B&W in wall wiring and receiver help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2014, 07:49 PM - Thread Starter
Liked: 0
Hello my name is Josh and this is my first post in this forum, thanks to all who could help me out.
A little backstory: moved into a new house about 6 months ago, just started thinking of hooking up some audio, as I'm growing tired of my computer speakers.
I see that my living room has 4 in-wall speakers, take off the grills and see these:
I did some research and believe they are Bowers & Wilkins Signature 7
Out of the wall next to my Tv there are 8 wires coming out of the wall, 2 thin black, 2 thing red, 2 thick clear/white, and two thik green wires.
The thin wires are wrapped around the thicker wire.
I would like to know if this wiring is ok?
What receiver would I need for this?
Wattage? Impedance?
Thanks again for the help,
Josh
lupob6 is offline
post #2 of 4 Old 08-21-2014, 08:03 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Attachment 223033
Attachment 223041
Attachment 223057
Attachment 223065
Wattage? Impedance?
Nice speakers - too bad they are wallunits, I'd rather put them someplace else.
Speaker Info
The wires will work.
Wire is wire according to the scientists here
(I only barely disagree).
The thin wire is probably the last guy's experiment with biwiring.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #3 of 4 Old 08-23-2014, 03:29 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
You can use a 9V battery to see which wires are connected to which speakers - very quickly touch and remove a pair of black and red wires to the (-) and (+) terminals on the battery - the speaker connected to those wires should make a clicking noise - then label those wires with a piece of tape.
Any AVR (Audio Video Receiver) should be able to drive those speakers - it really depends on what kinds of modern features you want (networking, streaming services, bluetooth, etc) as to which AVR you choose. If you are just going to hook up some standard audio sources (MP3 player, phone, CD player, etc) or a digital source (optical digital audio from TV) just about any modern AVR will do the job. Check out this one:
DENON AVR-E300 5.1 3D Networking Receiver AirPlay - $189 free shipping
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #4 of 4 Old 08-24-2014, 07:03 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
Attachment 223033
Attachment 223041
Attachment 223057
Attachment 223065
Wattage? Impedance?
Josh
The heavy wires are probably the speaker wires. Try two of them at a time until you find the ones that are connected to the speakers.
To verify this use a 1.5 volt C or D cell, NOT a 9 volt battery.
When you connect it to the actual pair of speaker wires, you should see the cone move in or out slightly.
The thin wires may have been for some sort of future "home automation" setup that never was implemented.
commsysman is offline
