Balanced Input to RCA Adapters? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-29-2003, 03:47 PM - Thread Starter
blaine_ca's Avatar
I have recently purchased a used Classe CA-100 power amplifier, and from some of the research I have done I am aware that this model will often suffer from rather high levels of hum when using the RCA inputs. Unfortunately, my current pre-amp only has RCA out to the power amp.
I am wondering if there is any high quality gear available that will allow me to use balanced cables to connect to my pre-amp without losing much in the way of sound quality (or defeating the purpose of using a balanced input.)
This would probably be a temporary solution should I find that the amplifier hums quite a bit in my room... I will be upgrading to a pre-amp that supports balanced out sometime in the next year. The power amp hasn't arrived yet, but I'm trying to be prepared just in case I have to go down this road.
thanks in advance for any advice!
-Blaine
blaine_ca is offline
post #2 of 13 Old 11-29-2003, 05:42 PM
Larry Fine's Avatar
Blaine, especially because you will be replacing the preamp soon, I would wait to see if you have hum, rather than assume you will. Hook up the amp and give a listen with the RCA's first.
Larry
www.fineelectricco.com
My system (new larger pix!)
Larry Fine is offline
post #3 of 13 Old 11-29-2003, 10:34 PM
MikeTz's Avatar
Both Markertek (http://www.markertek.com/MTStore/Sto...&button=Search) and Radio Shack sell RCA to Balanced adapters but I can't attest to their fidelity. These adapters get the impedance right (75ohm to 110ohm) but I'm not sure they can create the differential signal required at the input of your amp.
As long as the RCA connectors are tight there shouldn't be significant hum from the Classe amp. I'm with Larry, first try the RCA connections because the RCA to XLR adapters can be more trouble than they're worth.
MT
MikeTz is offline
post #4 of 13 Old 11-29-2003, 10:41 PM
MikeTz's Avatar
Sorry, my Markertek link was in error. Go to Markertek HOME then search on "Neutrik xlr audio adapter". Then click on the link in the search window.
MT
MikeTz is offline
post #5 of 13 Old 12-02-2003, 08:27 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
Don't use the Neutric adapters, I've tried them and they sound terrible.
IMO the 'best' adapters are those made by Ayre Acoustics.
http://www.ayre.com/products/phadapt.htm
Another very good option is to use transformers instead of adapters from Jenson transformers.
http://www.jensen-transformers.com/pc2xr.html
Thomas-W is offline
post #6 of 13 Old 12-02-2003, 06:12 PM
tvtech1's Avatar
Those are for converting balanced AES/EBU to unbalanced, not for analog audio.
Those are just pin adaptors, they're of no use.
A balanced connection only has benefit when both source and destination are balanced.
tvtech1 is offline
post #7 of 13 Old 12-04-2003, 10:51 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
The "Balance Buddy" from Rane converts unbalanced RCA outputs to balanced XLR. Rane builds very high quality audio gear.
http://www.rane.com/bb22.html
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #8 of 13 Old 12-27-2003, 09:08 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 949 Post(s)
Liked: 2913
Greetings,
I have seen cables with XLR connections on one end and RCA on the other. How would something like that work if you have a preamp with Balanced outputs and an amp with unbalanced inputs?
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #9 of 13 Old 12-27-2003, 02:35 PM
oneobgyn's Avatar
IMO the best adapters are made by Purist Audio.
http://www.puristaudiodesign.com/index2.html
oneobgyn is offline
post #10 of 13 Old 12-27-2003, 03:31 PM
tsteves's Avatar
Whatever you do, don't buy anything that is not returnable.
tsteves is offline
post #11 of 13 Old 12-28-2003, 08:33 AM
tvtech1's Avatar
Originally posted by placidman
Greetings,
It doesn't work as a balanced connection, there are no benefits to it at all.
Both source and load must be balanced to realise the advantages of it.
tvtech1 is offline
post #12 of 13 Old 12-28-2003, 04:47 PM
Blu-ray Reviewer
Moderator
Quoted: 949 Post(s)
Liked: 2913
Greetings,
That is what I thought. Thanks for the response.
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
post #13 of 13 Old 12-28-2003, 06:12 PM
Matt_Doug's Avatar
Jensen's rca to XLR converters are not the same as th simple neutrik adapters. The Jensens actually output a balanced signal and are exacltly the same as the balanced outputs on the vast majority of xlr equiped components. You can also try Pro equipment maker Radio Desgin Labs (Markertek)
Once you start down the dark path, forever will it dominate your destiny. ... Yoda, ESB
Matt_Doug is offline
Closed Thread Audio Theory, Setup, and Chat
