000 with welded locking bananas looks like - cheap compared to most "audiophile" speaker wires, look nice and very high quality
Name:	BJC Beldon 5000 Welded.JPG
mtn-tech is offline
post #5 of 5 Old 07-28-2014, 02:43 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Use the forum search function. This same question comes up practically on a daily basis. You probably don't have to go beyond page one to find at least two more threads asking the exact same thing.
Bill Fitzmaurice is offline
