popping sound after Win 10 update - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ratman
post #1 of 5 Old 09-13-2017, 12:35 PM - Thread Starter
luthierwnc's Avatar
Quoted: 13 Post(s)
F$@&^*g Microsoft!
I got a periodic update and when it was done, my sound system has a nasty popping sound. I use a little USB DAC from the computer into RCAs that go into the back of the receiver. It worked fine this morning. Now it doesn't. It happens both through the receiver and on the headphones leaving the front of the DAC.
Any ideas would surely help, thanks, sh
luthierwnc is offline
post #2 of 5 Old 09-13-2017, 01:25 PM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1179
Restore your 'puter to a previous date (before the latest update). If the problematic symptoms cease... contact Microsoft.
Madmax67 likes this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 5 Old 09-13-2017, 02:12 PM - Thread Starter
luthierwnc's Avatar
Quoted: 13 Post(s)
Thanks Ratman -- that was it. I keep waiting for the day when, like Scotty, I can say, "Computer, diagnostic". sh
post #4 of 5 Old 09-13-2017, 02:29 PM
CharlesJ's Avatar
Quoted: 456 Post(s)
Liked: 274
Just curious. Did this also manifest when you played through your computer monitor speakers or just your receiver. I have no problems as of today with monitor speakers with the latest update a day or so ago.
CharlesJ is offline
post #5 of 5 Old 09-14-2017, 04:47 AM - Thread Starter
luthierwnc's Avatar
Quoted: 13 Post(s)
I didn't try the computer stereo 3.5mm out -- just the USB 2.0. The popping sounded like a bad physical connection but it was fine that morning and it was fine after I uninstalled the updates. It still leaves me the problem of being left behind with future updates or even what would have caused it. I checked the sound system on the control panel and it was fine -- although I was getting no sound until I opened it and double-checked the settings. I noticed the popping after I got that far. Good luck with your gear, sh
