Denon's Audyssey vs. Pioneer's MCACC - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1 of 136 Old 01-21-2007, 12:34 AM - Thread Starter
ImDiesel's Avatar
any opinions as to which one works better...?
the Pioneer VSX-82TSX has this program and comes with the mic for setting it up...
the Denon AVR-2807 has the Audyssey, and I'm assuming it comes with a mic for setting it up...
does anyone know if the Pioneer passes audio and video through HDMI...? i know the 2807 does...
my main use will be for PS3, and ocassional movie watching...
Thanks...
ImDiesel is offline
post #2 of 136 Old 01-21-2007, 03:38 PM
soundlovr's Avatar
Audyssey is the most advanced room correction in the market presently. MCACC doesn't hold a candle.
You assume correctly.
If not, one would question why it's there (ie: yes, it does).
Given that you don't even list music-listening as a purpose to the system, room correction seems an unimportant factor for your needs. Pick the cheapest option.
soundlovr is offline
post #3 of 136 Old 01-21-2007, 04:11 PM - Thread Starter
ImDiesel's Avatar
so speaker setup for surround sound holds no importance...?
ImDiesel is offline
post #4 of 136 Old 01-22-2007, 08:13 AM
hdgeek's Avatar
Even for movie watching, the Audyssey on the Denon 2807 made a huge difference in my room. Vocals are better focused and the sound stage is much wider with smooth panning. I can also sit off-center with dialog still anchored to the screen.
Room correction, if done well, makes all sources sound better. Music just gets the most benefit.
hdgeek is offline
post #5 of 136 Old 01-22-2007, 09:33 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Sure, it does but both the Denon and the Pioneer (as well as many others) have that.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #6 of 136 Old 01-22-2007, 11:34 AM - Thread Starter
ImDiesel's Avatar
i opted for the Elite... but can swap it out if i so choose...
we'll see how it works out...
ImDiesel is offline
post #7 of 136 Old 01-23-2007, 02:08 AM
soundlovr's Avatar
Audyssey is a RoomEQ product, not a speaker setup routine.
post #8 of 136 Old 01-23-2007, 06:16 AM
Quoted: 673 Post(s)
Liked: 460
Yes. Seems as if we have to say this over and over and over.......................
Kal Rubinson
post #9 of 136 Old 01-23-2007, 07:16 AM - Thread Starter
ImDiesel's Avatar
ok, i got it...
no need to continue crying about it...
and it seems the Audyssey is mainly for music, so i have zero use for it anyhow...
ImDiesel is offline
post #10 of 136 Old 01-23-2007, 07:36 AM
Quoted: 673 Post(s)
Liked: 460
Where did you get this idea from? It applies equally to music and HT and most of the Audyssey-recommended demos for it are movies, not music.
Squirrel! likes this.
Kal Rubinson
post #11 of 136 Old 01-23-2007, 08:17 AM - Thread Starter
ImDiesel's Avatar
i got it from someone here who said the Audessey was mainly for music content...
it's hard to get somewhere when you have conflicting information coming from all angles...
ImDiesel is offline
post #12 of 136 Old 01-23-2007, 09:28 AM
krabapple's Avatar
Quoted: 382 Post(s)
Liked: 371
As did MCACC in mine. I haven't heard any of the other mfrs' automatic room correction routines.
But the fact is , no one has published any sort of rigororous (or even casual, as best I know) comparison of Audyssey vs MCACC vs YPAO vs Harman's room eq, in terms of their effects on the same room, same setup, same listening position. Not even before/after room measurements, much less subjective impressions (Kal, are these something Stereophile could be persuaded to try?). So any definitive claims made here should be taken with a large lump of salt. It should also be noted that Audyssey as supplied on Denon receivers is a 'simplified' version of the extremely powerful Audyssey engine available as a stand-alone device.
krabapple is offline
post #13 of 136 Old 01-23-2007, 10:17 AM
Quoted: 673 Post(s)
Liked: 460
Not very likely. We do not review receivers, as a rule so, unless someone is very hot to do this particular test, it will not happen. Don't count on me.
See my forthcoming March column.
Kal Rubinson
post #14 of 136 Old 01-24-2007, 07:06 AM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Well, I'm extremely happy with Audyssey on both, music & video performances.
All I do is - once in a while - to swap between Audyssey & Flat modes, but most of the time it's engaged on Audyssey. My AVR is a 3806.
To my taste, not even manual EQ (which doesn't have Audyssey apllied) surpasses the former. So, IMHO: THANKS Audyssey!
Hope this helps.
Cheers.
Regards, Chuck
Hold on tight to your dreams - ELO
Avliner is offline
post #15 of 136 Old 01-25-2007, 05:56 PM
WebEffect's Avatar
Quoted: 98 Post(s)
Liked: 44
I'm curious, how does Yamaha's YPAO compare to Audyssey?
WebEffect is offline
post #16 of 136 Old 01-25-2007, 06:34 PM - Thread Starter
ImDiesel's Avatar
apparently it's crap, cause everyone seems to feel the Auddessy is GOD...
ImDiesel is offline
post #17 of 136 Old 01-26-2007, 08:17 AM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
... or DEVIL, if you see things from a different angle.
Lots of people on this & other forums doesn't like the way Audyssey sounds though.
Cheers.
Regards, Chuck
Avliner is offline
post #18 of 136 Old 01-27-2007, 01:28 PM
skoolpsyk's Avatar
Quoted: 65 Post(s)
Liked: 44
I sure wish someone would; I think a LOT of people would be interested in the results!
skoolpsyk is offline
post #19 of 136 Old 01-01-2009, 10:50 AM
SkiSmuggs's Avatar
apparently YPAO is crap, cause everyone seems to feel the Auddessy is GOD...
They are ALL better than doing nothing which is what many people do. Most don't own an SPL meter. Just because Audyssey is the preferred EQ by many does not make the others crap. And having your a** on your shoulders doesn't make anything sound better.
SkiSmuggs is offline
post #20 of 136 Old 01-05-2009, 08:16 PM
nwbnd's Avatar
So is the only option to automatic correction schemes a PEQ? If so, is there a 5.1/7.1 ch PEQ that is cost competitive with the built-ins?
nwbnd is offline
post #21 of 136 Old 01-05-2009, 08:30 PM
Quoted: 673 Post(s)
Liked: 460
Nope. The hardware cost of the built-ins is minimal consisting of firmware and a mic input. The hardware cost of a standalone includes real hardware (chips, controls, components), chassis and power supply. Hard to imagine how they could be cost competitive. In fact, I do not know of such a stand-alone 5.1/7.1 PEQ.
Kal Rubinson
post #22 of 136 Old 01-05-2009, 10:47 PM
zamboniman's Avatar
Are they all truely just frequency domain PEQ's though? For some odd reason I thought I remember some (maybe Audessey) also doing some time domain correction as well. That said if truely the case with time correction and implemented correctly (big assumption) the internal room correction should be superior to stand alone PEQ??
All that said the best rooms I've heard have just been calibrated with external EQ.
zamboniman is offline
post #23 of 136 Old 01-06-2009, 04:16 AM
soundlovr's Avatar
Audyssey is indeed time-corrected as well as frequency-corrected. That is perhaps the main reason why it is so vastly superior to a PEQ. But also, it uses finite impulse response filters instead of PEQ's infinite impluse response filters which eliminates the smearing and ringing that PEQ systems create.
For PEQ to compete, it would have to be 512-band, time-correcting, and completely change its filter-type. Hence... PEQ cannot compete
post #24 of 136 Old 01-06-2009, 06:24 AM
nwbnd's Avatar
Is that 512 band/ch? Is this the same for all levels (2eq, multeq, xt)?
nwbnd is offline
post #25 of 136 Old 01-06-2009, 12:37 PM
krabapple's Avatar
Quoted: 382 Post(s)
Liked: 371
Possibly exciting news on the comparative testing front:
http://www.avsforum.com/avs-vb/showp...&postcount=340
assuming Audyssey and MCACC were tested, which is unknown.
post #26 of 136 Old 01-06-2009, 12:43 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
You can download the report from the AES library.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #27 of 136 Old 01-06-2009, 04:22 PM
RexCarson's Avatar
Not true. Even CNET's review stated that Audyssey's setup is far more complex and time-consuming, though no more accurate.
Advanced MCACC as used in current model Pioneers is most excellent and has some major advantages. Let me link you to a Denon thread and a post of mine where I posted my review of their operational differences regarding customizing the results to the content and your tastes, as to why I chose MCACC over Audyssey in a big way:
http://www.avsforum.com/avs-vb/showt...&#post15252779
MCACC also works in the time domain to correct for room reflections as well direct sound from the speakers. See this Denon thread and my post there:
http://www.avsforum.com/avs-vb/showt...&#post15259633
Originally Posted by chriskav73 View Post
As a current Pioneer owner and former Denon owner, I prefer the results of MCACC over Audyssey. I found the imaging to be spot on with MCACC, and it also corrected for a boomy bass problem that Audyssey couldn't correct for me.
That doesn't surprise me. Enjoy!
RexCarson is offline
post #28 of 136 Old 01-06-2009, 04:45 PM
jostenmeat's Avatar
Uhh. Audyssey makes a lot of products. Disregarding Dynamic EQ/Volume, did you use?...
2eq
multEQ
multEQ XT
Audyssey Pro
Audyssey SEQ (nm, its a standalone)
jostenmeat is offline
post #29 of 136 Old 01-06-2009, 07:20 PM
BobL's Avatar
Liked: 56
The first thing to consider with these auto EQs/room correction systems is they should be thought of as the final tweak. Fix the room first! None of these can correct room problems, they TRY to compensate for them. I understand using these systems is sometimes the only option one has in their situation, but if possible fix the room!
The other thing to consider is how these systems work. We can argue the technical merits of one vs. the other but that doesn't mean the more advanced EQ will give better results. The reason is none of these systems know what is causing the problems in a given room. They apply an algorithm based off their measurements. These systems can be tricked and often apply settings that may not be appropraite for a given situation.
If the EQ system with the lesser technical abilities happens to have its algorithm modeled after a room similar to the one being measured your results will probably be pretty good. If the measurements trick the more advanced EQs algorithm the results might not be as good.
It is important to understand that when measuring multiple seating locations that the measurements at different seats might require different EQ correction which isn't possible. Depending on the algorithms decisons some locations may sound worse! Debating over which one does the better job is pointless unless the rooms, equipment, etc. are identical.
Hope this helps.
Bob
BobL is offline
post #30 of 136 Old 01-06-2009, 09:53 PM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
Hope this helps.
Bob
Bob, Very nicely said!
Ray
Ray
"Listen with an open heart and mind."
cavchameleon is offline
Audyssey , Denon , Pioneer , Pioneer Brand
