Banana plugs on Amp vs. bare wire - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Bill Fitzmaurice
  • 1 Post By Schuyler Bain
  • 1 Post By Sean Spamilton
post #1 of 15 Old 07-23-2017, 06:15 AM - Thread Starter
Schuyler Bain's Avatar
Quoted: 94 Post(s)
I recently read an article (Sound and Vision?) and the editor mentioned that he NEVER uses banana plugs to connect his amp on his permanent system - only gear that he swaps out often.
I've been using banana plugs for years anywhere possible. Is there some unwritten rule about only using bare wire for amp connections, for a permanent setup?
Schuyler Bain is offline
post #2 of 15 Old 07-23-2017, 06:22 AM
BNestico's Avatar
Quoted: 174 Post(s)
Liked: 231
I use banana plugs only on the AVR ends of my cables just because it's SO much easier to plug/unplug them in the confines behind my entertainment center. I use the bare wire to connect to my speakers. I've heard of people not liking banana plugs because it just adds a connection to the stream the could degrade the sound. That's really all I've heard on the subject.
Panasonic P60U54
Marantz SR-7009
Polk Audio RTi8's, CSi5, RTi6's, OWM3's
SVSound PC12 Plus, PC Ultra (12")
Sony BDP-S7200
BNestico is offline
post #3 of 15 Old 07-23-2017, 07:06 AM
tedhontz's Avatar
Quoted: 270 Post(s)
Liked: 55
I'm really interested in this topic as I was just about to order 20 banana plugs. Hooking up receivers with bare wire is a pain, but if it sounds better I'll do it!
tedhontz is offline
post #4 of 15 Old 07-23-2017, 07:14 AM
Bill Fitzmaurice's Avatar
Liked: 5684
It doesn't sound better, or worse. I've never used plugs. I only swap out connections when I replace a component, so for me they serve no purpose.
Ratman likes this.
Bill Fitzmaurice is offline
post #5 of 15 Old 07-23-2017, 07:15 AM
drh3b's Avatar
Quoted: 431 Post(s)
Liked: 410
I think some people don't believe it makes as good contact as other methods, but I doubt it makes any real world difference. I have both spades, banana plugs, also some bare wire(work in progress), and they all seem to make fine contact to me.
Denon AVR-X4300H
Emotiva XPA Gen3 3 channel
Klipsch RP-280f LR, RP-260f SR, RP-450c, RF-82 II SB, RC-10 height
SVS SB12-NSD x4
OPPO UDP-203 TiVo Roamio, adequate Samsung UHD LED TV
drh3b is offline
post #6 of 15 Old 07-23-2017, 07:41 AM - Thread Starter
Quoted: 94 Post(s)
These media bridge plugs are my favorites.
Newbie789 likes this.
post #7 of 15 Old 07-23-2017, 07:44 AM - Thread Starter
Quoted: 94 Post(s)
I noticed in your equipment list the Emotiva XPA3 gen3. I'm ordering that today for LCR's. Are you happy with that amp? I have have an XPA5 gen 2 for my other channels.
post #8 of 15 Old 07-23-2017, 07:46 AM
drh3b's Avatar
Quoted: 431 Post(s)
Liked: 410
It's been great for me, I play at massive levels sometimes, never gets warm.
Denon AVR-X4300H
SVS SB12-NSD x4
drh3b is offline
post #9 of 15 Old 07-23-2017, 08:50 PM
tedhontz's Avatar
Quoted: 270 Post(s)
Liked: 55
Now this is getting more complicated. I was trying to find out if using banana plug VS bare wire has an advantage or not. Now I just got done looking at the Mediabridge banana plugs and they are very different from the SEWELL banana plugs that I was using. My plugs have two little screws that require a small screwdriver to contact the wire. So now its Mediabridge type VS Sewell type VS bare wire. One thing I remember about using bare wire is that the speaker wire gets oxidized and turns hard and brittle forcing me to occasionally remove the wire from the receiver and cut a new end on the wire to keep the sound quality good. The SEWELL banana plugs seemed to conceal the bare wire from oxidation. I still don't know what to do now.
tedhontz is offline
post #10 of 15 Old 07-23-2017, 09:47 PM
CharlesJ's Avatar
Quoted: 456 Post(s)
Liked: 274
Now this is getting more complicated. I was trying to find out if using banana plug VS bare wire has an advantage or not. ....
Well, yes there is an advantage. Ease of connection and less or no chance of a missed wire strand shorting causing an amp shut down.
Sonically, none.
CharlesJ is offline
post #11 of 15 Old 07-23-2017, 09:50 PM
CharlesJ's Avatar
Quoted: 456 Post(s)
Liked: 274
No, there isn't a written or otherwise rule for using or not using. Sort of dealer's choice. And one is more convenient than the other.
CharlesJ is offline
post #12 of 15 Old 07-23-2017, 10:52 PM
Newbie789's Avatar
Quoted: 302 Post(s)
Liked: 89
The sewell and mediabridge plugs are functionally the same but the mediabridge plugs are much stronger. For every 20 sewell plugs I had one that the head stripped put from the body. The mediabridge plugs are much stronger and where the sewell is a plastic body the mediabridge is some sort of non conductive metal.
Newbie789 is online now
post #13 of 15 Old 07-23-2017, 11:03 PM
Sean Spamilton's Avatar
Quoted: 371 Post(s)
Liked: 431
I've used bare wire for many many years at this point, and haven't felt the need or seen any difference in re-terminating cables personally.
Ratman likes this.
Sean Spamilton is online now
post #14 of 15 Old 07-23-2017, 11:08 PM
tedhontz's Avatar
Quoted: 270 Post(s)
Liked: 55
My Sewell plugs aren't plastic but you've, along with the 5 stars on amazon, convinced me to buy the Mediabridge banana plugs. I have a new receiver on the way (Denon AVR-X4300H) and I just don't like using bare wire so hopefully I'll be happy with the MediaBridge banana plugs. Thanks guys!
tedhontz is offline
post #15 of 15 Old 07-23-2017, 11:10 PM
Newbie789's Avatar
Quoted: 302 Post(s)
Liked: 89
Probably a good call. The sewell deadbolt plugs are plastic. They look like the mediabridge plugs in the pics but they are black instead of silver
