Is my iPhone 5 ruining my audio experience? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 2 Post By arnyk
  • 1 Post By arnyk
  • 1 Post By arnyk
  • 1 Post By Alan P
Old 08-05-2014, 07:21 PM - Thread Starter
pcbarnard's Avatar
Liked: 1
Question Is my iPhone 5 ruining my audio experience?
Your wisdom, please.
I have my iPhone 5 connected to my Luxman R-115 via an Apple branded A/V cable which ends in a 30-pin (I then have a Lightning adapter on that...) I have a pair original Advent speakers.
I also have a Luxman CD player which is connected via coax cables to the receiver. A significant leap in sound compared to the iPhone.
As a budding audiophile, is it a waste to venture into the world of separates (which I think would be fun) if my primary source of play is typically via iPhone. Is the bridge between the iPhone and the receiver the limiting factor? Is bit rate less important? A whole other topic?
pcbarnard is offline
Old 08-05-2014, 07:45 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The iPhone 5 follows up on the earlier iPhones by having good technical performance when playing music, particularly when driving a good amplifier such as your Luxman. As a stand alone device driving headphones directly it isn't the loudest thing in the world, but it is still OK. But it can sing when connected to a good audio system.
That may be the fault of the music source you are using, such as streaming or low-bitrate MP3 files, but when playing lossless audio files, it compares well with a good separate CD or DVD player.
Bit rate is very important, the most important of the influences you listed. Your cable is OK, and your receiver is OK. You didn't say what your speakers are, but your speakers and your room may be your next bottleneck after the low bitrate streaming and music files.
TomC1315 and pcbarnard like this.
arnyk is offline
Old 08-06-2014, 05:47 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So what is the ideal way to hookup an iPhone 5s to an existing receiver?
Is an iPhone capable of bit streaming the signal or just PCM? Would a cheap, USB DAC, such as the Behringer UCA-202 be a good addition of the signal chain?
Martycool007 is offline
Old 08-06-2014, 06:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The iPhone's headphone jack provides CD-quality analog signals. It seems to have a bit of a bad rep because its output is limited but with an external amplifier that problem is moot.
The Lightning connector accepts a bunch of external adapters.
The Lightning Digital AV adapter provides HDMI for all-digital audio and video which is generally more preferred, but probably sounds pretty much the same.
http://store.apple.com/us/product/MD...D35df%252B2af5
I'm not sure what the Lightning/USB cable supports, but the HDMI output on the adaptor above seems to cover more bases.
TomC1315 likes this.
arnyk is offline
Old 08-06-2014, 10:56 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
^This.
What is the bit rate of the content you are playing from the iPhone??
Alan P is offline
Old 08-07-2014, 08:58 AM
Quoted: 280 Post(s)
Liked: 176
Originally Posted by Alan P View Post
^This.
Can the iPhone 5s, as a source, playback hires music files such as the 24/196 stuff from HDTracks? How can the iPhone 5s be setup to bitstream, or is it not capable of bit streaming?
I would like to try and hook up my iPhone 5s to my Yamaha RX-V663, and try things out!
Question, I have a Behringer UCA-202 that I would like to experiment with as a DAC for my iPhone 5s. How can the 5s and the UCA-202 be connected? I am assuming that my iPhone can be connected via a 3.5mm jack from the mic output on the 5s to USB cable to go between my 5s to my UCA-202 then from the UCA-202 to my receiver via the R+L analog jacks?
Does that seem reasonable?
Old 08-07-2014, 09:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
That's a good question. According to Apple It is possible to attach USB gear to the iPhone 5 using their Lightening to USB cable
You can connect your phone directly to one of your AVR's HDMI inputs via their Lightning to USB/HDMI adapter.
Here is an article about some caveats associated with that kind of use:
http://blog.jdslabs.com/?p=838
Yes, that's a plain analog connection using the converters in the iPhone which are comparable with those in the UCA 202.
You need the Lightning to USB cable for that, and there are possible device and service support issues in the iPhone.
According to their web site the Apple® - Lightning Digital A/V Adapter, and USB cable are available at most BB stores. I suspect that other Apple dealers have them too. There also seem to be some third party compatible devices.
arnyk is offline
Old 08-07-2014, 09:36 AM
Alan P's Avatar
Liked: 3324
http://lmgtfy.com/?q=iPhone+5s+hi+res+music+files
You would use either the headphone out or the dock connector on your iPhone to connect to the Behringer's analog inputs, then the R/L analog jacks or S/PDIF to your AVR. However, I don't think it would provide any benefit over connecting the iPhone directly to the AVR.
Alan P is offline
Old 12-02-2014, 07:43 AM
rerod13's Avatar
I'm also wanting to use my iphone5 source, but as the head unit in my car..
Iv read apples 30 pin to lightning adapter contains a DAC chip and will spoil the SQ .. So that leaves me with the HRT istreamer 12v..
Or are there other USB DAC's I should consider?
rerod13 is offline
Old 12-02-2014, 12:36 PM
zgeneral's Avatar
Quoted: 874 Post(s)
Liked: 213
Sounds like a source problem.
zgeneral is offline
Old 12-02-2014, 03:12 PM
TomC1315's Avatar
Quoted: 134 Post(s)
Liked: 146
Question : are iPod nanos (or any other iPod for that matter) comparable to the iPhones music playing capabilities ... specifically when hooked up to an AVR's USB input via a 30pin to USB cable?
Thank you :-)
MartinLogan Motion 40s / 30 / LX16s
Marantz SR5007 / UD5007
Emotiva XPA-3
SVS SB13ultra
exercise room: MartinLogan LX16s / SVS SB2000
TomC1315 is offline
Old 12-02-2014, 03:18 PM
Alan P's Avatar
Liked: 3324
Yes, with the 30 pin they are no different in audio quality.
Alan P is offline
Old 12-27-2014, 07:59 PM
rerod13's Avatar
Im still shopping for something more economical than the HRT istreamer.. But I don't want to use any adapter other than the lightning cable. Maybe a usb hub
Will any DAC with usb input work? And what about a DAC with male usb needing a usb hub to use the lightning?
rerod13 is offline
Old 01-18-2016, 12:03 PM
solly46's Avatar
Quoted: 22 Post(s)
Applie iphone 5c how to get music to my stereo audio
I own a iPhone 5c and an antiquated Yamaha receiver. (no HDMI ins/outs) Using spotify, how can I output music from my phone to my stereo?
solly46 is offline
bit rate , connection , iphone 5 , separates
