CD --> FLAC 44.1khz vs 48khz - AVS | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By RayDunzl
  • 1 Post By Brahmzy
  • 1 Post By audio2xs
  • 1 Post By rcohen
post #1 of 9 Old 02-23-2015, 10:40 AM - Thread Starter
wunderkind's Avatar
Quoted: 23 Post(s)
Liked: 27
Hi I am living the CD world behind and moving to digital storage. So been very busy ripping CD music flac.
I noticed that I am getting crackle and pops when I am using 48khz vs 44.1khz sampling. Am I doing something wrong?
Did some searches, but so far the explanation left my head spinning. Looking for a lay-man explanation.
wunderkind is offline
post #2 of 9 Old 02-23-2015, 10:50 AM
RayDunzl's Avatar
Quoted: 542 Post(s)
Liked: 756
Although resampling shouldn't make objectionable noises, it would seem that whatever you are using to do it is not the optimal solution.
If you are copying CD, copying at the native rate and bit depth - 16/44.1, would be my suggestion and personal preference.
F.Cook likes this.
I'll be back later...
links::: 1.5RQ > digits > 1177a > OpenDRC-DI > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest > Sweetspot
RayDunzl is online now
post #3 of 9 Old 02-25-2015, 06:29 AM
Roseval's Avatar
Quoted: 24 Post(s)
Have a look at dBpoweramp, one of the best rippers there is imho
Roseval is offline
post #4 of 9 Old 02-25-2015, 06:35 AM
Brahmzy's Avatar
Quoted: 211 Post(s)
Liked: 136
Why are you ripping to a higher sample rate than your source? You are unnecessarily creating larger files with zero quality improvement. You're adding "empty space" into your FLAC files for no reason.
F.Cook likes this.
HTPC | 12TB NAS | DENON 2809ci | Sharp 70
Klipsch RF-7II,RC-64II,CDT-5650-CII | SVS SB-2000 x2
Brahmzy is offline
post #5 of 9 Old 02-25-2015, 07:26 AM
audio2xs's Avatar
Quoted: 357 Post(s)
Liked: 153
The best rips are bit-perfect, which means no sample rate conversion, no change in bit depth. As Brahmzy said, there's no quality improvement even if you find away around the clicks. Which, by the way, are not endemic to proper resampling anyway.
F.Cook likes this.
audio2xs is online now
post #6 of 9 Old Yesterday, 08:00 AM
rcohen's Avatar
Quoted: 467 Post(s)
Liked: 155
Resampling from 44.1khz to 48khz could actually cause a significant drop in quality. Definitely keep it at the original 44.1khz rate.
F.Cook likes this.
rcohen is online now
post #7 of 9 Old Yesterday, 01:17 PM
F.Cook's Avatar
Quoted: 143 Post(s)
Liked: 47
I second this suggestion! - Keep it as a 'wave' file...
I've lost my hair, but I haven't lost my mind!
F.Cook is offline
post #8 of 9 Old Yesterday, 01:27 PM
audio2xs's Avatar
Quoted: 357 Post(s)
Liked: 153
Significant, no, but it's not going to improve anything either. Simple resampling results in a 3dB increase in noise, though there are tricks that help that a bit these days. Any change in the original data is technically a degradation, even resampling to 24/192 is a change that doesn't improve anything.
Agreed, keep the original 44.1KHz rate, no need or desire to resample.
F.Cook likes this.
post #9 of 9 Unread Today, 08:49 AM
Michael Sargent's Avatar
Quoted: 81 Post(s)
Liked: 72
FLAC sounds identical to WAV, but uses only about 40% as much space on disk and handles metadata properly.
Mike
Michael Sargent is online now
