My System Is Hurting My Ears - AVS Forum | Home Theater Discussions And Reviews
 16Likes
  • 1 Post By commsysman
  • 2 Post By m. zillch
  • 2 Post By Bigus
  • 2 Post By shivaji
  • 2 Post By Bill Fitzmaurice
  • 1 Post By m. zillch
  • 1 Post By donktard
  • 2 Post By Doe Doe
  • 2 Post By gajCA
post #1 of 26 Old 02-17-2017, 05:18 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 2
When I'm watching a movie or listing to musics on my surround sound my ears start to hurt when there is a lot of bass in the song or the movie. I don't have this problem when I'm in a car with a lot of bass, so I think something is wrong. I hope the photos help if you anyone knows what I can change to fix this, if you need more info just hit me up, thanks.
ID:	1976809   Click image for larger version
ID:	1976817   Click image for larger version
ID:	1976825   Click image for larger version
coolcolorblack is offline
post #2 of 26 Old 02-18-2017, 11:23 AM
commsysman's Avatar
Quoted: 980 Post(s)
Liked: 526
A car may seem to have a lot of bass, but the frequencies are usually not much lower than 40 Hz.
A subwoofer in a house can go lower in frequency, and there may even be subsonic frequencies (you can't "hear" them much, but they affect your ears anyway).
One thing is for sure; you will suffer hearing damage if you don't turn the volume down.
commsysman is online now
post #3 of 26 Old 02-18-2017, 11:29 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 2
even when I have the volume low my ears start to hurt.
post #4 of 26 Old 02-18-2017, 11:38 AM
commsysman's Avatar
Quoted: 980 Post(s)
Liked: 526
If you have a subwoofer, try unplugging its power cord.
If that doesn't fix the problem, maybe there is sort sort of high-frequency distortion that is bothering you.
Gorilla Killa likes this.
post #5 of 26 Old 02-18-2017, 11:56 AM
m. zillch's Avatar
Quoted: 1874 Post(s)
Liked: 1205
I think you should consult a doctor. I would.
bigguyca and ChromeJob like this.
m. zillch is offline
post #6 of 26 Old 02-18-2017, 12:33 PM
gajCA's Avatar
Quoted: 2106 Post(s)
Liked: 1261
What are your main speakers?
The problem may lie there as your sub only plays down to 32hz according to the specs which means it actually doesn't play very low at all.
Try turning OFF the subwoofer and see it the problem continues without the sub in place and the main speakers set to large instead of small, (I assume you have them set to small now).
Geoff A. J., California
gajCA is offline
post #7 of 26 Old 02-18-2017, 12:45 PM
Bigus's Avatar
Quoted: 227 Post(s)
Liked: 252
Given the prodigious cabin gain in vehicles, this is rarely true unless you are speaking specifically about factory systems. I've seen untold single subs in small sealed boxes that would have no useable output below 40Hz in a home environment still have quite reasonable 20Hz output in a car because of this cabin gain.
Bill Fitzmaurice and Madmax67 like this.
Bigus is online now
post #8 of 26 Old 02-18-2017, 01:28 PM
shivaji's Avatar
Quoted: 523 Post(s)
Liked: 386
just to remove the obvious, you are not using your subwoofer as a pillow, are you?
ChromeJob and bimmaguy like this.
shivaji is online now
post #9 of 26 Old 02-18-2017, 02:42 PM
Bill Fitzmaurice's Avatar
Liked: 4696
If it bothers others the same way then it's the system. If it doesn't it's you. Find out which of the two is broken first, then you can go about fixing it.
ChromeJob and Madmax67 like this.
Bill Fitzmaurice is online now
post #10 of 26 Old 02-18-2017, 04:47 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 2
how do you set them to small, I have a TX-NR545?
post #11 of 26 Old 02-18-2017, 04:56 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 2
I turned the sub off and my ears are still hearing, I'm thinking its high pitch sounds that are doing it.
post #12 of 26 Old 02-18-2017, 06:30 PM
jmh547's Avatar
Quoted: 111 Post(s)
Liked: 37
Does the sound cause physical pain or discomfort?
When you say it still hurts at "low volumes" do you have any way to quantify that? When I think of low volume I am in the 60-70 dB range... you low might be significantly higher....
What speakers are you using?
Have you run or tried to rerun auto EQ?
Sent from my SM-G920V using Tapatalk
jmh547 is offline
post #13 of 26 Old 02-18-2017, 06:53 PM
galneon's Avatar
So it isn't the sub. That's not surprising as audible highs tend to bother people more than rumbling lows.
Your receiver may have a global high cut option you could experiment with--it's mostly there for rooms with bright acoustics (hard floors). If not, you can try EQing down the high frequencies for each channel. Do so in a way that the highs gradually drop more and more the higher the frequency.
Either your system is too bright, or you have a medical problem. Whichever problem it is seems severe and should be dealt with.
galneon is online now
post #14 of 26 Old 02-18-2017, 06:55 PM
shivaji's Avatar
Quoted: 523 Post(s)
Liked: 386
Sounds to me like you have been listening at a volume that has slightly damaged your hearing and your ears are now over sensitive to sound. perhaps, it would be a good idea to keep the volume down for a time and give your ears a time to heal.
post #15 of 26 Old Yesterday, 08:50 AM
commsysman's Avatar
Quoted: 980 Post(s)
Liked: 526
There is another possiblity.
You might have a high-frequency oscillation in your system that is near your high-frequency hearing limit.
This can be caused by a poor ground connection on one of your cables due to it not being tight enough on the connector.
This will usually cause one amplifier to run very hot.
Check and see if your amp heat sinks are extremely hot.
post #16 of 26 Old Yesterday, 10:35 AM
gajCA's Avatar
Liked: 1261
Turn of the "loudness management" as that boosts frequencies at low volumes.
Either I'm stupid or the Onkyo EQ is stupid as I don't see anywhere to manage crossovers and speaker size in your manual.
http://filedepot.onkyousa.com/Files/...ADV_En_web.pdf
Page 19 of the Basic Manual walks you through the Quick Setup audio menus so try listening with everything off and or on and adjusting the treble to see if any of those changes help.
Can't find a thing about changing speakers from large to small or manually adjusting crossover points; but maybe that's the way Onkyos work.
If so, yet another reason to get a Denon or Marantz!
gajCA is offline
post #17 of 26 Old Yesterday, 10:47 AM
m. zillch's Avatar
Liked: 1205
"Patients who have a collapsed tolerance to sound need to have their Loudness Discomfort Levels (LDL's) established by a hearing healthcare professional." -
http://www.hyperacusis.net/what-is-i...d-sensitivity/
ChromeJob likes this.
post #18 of 26 Old Yesterday, 10:54 AM
Danonano's Avatar
Quoted: 37 Post(s)
My parents have a fairly small room setup (9'`14') and the subwoofer+speakers in there can really pressurize the room to where it hurts me. The in-room response also boots some frequencies around 60hz so using room compensation helped with that.
You can test your sound pressure levels (spl) with the simple Radio Shack meter. There are tables on the web that show what ranges are harmful.
Danonano is online now
post #19 of 26 Old Yesterday, 01:43 PM
gajCA's Avatar
Liked: 1261
Maybe a picture of your room and how reflective the surfaces are would help, (as would going to a doctor...you could have an infection).
gajCA is offline
post #20 of 26 Old Yesterday, 01:51 PM
ChromeJob's Avatar
Quoted: 635 Post(s)
Liked: 251
[emphasis added]
Okay, I'm with M.zilch. You need to clarify for us if when you say "hurts" you mean it's just not comfortable listening to it, or you are actually experiencing pain/discomfort. If the latter, STOP, go to an audiologist and get tested (not the routine test that just checks for what tones you can hear, but the advanced diagnostic test for pain in the ear drums, hearing loss, or tinnitus).
It could be that the stereo is simply making a symptom more acute, but troubleshooting your stereo is not going to save your hearing.
Seriously, go see an audiologist to diagnose the pain, "do not pass GO, do not collect $200/£200" as they say in the game of Monopoly.
Once you've done that and gotten the results, we'll know what to do next.
Question: in one of your pics, you have bi-amp set YES. Do you actually have two sets of leads going to each main speaker, i.e. Each speaker has two red wires and two ground wires? If the answer is NO, then I think you need to reset your amp to factory defaults (p.21 of your basic manual), and set it up again paying diligent attention to the instructions in the manual. Don't enable any features without first reading the manual and understanding what they are for. I recommend this because you may have the EQ or tone controls set up in a way that is compensating for hearing difficulties, and causing more trouble. Instead of asking you to find all the advanced settings and set them to nominal values, completely resetting the AVR will start from square one.
But that audiologist diagnostic hearing test is the first thing you do. I'd stop listening to the stereo until then as you may be causing more damage. That includes gaming (you posted a few months back about an Xbox), and particularly NO listening with earbuds or headphones as they may hurt your ear drums more.
{edited}
OOH, I get it. P. 31 of Advanced manual (63 of the PDF), you simply set each speaker as "Full band" (aka "large") or set a crossover for each (aka "small" and bass managed). Actually, I like that. Sidesteps the whole "large vs. small" confusion factor for consumers. :}
Hey, folks. A 10-line signature on a post of only 3 lines is a joke. Cut your sigs down to no more than 4 lines, 'kay??
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550.
ChromeJob is online now
post #21 of 26 Old Yesterday, 01:52 PM
Quoted: 645 Post(s)
Liked: 336
His subwoofer is Klipsch. I will deduce his main speakers are Klipsch too, because people love to buy all from one brand. Klipsch speakers sound like train horn. Train horn in a room with nasty reflections sounds like a recipe for suicide.
3 solutions:
1. treat reflections
2. dump speakers
3. do both (1) and (2)
Scotth3886 likes this.
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is online now
post #22 of 26 Old Yesterday, 02:00 PM
Quoted: 330 Post(s)
Liked: 79
I was wondering that too. If what he was describing as 'pain' was really just listener fatigue. Not everyone can use Klipsch speakers without feeling like their ears get tired out.
Lower treble or play with EQ on the receiver would be the first thing I'd try. Or if the OP has other speakers to test, just swap them out and see if the same problem occurs. And of course make sure volume isn't at ear bleed levels.
ChromeJob and Scotth3886 like this.
Doe Doe is offline
post #23 of 26 Old Yesterday, 02:01 PM
gajCA's Avatar
Liked: 1261
Originally Posted by ChromeJob View Post
You saw the manual (PDF) is divided into two books, the second of which is advanced and covers the nifty customization stuff?
FWIW, I can't find speaker size setting either. Pffft. Friggin' Onkyo.
Yeah, I paged through the whole darned thing and dear lord, what a complete lack of customization that AVR seems to offer.
Stunning in this day and age to be honest.
gajCA is offline
post #24 of 26 Old Today, 11:02 AM
m. zillch's Avatar
Liked: 1205
http://filedepot.onkyousa.com/Files/...ADV_En_web.pdf.
In Auto mode the crossover frequency is selected by the results of the mic's room calibration readings. In manual mode the user can set the frequency from 40 to 200Hz. see pg EN-31
Their terminology of "full band" instead of the speakers being "large" is one of the most important advances in AVR design I've seen in years. Not a few, but rather zillions of people have set up their systems incorrectly because their egos refused to allow them to deem their speakers as "small". This should help with that issue.
post #25 of 26 Old Today, 11:25 AM
gajCA's Avatar
Liked: 1261
Completely missed that.
Pretty straight forward.
m. zillch and ChromeJob like this.
gajCA is offline
post #26 of 26 Old Today, 11:43 AM
ChromeJob's Avatar
Quoted: 635 Post(s)
Liked: 251
I later found it and updated my post; zilch also found it as you saw. Took several minutes of searching the PDF in iBooks. :P
@coolcolorblack hasn't returned, so I'm wondering if he only has one set of speaker wires to each left and right speaker, with the AVR set up in bi-amp mode, resulting in an abnormal accentuation of high frequencies, and doesn't realize it? Don't have time right now to look at the manual and speculate on all the ways the system could be mis-configured....
\\ Sent from my mobile device //
