where to find 6 channel selectors - AVS Forum | Home Theater Discussions And Reviews
Old 01-10-2007, 09:46 AM - Thread Starter
stangflyer's Avatar
Quoted: 30 Post(s)
Liked: 25
I have my receiver that has a 6 channel analog input which I use for my sacd and dvd audio. I also would to be able to put my pc 6 channel there also. When I use splitters The sound volume is very low even though only one is on at a time. Is there a cheap 6 channel selector out there. I have the wiring for it. Thanks.
stangflyer is offline
Old 01-10-2007, 10:40 AM
louthewiz's Avatar
I use this switcher as a 6 channel selector and it works great and I never have any audio dropouts or lowered sounds. When you click on the link look at the rear by hitting the larger image icon so you can see the back of it:
http://www.monoprice.com/products/pr...ormat=2&style=
louthewiz is offline
Old 01-10-2007, 05:02 PM - Thread Starter
stangflyer's Avatar
Quoted: 30 Post(s)
Liked: 25
Thanks a ton. Ordered.
