Does equal speaker length matter? - AVS Forum | Home Theater Discussions And Reviews
 16Likes
  • 1 Post By gmanhdtv
  • 1 Post By Scotth3886
  • 1 Post By Speedskater
  • 1 Post By donktard
  • 3 Post By BassThatHz
  • 3 Post By GIEGAR
  • 2 Post By MattB101
  • 1 Post By holl_ands
  • 3 Post By m. zillch
post #1 of 21 Old 09-21-2017, 03:29 PM - Thread Starter
Quoted: 91 Post(s)
Does equal speaker length matter? More importantly has anyone tested this?
I need about 8 ft for the left speaker and 12 foot for the right speaker.
I understand at the speed of light my ears won't hear the delay.
There is some talk about impedance and ohms... But does it matter even to an audiophile that has gone through his own blind testing?
I'm looking at either a chance of small difference, or adding loops to a rat's nest behind my AV/TV stand.
AudioQuestions is offline
post #2 of 21 Old 09-21-2017, 03:37 PM
gmanhdtv's Avatar
Quoted: 42 Post(s)
Liked: 27
As long as you use black walnut spacers to elevate the speaker wire off the carpet you should be fine
rnsound likes this.
gmanhdtv is offline
post #3 of 21 Old 09-21-2017, 04:10 PM
Scotth3886's Avatar
Quoted: 1804 Post(s)
Liked: 1076
I use birch cable elevators. Is that ok?
18Hurts likes this.
Scotth3886 is online now
post #4 of 21 Old 09-21-2017, 04:37 PM
Quoted: 34 Post(s)
Liked: 994
The Black Walnut ones ----- YMMV
leecreek is offline
post #5 of 21 Old 09-21-2017, 05:21 PM
Speedskater's Avatar
Quoted: 38 Post(s)
Liked: 30
For reasonable differences in length, it doesn't matter. Now if one cable was 1 foot long and the other cable was 100 foot long, then yes it would matter.
leecreek likes this.
Kevin
Speedskater is offline
post #6 of 21 Old 09-21-2017, 05:26 PM
Quoted: 720 Post(s)
Liked: 380
Why? Just move one speaker a bit forward.
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is offline
post #7 of 21 Old 09-21-2017, 06:07 PM
BassThatHz's Avatar
Quoted: 2388 Post(s)
Liked: 2162
The circumference of the earth is 25,000 miles and the speed of light is 186,000 miles per second.
So even if you lived on the north pole and put the other speaker on the south pole there would only be 7ms of delay, or ~6ft of acoustical delay.
That would make for one very expensive cable, with a very high resistance.
Even at 1ft and 100ft it wouldn't be a problem if the 100ft run was 10awg or thicker.
Is it ideal? No
Would it work? Yes.
More importantly, is having a symmetrical room and room treatments.
In fact I believe trapezoidal rooms are just about the best geometry, as it is still symmetrical, but non parallel (at least for 3 of the 6 boundaries.)
BassThatHz is offline
post #8 of 21 Old 09-21-2017, 07:14 PM - Thread Starter
Quoted: 91 Post(s)
Is it ideal? No
Would it work? Yes.
I understand the delay is not a problem, but what about change in impedance?
post #9 of 21 Old 09-21-2017, 07:33 PM
gmanhdtv's Avatar
Quoted: 42 Post(s)
Liked: 27
Hell, why worry about impedance, just need a bigger amp!!!!! Just ask Marty......................
gmanhdtv is offline
post #10 of 21 Old 09-21-2017, 08:54 PM
Scotth3886's Avatar
Liked: 1076
Big amp(s), you ask?
post #11 of 21 Old 09-21-2017, 09:08 PM
Quoted: 123 Post(s)
Liked: 123
Is it ideal? No
Would it work? Yes.
99% joking but REALLY? Speed of light and electron flow is one thing, but once those electrons exit and become sound waves, the much slower .22 miles per second makes a huge difference. :-)
darknite9099 is offline
post #12 of 21 Old 09-21-2017, 10:48 PM
GIEGAR's Avatar
Quoted: 837 Post(s)
Liked: 1427
Not in the context of consumer audio in typical domestic sized spaces, assuming you've selected at least the minimum required gauge of (non-crappy) wire.
It doesn't need to be... we have perfectly good formulae.
Audiophiles with the handy combination of hubris, super-human hearing and an immunity from perceptual bias think EVERYTHING MATTERS. Like many things, this doesn't.
Speaker wires present resistance to the flow of current.
Use this tool to determine the minimum wire gauge based on your longest run: BCAE | Speaker Wire Calculator. Then, have a play to see how much difference 8ft vs 12ft runs make to resistance and resulting dBSPL loss. It will be in the order of 0.02Ω and 0.03dBSPL... in other words, the square root of bugger all.
If you're curious, have a play to see what the disparity in wire lengths needs to be to produce a (still inaudible) 0.5dBSPL loss.
Good luck and don't expend too much more mental energy (or money) on wires, cables and everything else that doesn't matter.
jautor, m. zillch and 18Hurts like this.
GIEGAR is offline
post #13 of 21 Old 09-21-2017, 11:01 PM
GIEGAR's Avatar
Quoted: 837 Post(s)
Liked: 1427
Not necessarily Kev. Try the calculator above. A fairly typical combination of 100WPC, 14AWG and 8Ω load only produces a loss of 0.53dB for a 100ft run. You're in strife (just) with 4Ω loads though, but upping it to 12AWG solves it.
GIEGAR is offline
post #14 of 21 Old 09-22-2017, 05:39 AM
Quoted: 38 Post(s)
Liked: 30
Yes, the 1/2dB loss can be compensated for. But it will depend on the loudspeaker's impedance curve with respect to frequency. If the curve is rathre flat, then no problem. But if the curve looks like a roller coaster then the long cable channel will have EQ differences.
Kevin
post #15 of 21 Old 09-22-2017, 10:51 AM
MattB101's Avatar
Quick answer. Don't worry about it. Not enough difference to matter.
Sent from my SM-G955U using Tapatalk
Ratman and m. zillch like this.
MattB101 is offline
post #16 of 21 Old 09-22-2017, 06:42 PM - Thread Starter
Quoted: 91 Post(s)
Can you elaborate? Because I think the SF olympica 3 has a much lower than the rated 4 ohm on the low frequencies, and much higher on the high frequencies.
post #17 of 21 Old 09-23-2017, 08:25 PM
bigguyca's Avatar
Quoted: 422 Post(s)
Liked: 296
So even if you lived on the north pole and put the other speaker on the south pole there would only be (1) 7ms of delay, or ~6ft of acoustical delay.
Is it ideal? No
Would it work? Yes.
Originally Posted by darknite9099 View Post
99% joking but REALLY? (2)Speed of light and electron flow is one thing, but once those electrons exit and become sound waves, the much slower .22 miles per second makes a huge difference. :-)
(1) Light will travel about 1,300 miles in 7ms. 67ms is closer to an accurate value for light in vacuum.
The signal is traveling using a copper wire at a speed of .7c to .9c so the time would actually be proportionately longer.
(2) Electrons in a DC circuit will flow at velocity of millimeters per hour. Electrons in an AC circuit will have no net flow. Sound in air will travel far faster than electrons in a wire.
https://en.wikipedia.org/wiki/Speed_of_electricity
bigguyca is offline
post #18 of 21 Old 09-24-2017, 12:29 AM
holl_ands's Avatar
Quoted: 576 Post(s)
Liked: 253
As mentioned above, Speed of Light difference between two different Speaker Wire Lengths is of NO consequence. HOWEVER, fol. are the ONLY aspects that CAN result in AUDIBLE differences (NOT copper purity or skin effect, ad nauseum):
Insertion Loss and Damping Factor.....incl. Speaker Size Recommendations:
http://www.audioholics.com/audio-vid...er-cable-gauge
http://www.roger-russell.com/wire/wire.htm#damping
BTW: Do NOT overlook the Ohmic Loss in the Hefty Inductor Coil part(s) of the Passive Crossover feeding the Woofer....which is ELIMINATED for those of us using BI-AMPED Systems with an Electronic Crossover feeding Separate Amps for Woofer and Mid-Range/Tweeter. And to BYPASS the Woofer part of the Passive Crossover INSIDE the Speaker (even though it comes with "Bi-Amp" Terminals), usually requires opening and modifying interior wires. This ALSO eliminates high Woofer currents on the [previously SHARED] Speaker Wires from degrading Mid-Range/Tweeter signals:
https://www.electronicproducts.com/S...lculators.aspx
http://www.audioholics.com/frequent-...ng-vs-biwiring
More Technical Info re Speaker Damping Factor:
Try to keep LESS than 10:1....even better if 30:1 so that Speaker Cone follows Input Voltage with minimal Overshoot/Undershoot:
https://www.google.com/url?sa=t&rct=...POK7rZin1haJKQ
Phase & Freq. Response Variances due to Speaker Wire Impedance Variations at 10+ kHz:
[Minor, much SMALLER than Azimuthal/Vertical Tweeter Pattern Variations....and Human Ear Insensitivity]
https://www.lifewire.com/speaker-cab...rences-3134603
Fol. compares AWG11 Bi-Wire [separate wire pairs to Tweeter and Woofer] vs Doubled Up Wire Pairs to combined Tweeter/Woofer Terminals for a 4-meter (13.1-ft) long cable, showing NEGLIGIBLE impact to Freq. Response or Phase....that's a bit THICKER wire than most people use, but we can expect AWG12 and AWG14 wouldn't be much different:
http://www.empiricalaudio.com/comput...speaker-cables
Note that fol. showed Excellent Freq. Response for IMPEDANCE (NOT related to smaller effect on Freq. Response] for 10-ft long 18-Gauge wire (not so much 24-Gauge) and a WIDE VARIATION for several expensive cables.....but "FORGOT" to show how typical 16-gauge to 12-gauge "Zip Cord" performs [I would expect they would be MUCH BETTER than too skinny 18-Gauge]:
https://www.passlabs.com/press/speak...e-or-snake-oil
Also see my earlier posts on this subject, incl. links to DOUBLE BLIND TESTS:
Ask the Editors: Does Speaker-Wire Gauge Matter?
4 wire speaker connection question
And Roger Russel's entire collected litany of "stuff" on this subject:
AudioQuestions likes this.
holl_ands is offline
post #19 of 21 Old 09-25-2017, 11:22 AM
m. zillch's Avatar
Quoted: 2004 Post(s)
Liked: 1286
. . . Does equal speaker length matter? . .
No.
Ratman, 18Hurts and leecreek like this.
m. zillch is offline
post #20 of 21 Old 09-26-2017, 09:33 AM
Quoted: 38 Post(s)
Liked: 30
Remember that was about a 1 foot and a 100 foot cable.
It only applies to multi-driver loudspeakers with curves that look like a roller coaster. Ignoring the bass-reflex hump.
When Stereophile magazine tests tube amplifiers into their dummy loudspeaker load, you see the same type of response, but in this case it would only be on one channel.
Kevin
post #21 of 21 Old 09-27-2017, 09:49 AM
cegadede's Avatar
Quoted: 26 Post(s)
Liked: 26
Originally Posted by m. zillch View Post
No.
That was easy!
Enviado de meu Moto Z2 Play usando Tapatalk
cegadede is offline
