AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Audio Theory, Setup, and Chat (http://www.avsforum.com/forum/91-audio-theory-setup-chat/)
-   -   center channel placement help (http://www.avsforum.com/forum/91-audio-theory-setup-chat/1653601-center-channel-placement-help.html)
jspsc123 08-21-2014 09:24 AM
i can either get place my center channel in my tv stand or above the tv. if i place it above the tv i will have to buy a mount. the tv stand slot is 25"x10" with a 2" hole in the back. i dont know if it will sound good in the stand because of the port and airflow. right now i have my receiver and power strip thing in the slot where i would put the center channel so i dont want to move if it and rewire everything if wont give good results
Alan P 08-21-2014 09:58 AM
Is it a rear ported CC? Is the cabinet completely enclosed and will the CC pretty much fill the opening?
If so, I'd recommend on top of the TV.
jspsc123 08-21-2014 11:13 AM
yes and yes. im going with the mount.
Alan P 08-21-2014 11:17 AM
Make sure whatever mount you get will get the face of your CC in front of the face of your TV by at least a half inch or so. Cuts down on reflections.
Oh, and make sure you angle the CC down to point at your head when you're in the MLP.
Skylinestar 08-23-2014 08:46 AM
no matter what, put it above the display.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
