Receiver LFE Lowpass setting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2015, 08:01 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Is there a rule on how high to go. Reason i ask, is because the FR was quite rough above 60hz once i settled on a suitable sub location. My mains are capable of a 60hz XO.......
With little EQ the FR is 10hz-60hz.......
I have not adjusted it, its still @120 hz
kgveteran is offline
post #2 of 6 Old 01-28-2015, 09:30 AM
Alan P's Avatar
Quoted: 5083 Post(s)
Liked: 3771
Not quite sure what you are asking....is this the LPF for LFE you are concerned about or is it the crossover?
From your comments, it sounds like you have measured your response (REW?)...can you post up some graphs?
Alan P is offline
post #3 of 6 Old 01-28-2015, 11:07 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Sorry about that... The Lowpass of the LFE. I've read about keeping it at 120hz, which seems high for a subwoofer (LFE) channel.
I will do some measuring and saving of those files this weekend. I use an OmniMic.
post #4 of 6 Old 01-28-2015, 11:14 AM
Alan P's Avatar
Liked: 3771
The LPF for LFE only sets the cutoff for content in the LFE channel. Some movies do have content up to 120hz although they are rare. Some folks like to set it to 80hz. FWIW, I've tried mine at both and found no difference.
The crossovers for your speakers are a whole 'nother thing.
Alan P is offline
post #5 of 6 Old 01-28-2015, 11:32 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
There are some interesting thoughts on LPF for LFE contained in the Audyssey FAQ in this post.
TL;DR: Technically, 120Hz is where it should be set to get all the content at the "correct" level. Real world, several respected authorities have advocated setting it lower anyway. You aren't missing much by applying the filter lower if your subwoofer performance requires it. You might even benefit by cutting out some subjectively less desirable content.
pitviper33 is offline
post #6 of 6 Old 01-28-2015, 11:43 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Yes, i totally agree, the main XO is a different animal. Wondering if everyone sets theirs to the usual 120hz
