I'm going crazy. I have a Marantz 6009. I have it all wired correctly. Direct TV, Amazon Fire TV. I have a Samsung 65" LED. My problem is sometimes if I try to switch to my Fite TV it just flashes off and on and won't " Catch" I have to kill the power to EVERYTHING at the surge protector. For a While, I'd turn on my Marantz and it wouldn't recognize I had Direct TV unless I did the Power thing. I solved that by never turning off my Marantz, I just let it go into sleep mode. I've replace the Fire TV so that's not it....could it be something wrong with my Marantz? Help
All connected via HDMI to the Marantz and a single HDMI going to the TV??
Have you tried different HDMI cables? A "soft" reset on the Marantz (unplug for 10 minutes)? A microprocessor reset on the Marantz (details in your manual)?
By always on do you mean in standby? There are more than one type of standby mode (basic, network, hdmi), which one? What specific order do you turn on your components (source, avr, display)?
I never turn my Marantz off. When I turn off my direct TV, the direct TV remote turns off both the TV and the DTV. When the Marantz has no signal, it goes into sleep. When I turn on my TV it's with the direct TV remote and it turns on both TV and DTV
Sent from my SM-G935V using Tapatalk
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
