Best bang for the buck cables? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 02-15-2007, 11:59 AM
Ratman's Avatar
Quoted: 1291 Post(s)
Liked: 1031
What's wrong with twisted pair?
Ratman is online now
post #32 of 45 Old 02-15-2007, 12:04 PM
DaveHolland's Avatar
I like BJC because:
1) I know exactly what raw materials go into the finished product.
2) I can custom order the length I need. Helps keep the rat's nest effect to a minimum.
DaveHolland is offline
post #33 of 45 Old 02-15-2007, 12:11 PM
schticker's Avatar
I'll just end this thread here (since it's going there anyway) and say:
Avoid Monster
Blue Jeans or Monoprice are both companies built by God himself.
There, typical AVS wire response.
The First Clarke Law states, 'If an elderly but distinguished scientist says that something is possible he is almost certainly right, but if he says that it is impossible he is very probably wrong.'
schticker is offline
post #34 of 45 Old 02-15-2007, 02:33 PM
jwatte's Avatar
Yes, you can run a 25' sub line with little trouble. If you run it balanced, you dont' have to worry about where the wire is run; if you run it un-balanced, you MAY need to be careful about where to run it, to avoid picking up hum.
If you run the wire inside a wall, make sure you get CL2 or plenum rated cable, as unrated (or just UL rated) cable is a fire spread hazard that may void/reduce your fire insurance coverage.
jwatte is offline
post #35 of 45 Old 02-15-2007, 05:10 PM
rynberg's Avatar
http://www.bluejeanscable.com/articl...-with-hdmi.htm
Avoid Monster
You're welcome to provide other "bang-for-the-buck" cables instead of just being a smart ass. I used Blue Jeans before I was even an active member here. There's a reason they are so commonly recommended....good prices, good quality, good customer service. What's the problem?
rynberg is offline
post #36 of 45 Old 02-15-2007, 06:29 PM
Ratman's Avatar
Liked: 1031
The BJC article is total bull in regard to Cat5 and is nothing more than smoke and mirrors.
When will they come out with a coaxial HDMI cable?
post #37 of 45 Old 02-15-2007, 10:23 PM
Mr. Mojo's Avatar
Use any 25' RG59 or RG6 cable. You'll be fine.
Thanks Ratman.
Mr. Mojo is offline
post #38 of 45 Old 02-15-2007, 10:42 PM
schticker's Avatar
Anytime anyone asks a question about cables/wires on here, the answers are always the same, and usually turns into an anti-Monster flame war. I realize it's the same herd answer that's expected anyway, so let's just avoid the issue entirely and sticky the answer, you know? I'm actually quite serious.
post #39 of 45 Old 02-16-2007, 07:20 AM
BigNunz6's Avatar
I was always happy with the products I got from Frank at SignalCable.....good quality and reasonable prices.....
IF YOU LIKE IT....BUY IT!
BigNunz6 is offline
post #40 of 45 Old 02-16-2007, 09:24 PM
Mr. Mojo's Avatar
Thanks for the info jwatte.
What do you mean by "balanced"?
Mr. Mojo is offline
post #41 of 45 Old 02-16-2007, 09:28 PM
mrjinglesusa's Avatar
New to home audio but I just purchased some 12g speaker cable and an 8' HDMI cable from Blue Jean Cable. Fast shiipping, quality product. I'm very happy with them and will use them again. I'm amazed at the quality difference between 25' of Monster speaker wire from Circuit City and 25' of 12g Blue Jean Cable. NIGHT and DAY.
mrjinglesusa is offline
post #42 of 45 Old 02-16-2007, 09:30 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
In what sense it was Night and Day? The sound quality? was it noticable?
Pioneer Elite SC-67, B&W 805S/XTC/M1/PV1, Pioneer Elite Kuro 111FD, Elite BDP-05FD
alexb76 is offline
post #43 of 45 Old 02-16-2007, 09:43 PM
jwatte's Avatar
Balanced wiring is XLR (using 3/4" locking connectors, or possibly TRS 1/4" tele). Unbalanced is tip/sleeve, typically using RCA, or a TS 1/4" tele. Balanced is used in high-end gear and pro gear; unbalanced is used in consumer gear (because it is cheaper for short runs). Balanced is much less susceptible to interference.
jwatte is offline
post #44 of 45 Old 02-17-2007, 08:55 AM
Yes, sound quality is better with the Blue Jean wires. Much "crisper". But in my post I was talking about the build quality of the speaker wires themselves. The Blue Jean cables are simply MUCH better quality than the Monster. THe inner copper wires are not thin little strands like the Monster.
post #45 of 45 Old 02-17-2007, 05:28 PM
Mr. Mojo's Avatar
Thanks for all your expertise.
It's very appreciated.
Mr. Mojo is offline
