Onkyo receiver: allow upconversion from 5.1 to 6.1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-16-2005, 02:05 AM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
I've recently purchased an Onkyo HT-S770B home-theatre-in-a-box setup and have a question about the setup. Since the majority of DVDs are simply straight DTS or DD, the receiver has an option to fill in the rear centre channel (upconvert the 5.1 to 6.1).
When this option is enabled on a Dolby Digital soundtrack, the receiver displays "Dolby D EX" to signify it is outputing Dolby Digital EX. When it is enabled on a DTS soundtrack, the receiver displays "DTS+DolbyEX" to signify it is outputing a combination of DTS and Dolby Digital EX. By default, this setting is on Auto. It seems to arbitrarily pick to upconvert. I haven't been able to find a pattern, but DTS rarely upconverts. Dolby Digital almost always does.
My question is this: should I leave this option set to On? Do I want the receiver (HT-R520) to be upconverting my DVDs to 6.1?
Thanks in advance.
Marantz AVR & monoblocks + MartinLogan Motion 3.1 setup
TheGSRGuy is offline
post #2 of 5 Old 10-16-2005, 03:23 AM
sivadselim's Avatar
Quoted: 165 Post(s)
Liked: 156
well, how many speakers do you have?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 5 Old 10-16-2005, 03:41 AM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
I have the original 6.1 setup that it came with (LF, C, RF, LS, BS, RS, LFE).
post #4 of 5 Old 10-16-2005, 10:08 AM
ChrisWiggles's Avatar
in most cases using EX/ES processing on 5.1 soundtracks yields fine results. However, there may be some mixed mono in the rear which will dumb everything behind you, which may not be desired. Go by ear, but I think you'll find most everything will sound not only fine, but better with EX/ES enabled to 6.1.
ChrisWiggles is offline
post #5 of 5 Old 10-16-2005, 12:34 PM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Thanks for your reply. I'll leave it set to Auto.
Closed Thread Audio Theory, Setup, and Chat
