Please recommend a "very good" quality (but not crazy-expensive) banana plugs !
I am having difficulty "stuffing" speaker wire into my Denon AVR. Probably about the same situation on most AVR's where they engineer/place the receiving (ports?) so tightly together. It makes a nightmare to jam the speaker wire into that tight a space. Then, (at least on my Denon AVR) there is that receiving "hole" at the 8 o'clock position.
I have always kinda thought "one less connection" by going with raw speaker wire right into the receiver on the back there, but now it seems that a banana plug straight into the receiver is much less of a hassle??
So I am asking what banana plug manufacturer you guys like. I would want a "very good quality" (yea, what does that mean?)...gold plated, I suppose/non-corrosive, at a moderate price (just not any crazy-expensive ones).
I have just about sworn off most "Monster" products...I have had only ONE HDMI failure, and guess what??...yea, it was Monster. I like the speaker wire and HDMI cables from Blue Jean Cable.
Thanks for any advice on the banana plugs !
