Music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-27-2017, 09:09 AM - Thread Starter
KeithLing's Avatar
Music Playlist setup on oppo udp-203 usb
My Oppo UDP-203 will play music files via the usb drive. One of the options in the interface is playlists. Unfortunately, I did not find anything in the manual regarding the set up or creation of playlists. Searches through the Oppo sites have proven fruitless. Any help here would be greatly appreciated.
KeithLing is offline
post #2 of 10 Old 08-27-2017, 09:10 AM
Quoted: 44 Post(s)
Liked: 5
Originally Posted by KeithLing View Post
pl
Riveting discussion, sir.
BrigadierAngus is offline
post #3 of 10 Old 08-27-2017, 10:48 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Don't you have to setup/create the playlists before copying to the USB drive?
Perhaps the Oppo only "reads" playlists and cannot "create" playlists.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 10 Old 08-27-2017, 11:59 AM
Frank Derks's Avatar
Quoted: 460 Post(s)
Liked: 335
+1
Stereo is simply Multichannel light.
Frank Derks is offline
post #5 of 10 Old 08-27-2017, 12:17 PM
Quoted: 460 Post(s)
Liked: 335
When you highlight a track when browsing the music files you can use the option button on the remote to get a menu where you can add the track to only one playlist (I'm not sure but I think the playlist isn't persistent when the stick is removed). This isn't playlist functionality as available in a music server where you can maintain multiple playlists.
If you have a media library management software you may be able to generate/create cue sheets and use these as playlists.
post #6 of 10 Old 08-27-2017, 01:29 PM - Thread Starter
KeithLing's Avatar
Thanks for your reply. The concept of generating playlist prior to using occurred to me. I probably would have much greater flexibility if I used my in home server and a media library management software. My file system is a pretty basic Windows (10) setup. What software would you recommend?
post #7 of 10 Old 08-27-2017, 01:40 PM
Quoted: 32 Post(s)
Liked: 963
I just copy the files, in my case MP3, to a folder. Then move it to the usb stick. I have to use MP3 since the reader in wife's suv will not work with wav files. And I use Media Monkey for the music servers.
leecreek is offline
post #8 of 10 Old 08-27-2017, 01:56 PM
Ratman's Avatar
Liked: 1191
Have you tried Windows Media Player?
Ratman is offline
post #9 of 10 Old 08-28-2017, 12:59 AM
Quoted: 460 Post(s)
Liked: 335
I'm using foobar2000 to maintain my music library on a synology nas. It has decent music server functionality and can be accessed through a browser or iPad App. I think the playlist maintained on a music server can be accessed by the Oppo through the option menu.
I know foobar can generate cue sheets but I never used it in practice as I never use playlist or cuesheets myself.
I'm mostly playing entire albums and use the Oppo file interface as this is the only option for gapless playback and seamless multichannel support.
My 105D is setup with both access to the nas but the entire music library is copied to an attached usb diskdrive. It is the only option on the 105 for gapless playback and the disc also doubles up as a backup.
Recently I added the UDP203 to my system and noticed that gapless now seems to work with file access over the network as well but I need to verify this if this is truly the case or that te gap is reduced and less noticeable.
post #10 of 10 Old 08-28-2017, 01:20 PM
Airsculpture's Avatar
Location: English but in Fredericton, New Brunswick, Canada
Quoted: 176 Post(s)
Liked: 284
Music
I have found the 203 can create playlists but not found a way to read existing ones. I tried to create one and then look to see what file format they were stored in, but they must be stored internally because it didn't appear on my plugged in USB drive.
Would be interested if anyone has any luck in this area as I have a ton of playlists created from iTunes and they weren't recognized when I exported them and added them to the external USB drive, either .msu or .xml
H/T Set up:
Oppo UDP-203
FrontL&R - Polk TSx550t, Centre - Polk CSiA6 all in Cherry
Surrounds - Mission 77DS & Mission 780s
Subwoofer - Polk PSW125 in Cherry
Receiver - Pioneer VSX-9140THX
Airsculpture is offline
