Connecting Laptop through AV? - AVS Forum | Home Theater Discussions And Reviews
Old 07-30-2014, 07:29 PM - Thread Starter
Quoted: 43 Post(s)
Liked: 2
Good Evening Gentlemen,
I was trying to connect my laptop to my AV (Sony STR DN 1050) & am only able to get the video to display. The owners manual is essentially useless but from what I understand I need to connect a separate connection for audio. Ordered an optical cable & single RCA last night while getting the ground loop isolator to stop the hum that comes from the new sub.The only outputs on the AV aside from sub are zone 2, monitor, & a coaxial for the BD that is assignable.
Is there anything else I need?
Prior to the home theater system I plugged the HDMI into the laptop & TV to access all the movies I have saved. It seems with the WiFi that the AV has that I should be able to access the library though have been unsuccessful. Have tried a USB into the AV (only will play music, & in the TV the sound only comes the TV.
Have a PS3 I don't use that I heard I could use as media server, yet have a feeling I may get the same result.
Just seems like there is a simple way of using the laptop or accessing the library and being able to hear it from the surrond speakers without additional cables. Is there a way? If not will the optical cable resolve this?
Been a bit frustrating not being able to watch any movies that are not on cable, would really appreciate any advice
TomFord is offline
Old 07-30-2014, 07:30 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
HDMI should send the sound and video to the AVR and speakers and tv.
SMHarman is offline
Old 07-30-2014, 07:39 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
You need to select the sound output at the PC if you haven't.
Control Panel -> Sound -> Playback Tab
Select the device you want to output audio and click "Set Default"
You may find device selection inside your playback applications, too.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
Old 07-30-2014, 09:26 PM - Thread Starter
Quoted: 43 Post(s)
Liked: 2
I'll try that when we get home. Thanks guys
TomFord is offline
