Are Digital Coax / RCA cables the same? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-16-2004, 09:59 PM - Thread Starter
MrComandante's Avatar
I have a Yellow Monster Cable (RCA) connected from the digital out of my HD satellite receiver to my Surround Receiver But I don't think the surround is up to par. Should I buy a Digital Coaxial cable, will It really make a difference?
MrComandante is offline
post #2 of 6 Old 11-16-2004, 11:07 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
You can find a lot of information on this subject by doing a search in this very forum. Just a few lines down from this thread, you'll find this one for starters:
http://www.avsforum.com/avs-vb/showt...hreadid=467460
Hope this helps.
What I can afford, when I can afford it...
filecat13 is offline
post #3 of 6 Old 11-17-2004, 01:58 PM
ChrisWiggles's Avatar
a yellow cable indicates that it is a video cable, which means it's 75ohm, which is what is preferred for digital coax transmission, so you're good to go. A digital coax cable is just a 75ohm cable, it's the same exact thing. As long as it works, you're not gonna hear any improvement, as it's a digital cable.
ChrisWiggles is offline
post #4 of 6 Old 11-26-2004, 01:02 PM
fredpb's Avatar
As long as it is not an audio cable. Yellow usually indicates video, which should work for you. Like other has said, if it works, it works. You are usually ok.
If you really would feel better about a "digital" cable, and you could afford it, it would probably make you sleep better to get one :) .
fredpb is offline
post #5 of 6 Old 11-26-2004, 09:35 PM
JorgeLopez11's Avatar
If you're using a coax cable you'll always want to have the least signal attenuation, That's why you need a coax cable with 75 Ohms impedance value.
Nevertheless, not all coax cables have the same specs.
There are "normal" coax cables whose impedance is precisely 75 Ohm and have an impedance tolerance = plus or minus 5 Ohm.
There are precision coax cables. These have a more strict impedance tolerance = 75 Ohm plus or minus 1.5 Ohms.
The "yellow" cables can be considered "normal" 75 Ohm coax cables ;)
JorgeLopez11 is offline
post #6 of 6 Old 11-26-2004, 11:45 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
A "yellow" cable, huh? Well, just be careful.
"Watch out where those Huskies go,
Don't you eat that yellow snow..."
Frank Zappa and the Mothers of Invention.
Closed Thread Audio Theory, Setup, and Chat
