Speaker wire with Adapter Jack or Longer Coaxial Audio/Video RCA CL2 Rated Cable - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2014, 03:50 PM - Thread Starter
sndille1's Avatar
Liked: 2
I am in need of advice and hopefully an explanation on the reason so I can be better educated on the Science of Sound. Should I use Speaker Wire cable to Audio Male RCA Connector Adapter Jack Plug or buy longer Coaxial Audio/Video RCA CL2 Rated Cable for my current speaker configuration.
I have an old KLH model 20 with the Model 20 speakers. I know its not high end but its old vintage and looks and sounds great and it was free. If you can give me advice on how to set this up the best possible way please do.
Thank you in advance
ID:	320258   Click image for larger version
ID:	320266   Click image for larger version
ID:	320274   Click image for larger version
ID:	320282   Click image for larger version
sndille1 is offline
Old 10-19-2014, 04:15 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Looks like you're good to me.
Working as Designed.
15w/channel, 4ohm speakers
https://www.etsy.com/listing/1131431...tage-klh-model
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
Old 10-19-2014, 04:22 PM
audio2xs's Avatar
Quoted: 378 Post(s)
Liked: 168
You can do either, whatever is more convenient. I assume you wanted longer wires than what you're using? If not, what you've done is fine.
audio2xs is offline
Old 10-19-2014, 05:20 PM - Thread Starter
sndille1's Avatar
Liked: 2
Yes sorry I did not explain that clearly. Since I have moved my speaker configuration has had to change to get wife approval and I need a longer wire for the right speaker.
Does sound quality differ between rca type wire and traditional speaker wire?
I am certain the speakers need rebuilt just due to age and the capacitors. Luckily they are cloth suspension speakers and not foam so I read they are easier to do for a entry level rebuild.
sndille1 is offline
Old 10-19-2014, 05:22 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
CL2 is a commercial fire rating that deals with toxic smoke emissions from burning cable insulation.
It has nothing to do with electrical properties.
If the cable is loose in a room, then CL2 is not required. If buried inside a wall, local electrical codes take precedent. In some areas residential usage does not require a CLx rating.
In any event for what you are doing CL2 cable is of no benefit. And you may find the CL2 rated cable stiffer and less attractive aesthetically.
Glimmie is offline
Old 10-19-2014, 05:30 PM - Thread Starter
sndille1's Avatar
Liked: 2
What about the sound quality between rca and speaker wire. I have cut ends off of rca scrap wire to recycle in the past and the wire is very tiny compared to speaker wire.
Would wire gauge have any play on my current set up?
sndille1 is offline
Old 10-19-2014, 05:34 PM
audio2xs's Avatar
Quoted: 378 Post(s)
Liked: 168
How long are your wires?
audio2xs is offline
Old 10-19-2014, 05:36 PM - Thread Starter
sndille1's Avatar
Liked: 2
I would be at about 12-15 foot to the right speaker to put it where I need it.
sndille1 is offline
Old 10-20-2014, 07:15 AM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
http://www.roger-russell.com/wire/wire.htm#wiretable
For more: http://www.roger-russell.com/wire/wire.htm
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 10-20-2014, 07:35 AM
audio2xs's Avatar
Quoted: 378 Post(s)
Liked: 168
Should be fine with either.
audio2xs is offline
