No subwoofer output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-16-2006, 07:20 PM - Thread Starter
sdrone's Avatar
I've finally got my new system setup. I've got a Yamaha HTR-5930 and a set of Polk RM6750 speakers.
My old system used speaker cable to go from the receiver to the subwoofer. The new system uses RCA cables.
The back of the subwoofer has a left and right low level input jack. Interesting thing is, the Yamaha receiver only has *1* subwoofer output RCA jack, not 2.
I've got a 35' 2 headed RCA cables. Both ends are hooked up on the subwoofer. I'm tried connecting either one up on the receiver, and I cannot get a test tone out of the subwoofer.
The subwoofer has moaned and hissed ever since it's been turned on, but I probably just need to move it, it might be too close to some electrical cord or something.
The Yamaha manual just suggests checking the speaker setup and the cable connections if you don't get sound out of the subwoofer. Any suggestions?
sdrone is offline
post #2 of 17 Old 12-16-2006, 07:32 PM
catacon's Avatar
My receiver (Pioneer VSX-516K) has a mono sub out and the sub amp has stereo inputs. I have a mono cable going to a 1 female to 2 male adpater, and it works fine. Using just one channel of the stereo cable should work. Make sure you have the subwoofer enabled on the receiver.
catacon is offline
post #3 of 17 Old 12-16-2006, 10:14 PM - Thread Starter
sdrone's Avatar
yeah, no joy. I'll pick up a Y cable tomorrow, though I don't think that's it. This one has me stuck.
sdrone is offline
post #4 of 17 Old 12-16-2006, 10:43 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 112
How do you have the speaker system configured in the receiver menu?
If the main speaker setting is to 'small' the sub should be automatically set to on. But if you have the main L/R set to 'large' the sub setting might be off.
Also is the sub set to normal or LFE? If to LFE then only when the LFE channel is active in the soundtrack will there be sound.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #5 of 17 Old 12-17-2006, 08:07 AM - Thread Starter
sdrone's Avatar
I have tried...
1. Setting all 3 front speakers to Large, subwoofer on
2. Setting all 5 speakers to small, subwoofer on
In both cases, I verified that the subwoofer was on.
I can adjust the LFE and "volume" level for the sub on the receiver. I've got the output level all the way up.
I didn't see an ability to set the subwoofer output to normal or LFE - I'll check that.
sdrone is offline
post #6 of 17 Old 12-17-2006, 10:11 AM
KMO
KMO's Avatar
Are you sure you're connected to the right connector on the receiver? Check you're on the subwoofer pre-out, not the subwoofer multi-channel input.
KMO is offline
post #7 of 17 Old 12-17-2006, 11:09 AM
Ratman's Avatar
Quoted: 1202 Post(s)
Liked: 947
... to clarify, you want to use the subwoofer or LFE "out" from the receiver to go to the sub.
Make sure that gets connected to the sub's "input".
Ratman is online now
post #8 of 17 Old 12-17-2006, 11:40 AM - Thread Starter
sdrone's Avatar
Heh. Yes. The single subwoofer output on the receiver is connected to the "low level input left/right" on the subwoofer. I've got a Y cable in place now and trying some stuff.
sdrone is offline
post #9 of 17 Old 12-17-2006, 01:12 PM - Thread Starter
sdrone's Avatar
I'm gonna end up calling both Yamaha and Polk. It's unbelievable how much static and hissing this subwoofer does while just sitting there.
sdrone is offline
post #10 of 17 Old 02-15-2007, 05:47 PM
doc_co's Avatar
Actually, according to Polk Audio, they suggested you run L/R to the sub, then from sub to your L/R front speakers. You have to set the L/R to "Large" in your receiver though. If you go to Polk Audio website, they have a page where they explain the reason why you should connect it that way instead of using the LFE output of the receiver.
doc_co is offline
post #11 of 17 Old 03-17-2013, 04:12 PM
palmharbor's Avatar
What is amazing to me is how poorly and incomplete owners manuals are written no matter what price
you paid for the receiver, preamp etc....they act as if nothing is going to go wrong and you will never have any
problems....I would sometimes like to wring then neck of these guys and the manager who approved it for
publishing it without reading it.
This stuff has become too damn complicated and its why few people are buying the stuff in 2013
palmharbor is offline
post #12 of 17 Old 03-17-2013, 04:21 PM
palmharbor's Avatar
Polk is made in the Peoples Republic of Vietnam and Yamaha made in the People's Republic of China.
C H E A P....crap with no quality control...
post #13 of 17 Old 03-18-2013, 05:10 AM
Ratman's Avatar
Liked: 947
And.... you had to reawaken a 5 year old thread for that opinion? rolleyes.gif
post #14 of 17 Old 03-18-2013, 07:19 PM
palmharbor's Avatar
Why not...is it not true today?
post #15 of 17 Old 03-18-2013, 09:54 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Was this your in depth review...
kiwi2 is offline
post #16 of 17 Old 03-19-2013, 12:07 PM
palmharbor's Avatar
GET a life.
post #17 of 17 Old 03-19-2013, 01:40 PM
SAM64's Avatar
Liked: 76
No, users have become "too damn simple" .
SAM64 is offline
