miniDSP OpenDRC-DI - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 44 Old 08-08-2014, 02:31 AM - Thread Starter
RayDunzl's Avatar
Quoted: 1230 Post(s)
Liked: 1430
miniDSP OpenDRC-DI
New toy inserted.
This one:
http://www.minidsp.com/products/open...ies/opendrc-di
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #2 of 44 Old 08-08-2014, 04:56 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Here's a graph of the phase (delay?) by frequency for my system at the sweet spot.
It looks like the lows become progressively late, though from 800hz on up the output is already phase coherent.
This will be the first thing I experiment with, using the tool rePhase.
RayDunzl is offline
post #3 of 44 Old 08-08-2014, 08:14 PM
DonH50's Avatar
Quoted: 2119 Post(s)
Liked: 1688
Ideally the phase would be a linear line, which in turns leads to constant group delay. That means all frequencies are delayed equally, no time distortion.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 44 Old 08-09-2014, 01:17 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
First try at phase correction gives (using the same scale as original above):
Group Delay is decreased, but not so flat, so have to think about that part a little bit more.
RayDunzl is offline
post #5 of 44 Old 08-12-2014, 01:08 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Well, having played for a while, a little surprise.
Most of my investigation so far is with phase correction. To do that the DSP delays or advances frequency bands in time relative to each other, but does not aterially change the frequency response.
So, by doing that, waves are relocated in time, and when summed with the non-relocated waves, produces a clip. The results are a bit unpredictable when trying to guess how much attenuation is enough to prevent clips.
I've had to attenuate the input to the DSP by 9dB to prevent clippage showing up at the input to the Behringer. That may or may not be enough for all source material.
I've thought to use white noise input at 99% full scale, but the no-clip input setting determined with that source was about -3dB.
Unfortunately, the miniDSP hardware does not have a level indication, and the software plugin has what appears to be a very rudimentary level meter.
I'm liking the unit though, overall.
RayDunzl is offline
post #6 of 44 Old 08-13-2014, 11:42 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Weekend Update...
I've brutally twisted the phase into alignment from about 700hz on down.
Increasing torque was applied to the lower frequencies, correcting a maximum of 1477 degrees of retardation at 30hz.
The bottom end is all cleaned up.
Any questions?
Yes, why didn't the Group Delay flatten out more?
Yes, uh, well, the, uh... Are there any other questions?
no.
Post adjourned.
RayDunzl is offline
post #7 of 44 Old 08-16-2014, 09:47 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Effect of time displacement on REW's logarthmic sweep frequency response
Very small to none.
(Yes, I know I have a big suckout in the lows due to the room)
RayDunzl is offline
post #8 of 44 Old 08-16-2014, 09:58 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Group Delay reduction - green trace is with the time filter, red is without
RayDunzl is offline
post #9 of 44 Old 08-16-2014, 12:09 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Since the miniDSP and FIR filter is messing with my signal, let's look at the output of the preamp.
(This measurement includes a 25 foot RCA to 1/8" miniplug from preamp to PC onboard sound device, and any defects caused by them.)
Blue is without the filter, and green is with. Basically no difference in frequency response is seen, results within .1dB or so. (Flat dark blue line is just the measurement cursor)
The FIR filter is changing phase, so here is that measurement at the preamp:
Blue is the preamp output without the filter, green is preamp output with the phase correction filter applied.
And finally, for right now...
Top green is the in-room measurement of phase with the FIR filter, red is the unfiltered room measurement of phase, and the lower green is the phase correction applied at the preamp by the filter (as measured at the preamp out).
This shows how the FIR filter creates* a reasonable inverse to the phase error detected in the room, and applied that to the signal, and corrected the sound in the room.
*rePhase is a manual tool, so the inverse isn't perfect, I have to move a lot of sliders and mess with things a while to have gotten it that close
RayDunzl is offline
post #10 of 44 Old 08-21-2014, 11:35 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
A tip on using rePhase:
At first I used a lot of travel on a lot of sliders to get that major phase/delay out of the low end.
Then experimented on another page of the tool.
Filters Linearization tab, Minimum-phase Filters Phase Linearization
One setting there can twist the big curve in the phase nearly flat.
Then, go to the Paragraphic Phase Eq sliders to clean up, after the major demolition work is done.
RayDunzl is offline
post #11 of 44 Old 08-29-2014, 12:38 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Here are some current measurements.
Red = no DSP
Green = FIR filters applied
1/3 octave smoothing applied
ID:	235529   Click image for larger version
ID:	235537   Click image for larger version
ID:	235545   Click image for larger version
ID:	235553   Click image for larger version
RayDunzl is offline
post #12 of 44 Old 08-29-2014, 02:12 PM
3ll3d00d's Avatar
Quoted: 1650 Post(s)
Liked: 621
what's the ripple in the IR (and SR) before the impulse? a preringing artefact of the filter?
3ll3d00d is offline
post #13 of 44 Old 08-29-2014, 02:41 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
It's the filter, yes.
The FIR filters here are 'acausal'...
There is time-shifting of frequency bands in my filter, to align the time of the peaks.
There is also a time delay - about 50ms in this filter, allowing plenty of time for the filter to grab something that would have occurred later and make it occur sooner.
JJ has looked in on this thread, and asked a few questions in PM, I'm sure he could give us a totally accurate yet incomprehensible reply.
RayDunzl is offline
post #14 of 44 Old 08-29-2014, 02:53 PM
3ll3d00d's Avatar
Liked: 621
do you detect any audible trace of that?
I use FIR filters as well, in my case generated by acourate which has a preringing compensation function. I thought the goal was to have a gently rising phase response at low frequencies as a completely flat phase response is one of the thing that introduces excessive preringing.
3ll3d00d is offline
post #15 of 44 Old 08-29-2014, 05:41 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Audible? Shhhh!!!! Can't talk about what you hear here!
Maybe you have something to teach me, because I don't know. I'm reading things, but it takes a while to soak in.
Post a picture if you have one.
I looked at Dirac (automation) and decided against it, since their implementation locks up the hardware and prevents the use of the Open source tools (and costs another $500)...
And I looked at Acourate but am still having enough fun with rePhase that I haven't looked back at it yet.
Here is the other impulse display, first attachement below.
The filter pre-ringing is reportedly 40-60dB down. That's in the generally accepted hard-to-hear area when other things are going on.
Second attachment, filtered impulse response - 1/3 octave 200Hz range, with pre-ringing on the un-filtered trace that isn't evident in the full-range impulse response. The unfiltered peak there is 18.1ms "late".
ID:	236129   Click image for larger version
Name:	impulse 200 1-3 octave filtered.png
RayDunzl is offline
post #16 of 44 Old 08-29-2014, 06:14 PM
Quoted: 311 Post(s)
Liked: 115
Great thread Ray!
Nice new mug shot as well!
Garidy is offline
post #17 of 44 Old 08-30-2014, 03:53 AM
GeekWave's Avatar
woah! ...cool thread - I don't know what half of it means, but Id like to learn... Subscribing
openELEC HTPC - Emotiva XMC-1 - Emotiva UPA1's - JBL Studio 590's - Dual SVS-PB2000's - JBL ES10's
FYI - I have NO affiliation with the media player 'Geek Wave'
GeekWave is offline
post #18 of 44 Old 08-30-2014, 06:57 AM
3ll3d00d's Avatar
Liked: 621
I think acourate aims to balance a few things with its phase correction; no major discontinuities in the phase response, as similar a response as possible across the 2 channels (summarised by calculating the IACC of the 2 step responses), minimal preringing.
The details, of how these features are implemented, are proprietary though so I don't know how much help I can give you. I just control the strength of its various parameters (excess phase correction, preringing compensation & the window size for its frequency dependent windowing) without knowing exactly what they do. Perhaps that gives you some food for thought though on the parameters you can tweak, for example to see if a different balance of adjustment reduces the ringing further but maintains the quality of the correction.
There is also a good guide on using rephase over on the jriver forum - http://yabb.jriver.com/interact/index.php?topic=87538.0 - which might be worth a read.
3ll3d00d is offline
post #19 of 44 Old 08-30-2014, 09:26 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
What I can't figure out yet is which knobs to twist to predictably affect Group Delay...
Here's an old study.
RayDunzl is offline
post #20 of 44 Old 08-30-2014, 06:08 PM
Quoted: 311 Post(s)
Liked: 115
Ray
Would you say that thus far, that there has or hasn't been a sonic improvement, in your opinion?
Garidy is offline
post #21 of 44 Old 08-30-2014, 08:07 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
There have been measureable changes.
RayDunzl is offline
post #22 of 44 Old 08-30-2014, 08:12 PM
Quoted: 311 Post(s)
Liked: 115
Measurable by human machines or electronic machines?
Garidy is offline
post #23 of 44 Old 09-06-2014, 01:38 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Tonight's activity:
Listening to piano then realizing I could fix the couple of notes that were offending my ear.
So I did.
RayDunzl is offline
post #24 of 44 Old 09-07-2014, 10:45 PM - Thread Starter
RayDunzl's Avatar
Liked: 1430
I have added frequency amplitude EQ to the original phase corrections, in case I didn't mention that.
REW has a automatic filter generator function, tried that. It creates overlapping filters of various Q and amplitude.
So... Not always being one to follow convention, I created a 128 band 1/12th octave equalizer with the DSP.
Every "musical" note from 13.75Hz to 21096Hz has it's own slider.
The filter type is "raised cosine", and with a Q of 18, it appears to be able to adjust any note without molesting its neighbors.
RayDunzl is offline
post #25 of 44 Old 09-10-2014, 09:07 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
1/3 octave frequency response today.
Unequalized, gray, equalized, green
RayDunzl is offline
post #26 of 44 Old 09-10-2014, 09:18 AM
3ll3d00d's Avatar
Liked: 621
does it sound on the bright side?
3ll3d00d is offline
post #27 of 44 Old 09-10-2014, 10:01 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
As in screechy, no.
REW's measurements assume Pink (-3dB/octave going up) is flat.
I think... looking at that now...
RayDunzl is offline
post #28 of 44 Old 09-10-2014, 10:35 AM
3ll3d00d's Avatar
Liked: 621
I am not sure what you mean by it "assumes pink is flat". Can you clarify? (NB: I know what pink noise is just not what you mean in that statement)
3ll3d00d is offline
post #29 of 44 Old 09-10-2014, 10:38 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Using Pink and White noise sources, measured by REW at the preamp, with no EQ
Red is Pink noise - expect downward slope, but it is displayed as flat.
Green is White noise -expect flat slope, but it is displayed as rising.
RayDunzl is offline
post #30 of 44 Old 09-10-2014, 10:54 AM - Thread Starter
RayDunzl's Avatar
Liked: 1430
Here's a different measuring tool, which displays without fudging...
Pink
White
RayDunzl is offline
