Center channel question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-06-2007, 11:19 AM - Thread Starter
brookspw's Avatar
My "great room" is about 20x40. At the back end of it is our kitchen. At the front end is the 50" HDTV.
What I want to do is:
1. Install surround sound.
2. Install a speaker in the back (in the kitchen) that would allow us to hear dialogue without having to crank the TV from the other end of the room.
What I guess this means is that I need to have 2 center channel speakers, correct?
If so, do you hear all that is "necessary" to hear if you are listening only to the center channel. Example -- if ALL I had on was the center channel, what would I hear?
Does this mean I can "split" the center channel and run it to the back of the room? At that point, I could install a volume control on the line and only turn it on/up when needed.
**Also, are there any receivers with bluetooth capability?
brookspw is offline
post #2 of 2 Old 01-07-2007, 06:34 AM
Rupert's Avatar
It would be best to use a two-channel analog output (like "Tape Out" or better yet, "Zone 2") connected to a separate amp and then to speakers in the kitchen. This would give you a stereo mix of the movie, so you can hear everything...dialog, music, etc. Listening to a "center-channel only" mix would not be pleasant.
Using a second zone also allows any source to play in the kitchen...radio, CD, TV, movies, etc.
Rupert is offline
