Best bang for the buck cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 02-12-2007, 11:46 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
Hey guys,
I am trying to find a set of good cables but don't wanna pay for marketing, just for quality. Here is what I need:
- 3 * 3' Digital coax cables
- 25' Subwoofer cable
- 2 @ 25' Speaker cables
- 1 HDMI-to-HDMI cable
- 2 * 6' Component cables
So far I've found monoprice and blue jeans cable as my choices. Blue Jeans is much more expensive (60% more), but I am not sure about monoprice quality and if it's as good as Blue Jeans Cables. Both are WAY CHEAPER than Monster or similar retail cables.
Any opinions? Is monoprice just as good, in other words, is it worth paying 60% more for bluejeans cables?
Thanks and sorry if this was asked before...
Pioneer Elite SC-67, B&W 805S/XTC/M1/PV1, Pioneer Elite Kuro 111FD, Elite BDP-05FD
alexb76 is offline
post #2 of 45 Old 02-13-2007, 12:07 AM
Dodo Bird's Avatar
I've never used Blue Jeans, but I can say that Monoprice cables seem to be excellent quality and do the job. One of their cables I ordered was so thick I had a problem getting it around a sharp bend!
(I know, I know, thickness doesn't mean quality. I'm just making a comment.)
Dodo Bird is offline
post #3 of 45 Old 02-13-2007, 05:24 AM
whoaru99's Avatar
Liked: 69
Originally Posted by alexb76 View Post
Hey guys,
Depends on what you mean by "just as good" - whether or not it's "worth it" is up to you.
If your real question is whether or not you see or hear a difference, IMO, the answer is probably not.
However, if knowing your cables are made with top notch wire stock (Belden or Canare) and top notch connectors (Canare) gives you peace of mind or some other kind of warm and fuzzy, then IMO, it is worth the extra $.
When one spends a fair pile of $ on gear, I guess I find somewhat odd to use the cheapest possible connections. But, by that same token, I'm not a proponent of mega-buck cables. For me, Blue Jeans strikes a fair balance between cost and what I feel I'm getting for my $.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #4 of 45 Old 02-13-2007, 05:29 AM
Joe_M's Avatar
I've been happy with Acoustic Research cables. They have several levels of each type of cable. I normally use their Pro or Pro II series.
There is no "best", best is what's best for you...
Have you tried searching first?
Joe_M is offline
post #5 of 45 Old 02-13-2007, 08:37 AM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
well, what I mean by "just as good" is this:
1. I get no HUM in the subwoofer cable (25')
2. I get least amount of "noticable" signal loss in my speakers
3. I get no "noticable" video loss through HDMI
4. All connectors are solid and don't come off if I took em in and out
5. Component Video cable is TRUE 75ohm
6. Digital audio comes through with no hick-ups (have had cables that cut in and out)
So, if monoprice meets all of the above, then it should be fine.
alexb76 is offline
post #6 of 45 Old 02-13-2007, 11:13 AM
mediahound's Avatar
I like Blue Jeans Cable speaker cables and sub cable and use them in my system. I definitely notice a difference after switching to them.
While Blue Jeans also sells RCA interconnects, and digital and HDMI cables, for those I'm using Monoprice premium line cables, which are less money than Blue Jeans but seem pretty good nevertheless.
mediahound is offline
post #7 of 45 Old 02-13-2007, 11:35 AM
rynberg's Avatar
The Monoprice cables do everything you need a cable to do....I happen to prefer the build quality/aesthetics/price relationship of the Blue Jeans though. Although the "premium" Monoprice cables are not much cheaper than BJ.
rynberg is offline
post #8 of 45 Old 02-13-2007, 01:21 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
The biggest price difference is in Component cables where BJ is like 3 times more expensive!!! Is it worth that much more?
alexb76 is offline
post #9 of 45 Old 02-13-2007, 01:52 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
What about DVIGear? Their price falls between monoprice and bluejeans... they are recommended cable vendor at Audioholics... any experience with them?
thnx
alexb76 is offline
post #10 of 45 Old 02-13-2007, 04:32 PM
rynberg's Avatar
You are not comparing apples to apples. The much cheaper Monoprice cables use thinner gauge wire and cheaper RCA connectors. Like I said, the Mprice cables pretty much do everything you need, but for me, the BJ cables represent a better overall combo of build/price. Plus their name is "BJ"....
rynberg is offline
post #11 of 45 Old 02-13-2007, 04:48 PM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1179
Any comparisons/facts you can provide to back that up?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #12 of 45 Old 02-13-2007, 06:04 PM
Mr. Mojo's Avatar
I'm considering using a 25 foot cable through my attic to subwoofer in the back of the room. There's an ideal place to hide the large subwoofer there.
Has anyone had any experience, positive or negative, with such a set up (25 foot cable to sub)?
Mr. Mojo is offline
post #13 of 45 Old 02-13-2007, 06:14 PM
whoaru99's Avatar
Liked: 69
Are you implying the molded-on RCA connector on the inexpensive monoprice cables is equivalent in price to the Canare connector used on the BJC?
whoaru99 is offline
post #14 of 45 Old 02-13-2007, 09:37 PM
jwatte's Avatar
For me, it matters most that Bluejeans usually has their stuff in stock, whereas monoprice always seem to be out of stock on exactly the particular cable I need.
jwatte is offline
post #15 of 45 Old 02-14-2007, 04:19 AM
Ratman's Avatar
Liked: 1179
That's debatable... properly constructed and once installed. No audible or visual difference IMO. Are Canares preferred among "audiophiles"? Yes... those that want top of the line and can afford the added expense. I'd equate it to SUV's. they all provide the same funtionality ( IE. Explorer vs. Escalade).
As for the wire gauges...
Monoprice has RG59 or RG6. From what I can see, so does BJC. So, the wire gauges would be the same, right?
post #16 of 45 Old 02-14-2007, 05:16 AM
whoaru99's Avatar
Liked: 69
I must assume that RG59 and RG6 would, out of necessity, be very similar in respective gauge regardless of who made it.
However, I took "the much cheaper" Monoprice cables as meaning the cheapest ones. If they are like the ones that come with some types of gear and from the website pictures they appear to be as such, there is no question the gauge is thinner and the connectors are less expensive than BJC. The premium Monoprice cables likely are an entirely different story, but are they much cheaper than a comparable BJC, or vice versa?
whoaru99 is offline
post #17 of 45 Old 02-14-2007, 05:42 AM
Ratman's Avatar
Liked: 1179
http://www.monoprice.com/products/pr...ormat=2&style=
http://www.bluejeanscable.com/store/...nentprices.htm
post #18 of 45 Old 02-14-2007, 05:54 AM
whoaru99's Avatar
Liked: 69
No question about that, those MP cables are much less costly than the BJC cables.
I still prefer the Canare terminations though. I have had a few RCA jacks ruined (outer shell contact pulled off) by RCA plugs that were way too tight or somehow seized up on the jack. I just don't see that happening with the Canare plug so to me there is some value added - how much, of course, is purely subjective.
Your points are noted though.
whoaru99 is offline
post #19 of 45 Old 02-14-2007, 09:35 AM
rynberg's Avatar
Ratman, I stand by my points above....Mprice isn't using the (very expensive) Canare connectors that I really like. Those significantly add to the cost. I said that the Mprice cables will do everything you need a cable to do, but FOR ME, the cost/build ratio of the BJ cables is more to my liking. What's there to argue about?
EDIT - I WAS wrong on the gauge, the Mprice do use RG-6. My apologies.
rynberg is offline
post #20 of 45 Old 02-14-2007, 09:47 AM
Ratman's Avatar
Liked: 1179
Hey... to each their own. I personally can't justify almost 2 1/2 times the price for just for an RCA connector. Not an arguement at all.
post #21 of 45 Old 02-14-2007, 11:32 AM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
What is so special about Canare connectors? on their brochure they claim not all connectors are true 75ohm which results in problems, but not sure what kind of problems?
alexb76 is offline
post #22 of 45 Old 02-14-2007, 01:34 PM
Ratman's Avatar
Liked: 1179
There are no problems.
RCA connectors are not 75 Ohm (although there are some that "claim" to be or close to). And a 1/4 to 1/2 inch is not going to present any visible issues.
IMO... if it were such a major deficit... why wouldn't "all" video inputs/cables use F or BNC connectors?
post #23 of 45 Old 02-14-2007, 03:26 PM
whoaru99's Avatar
Liked: 69
Not so much impedance problems, but when some other types of RCA plugs pull the RCA jacks apart on your vintage gear that you can't get parts for anymore (unless you find a used one), the added cost of the Canare is worth it, IMO.
The only way you are going to be convinced is to order a pair of each. Try them out, make your decision, and chalk up the relatively small cost as educational expense.
whoaru99 is offline
post #24 of 45 Old 02-14-2007, 06:09 PM
jwatte's Avatar
You understand that that's mostly FUD, right?
jwatte is offline
post #25 of 45 Old 02-14-2007, 09:42 PM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
So, is this BS? http://www.bluejeanscable.com/pages/...canarercap.pdf
alexb76 is offline
post #26 of 45 Old 02-15-2007, 04:59 AM
whoaru99's Avatar
Liked: 69
So, is this BS? http://www.bluejeanscable.com/pages.../canarercap.pdf
The only way you are going to be convinced one way or another is to order a pair of each, try them out and make your decision. Chalk up the relatively small cost as educational expense.
The merits of cables and connectors have been debated since the dawn of stereo gear and likely will be until it's demise.
So, either take the advice of those whos argument makes the most sense to you, or get a selection and make up your own mind.
whoaru99 is offline
post #27 of 45 Old 02-15-2007, 07:04 AM
Mr. Mojo's Avatar
Bump for any info.
Mr. Mojo is offline
post #28 of 45 Old 02-15-2007, 09:09 AM
Ratman's Avatar
Liked: 1179
Use any 25' RG59 or RG6 cable. You'll be fine.
post #29 of 45 Old 02-15-2007, 09:39 AM - Thread Starter
alexb76's Avatar
Quoted: 36 Post(s)
That is the best non-advice, advice I've ever had
Cheers!
alexb76 is offline
post #30 of 45 Old 02-15-2007, 10:49 AM
rynberg's Avatar
They should! All pro video uses BNC connectors, because maintaining 75 ohm impedance DOES matter. It's unfortunate that some moron a few decades ago decided that RCA connectors should also be used for consumer video.
Obviously history has taught us nothing, as a whole new generation of morons decided to use twisted pair wiring to transmit high resolution video (HDMI). DUMB!
rynberg is offline
