Does Dolby Atmos sound better on a 2 channel system? - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1 of 37 Old Yesterday, 08:05 AM - Thread Starter
kristoffer77's Avatar
Quoted: 36 Post(s)
Liked: 35
I am just wondring if Dolby Atmos sounds better downmixed to 2 channels?
Since the audio space is made in 3D instead of channels I would suspect this might be the case?
kristoffer77 is online now
post #2 of 37 Old Yesterday, 08:13 AM
Quoted: 685 Post(s)
Liked: 357
Is car a car if it has only one wheel?
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is online now
post #3 of 37 Old Yesterday, 08:44 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 35
Uhh no. So you are saying Atmos is on Atmos in 7.1.2? Got it.
post #4 of 37 Old Yesterday, 10:23 AM
Quoted: 685 Post(s)
Liked: 357
Well you cannot get height and surround component from only two speakers.
ChromeJob likes this.
post #5 of 37 Old Yesterday, 10:41 AM
asarose247's Avatar
Quoted: 727 Post(s)
Liked: 487
while you are correct,
my recreational experimentation of switching back and forth between DSU and stereo
using a spl meter to keep the same level at the MLP, and the same sub line-up
the F15's create by themselves a wondefrully clear, tall, wide, deep, phamtom center filled and extended sound field, in my space,
that for some "tunes", the stereo is actually more clear and definitive for smaller details like
the click and reverb fade of wood blocks,
high hats and that short sizzle .
I attribute that to being fortunate to go for the overkill factor in both using the science for speaker placement and a lot (120 ft^2) of room treatments.
not couning 7 of 52" x 96" ceiling to floor medium lined curtains in a slight arc, wall to wall, across the back of my listening space.
and as I know by using REW, I don't hear over about 6.6KHz.
The resources here at AVS can help you get (close to) the results you want . . .
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #6 of 37 Old Yesterday, 10:52 AM
sdurani's Avatar
Quoted: 4587 Post(s)
Liked: 3002
Atmos soundtracks have a nested structure. Inside the Atmos mix is the entire soundtrack as a 7.1 mix. At the core of the 7.1 mix is the entire soundtrack as a 5.1 mix. Inside the 5.1 mix is the entire soundtrack as a 2.0 mix.
So, when you're playing an Atmos movie on a 2-speaker set-up, only the 2.0 core (2-channel downmix) is unpacked. The rest of the Atmos track doesn't need to be decoded.
BTW, the minimum Atmos configuration is 2.0.2 (two front speakers, no sub, two height speakers). If you already have 2 speakers, then adding 2 heights will cause the Atmos track to be fully decoded and rendered to your 2.0.2 layout.
Sanjay
sdurani is online now
post #7 of 37 Old Yesterday, 11:22 AM
Liked: 1
The only time 2 speakers is going to sound better than a 3+ speaker setup is when you have something like binaural audio happening.
Lostandconfused2 is offline
post #8 of 37 Old Yesterday, 11:25 AM
Scotth3886's Avatar
Quoted: 1226 Post(s)
Liked: 645
Height? Sure you can.
Surround? 90 to 100 +/- degrees to the sides, sure.
Scotth3886 is online now
post #9 of 37 Old Yesterday, 11:32 AM
Scotth3886's Avatar
Liked: 645
Not true. Don't need binaural for that to happen.
post #10 of 37 Old Yesterday, 11:33 AM
rontalley's Avatar
Quoted: 708 Post(s)
Liked: 356
You can achieve immersive audio in a 2 speaker system given that you are at MLP and a room that is designed well. However, you can not achieve what Atmos offers in just 2 channels. 5.x.4 will be better than 5.x.2 and 7.x.4 will be WAYYYYYY better than 2.0. Hell, 2.1 is way better than 2.0 when it comes to movies unless you have some pretty hefty front capable of delivering sub bass. There are those who are achieving 9.x.6 and still feel that they can benefit from more speakers.
Once you hear the audio demos and what Atmos is capable of and look back on this question, you will ask yourself, "WTF was I thinking?..."
kristoffer77 and asarose247 like this.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2 Bed), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4 Monitor Series II, Ceilings-Micca M-8C, Sub 1-Klipsch RW12D, Sub 2-MTX SW2
Projector-Optoma HD33 DLP 3D, Screen-Da-Lite 100" Model B, TV-Insignia 65" LCD 1080p (NS-65D550NA15)
rontalley is offline
post #11 of 37 Old Yesterday, 11:46 AM
Liked: 1
Assuming equal quality speakers, setup, recording, room, and conditions, more speakers will always sound better than 2 except when comparing to binaural.
post #12 of 37 Old Yesterday, 11:52 AM
Scotth3886's Avatar
Liked: 645
"7.x.4 will be WAYYYYYY better than 2.0."
Not hardly (done right)
"Once you hear the audio demos and what Atmos is capable of and look back on this question, you will ask yourself, "WTF was I thinking"
I ask "what am I doing here"?
You might well be right with regards to a movie, which I haven't watched an entire movie in over 20 years, but on music, done right, not true. I've heard plenty of it.
I live in a HOA where there are about 120 or so homes and all of them have HT rooms (or music rooms). About 1/5th of the plans have an identical room to what I have here so plenty of opportunity to hear in 'like kind' environments. All are HT system except for me and one other guy with Maggies. For sure, you got us on HT for movies. For music though, not.
post #13 of 37 Old Yesterday, 11:54 AM
Scotth3886's Avatar
Liked: 645
^^^ Well, there you go ^^^
Not
post #14 of 37 Old Yesterday, 12:00 PM
Quoted: 685 Post(s)
Liked: 357
Lets just assume speakers are placed in a "standard" stereo setup, not glued to the ceiling or placed on your sides like headphones.
post #15 of 37 Old Yesterday, 12:05 PM
Scotth3886's Avatar
Liked: 645
My 'standard' is a lil different, I'll grant you that. Well, to be clear, in that mine are not plastered against the front wall.
post #16 of 37 Old Yesterday, 01:22 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 35
Ok, interesting. So my BD player won't downmix but just " know" that it has to play the 2.0 mix?
post #17 of 37 Old Yesterday, 01:48 PM
Alan P's Avatar
Quoted: 4868 Post(s)
Liked: 3493
To be fair, the OP was asking about Atmos. AFAIK, there haven't been any music only Atmos releases as of yet, or am I wrong?
Alan P is online now
post #18 of 37 Old Yesterday, 01:58 PM
Quoted: 685 Post(s)
Liked: 357
Sure, but you still wont be able to decode object oriented atmos track properly, which is the point of this topic.
post #19 of 37 Old Yesterday, 02:03 PM
sdurani's Avatar
Liked: 3002
BD players can't recognize the Atmos portion of the track. The audio in the Atmos track is compressed using Dolby TrueHD lossless packing, so the bitstream ends up with a TrueHD flag. If you're decoding in the player, then it sees the TrueHD flag and unpacks the bitstream like any other TrueHD track. If the player is configured for 2-channel output, then it will unpack only the 2-channel lossless core.
Same thing if decoding happens in your AV receiver. No need to waste DSP resources unpacking the entire Atmos soundtrack, objects and all, only to downmix it back to 2 channels when a 2-channel downmix already exists inside the soundtrack.
Sanjay
post #20 of 37 Old Yesterday, 02:15 PM
Scotth3886's Avatar
Liked: 645
That will never happen in this house from what I've heard around here in the neighborhood. For music I don't need it or want it to start with.
I thought the topic is " Does Dolby Atmos sound better on a 2 channel system"
I was responding to post 7:
"The only time 2 speakers is going to sound better than a 3+ speaker setup is when you have something like binaural audio happening"
post #21 of 37 Old Yesterday, 02:46 PM
rontalley's Avatar
Quoted: 708 Post(s)
Liked: 356
For music, a 2 channel system is the way to go however, there are settings on AVRs like Yamaha's 9ch Stereo that makes a 2 track sounds so so so so so soooooooo dang awesome!!! OMG what an amazing sound in the MLP. Wow!! Hey, this is coming from someone who worked in the Pro Audio industry for 15 years doing nothing but mixing and mastering.
There are some...however, Atmos is generally associated with "Movie" 3d surround sound. And its definitely not a gimmick.
But again some are fine with 2 channel setups and anything other than that sounds strange to them.
Horses for Courses
My Media Room
post #22 of 37 Old Yesterday, 02:51 PM
Alan P's Avatar
Liked: 3493
To each their own, but I have to disagree that "Party Mode" (aka All Ch Stereo, 5/7 Ch Stereo, etc.) is good for anything besides...well...parties.
Now, DPLII Music...that I kinda like sometimes, but I mostly stick to 2.1 for music.
post #23 of 37 Old Yesterday, 02:53 PM
rontalley's Avatar
Quoted: 708 Post(s)
Liked: 356
Me to. I guess you are seeing it as "Does an "Atmos" mix sound better downmixed to 2 channel vs something that was mixed for just 2 channels?"
The answer is that a 2 channel mix is included in the Atmos track. But playing it on a 15.x.8 system will sound better than playing all of the objects that are design to be in a a particular 3D space such as the front of the room where other sounds supposed to be in the back.
Here's an example. There is an Atmos demo where a 747 flys overhead. You can clearly hear the plane coming from the far back then flys over your head and even gives a Doppler effect. There is just no way that this would sound "right" played back on a 2 channel system.
Nope Atmos on 2 Channels would sound cluttered and way too much going on in just 2 speakers. Sorta like a bunch of birds in a cage vs all of the birds flying around and chirping making a peaceful environment vs just a bunch of noise in a close up space.
My Media Room
post #24 of 37 Old Yesterday, 04:35 PM
Scotth3886's Avatar
Liked: 645
"too much going on in just 2 speakers. Sorta like a bunch of birds in a cage "
Doesn't have to be. Takes the right equipment and placement up front to dispense with that cage.
"Here's an example. There is an Atmos demo where a 747 flys overhead. You can clearly hear the plane coming from the far back then flys over your head and even gives a Doppler effect. There is just no way that this would sound "right" played back on a 2 channel system."
And this would be something I would have zero interest in. 747s in my listening room are somewhat unlikely, but I can reproduce the overhead antics in something like Dansk. Yep, for me it's music and music only, and for that, 2 channel (****done right****) is real hard to beat. And this is coming from someone who has been actively at this since 1959 (Quad ESL 57s)
post #25 of 37 Old Yesterday, 06:37 PM
Bigus's Avatar
Quoted: 261 Post(s)
Liked: 271
Two channel vs multichannel is a tired debate and not the subject of this thread. The common misconception I see from the two channel diehards is that they believe by avoiding artificial signal processing and staying more pure to the source they achieve better fidelity. The fallacy is that they aren't even avoiding signal processing.
A room is a signal processor. Some are better designed than others. But no room will ever be as powerful, flexible, intelligent and accurate as a well designed digital signal processor. This has been the case for, oh, two decades or so now.
There's a lot to be said for nostalgia. Bias likes to speak a lot as well.
Bigus is online now
post #26 of 37 Old Yesterday, 06:40 PM
Scotth3886's Avatar
Liked: 645
I was responding to: "The only time 2 speakers is going to sound better than a 3+ speaker setup is when you have something like binaural audio happening" in post 7
"by avoiding artificial signal processing and staying more pure to the source they achieve better fidelity."
Correct
post #27 of 37 Old Yesterday, 07:31 PM
Bigus's Avatar
Quoted: 261 Post(s)
Liked: 271
Well, that belief is a fallacy. Great thing about this hobby is the only person we really have to please is ourselves. Mono speaker with tube amp playing vinyl? Knock yourself out!
Bigus is online now
post #28 of 37 Old Yesterday, 07:40 PM
Scotth3886's Avatar
Liked: 645
Never said that.
Tube amp playing vinyl? Absolutely.
post #29 of 37 Old Yesterday, 08:16 PM
Bigus's Avatar
Quoted: 261 Post(s)
Liked: 271
Wasn't specific to you. Some people may enjoy mono audio.
Bigus is online now
post #30 of 37 Old Yesterday, 08:30 PM
Scotth3886's Avatar
Liked: 645
I don't have much choice with my LPs from 1947 to at least 1958. Some stuff later than that I prefer in mono such as the early Beatles albums, Beach Boys, etc. Some of the early jazz stuff sounded pretty damn good in mono.
