alternative to BFD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-14-2007, 06:27 PM - Thread Starter
mastarecoil's Avatar
I am interested in getting a BFD, but I am picky. I very much dislike silver or white things in my rack. All of the rest of my components are black, and if I am going to get anything I would like it to match. If I dont find anything, Ill probably still get a BFD, but Ill just hide it somewhere, however, are there any other good (and low cost) units that people reccomend, which are black?
mastarecoil is offline
post #2 of 9 Old 02-14-2007, 06:34 PM
CharlesJ's Avatar
Quoted: 423 Post(s)
Liked: 248
How about painting it? I am not sure you will find a comparable component in black. I cannot think of a reason why the company used that faceplate
CharlesJ is offline
post #3 of 9 Old 02-14-2007, 06:48 PM - Thread Starter
If I recall correctly, there are labels painted under the buttons on the bezel. This still is an option, however. Buying something black already would be nice though.
post #4 of 9 Old 02-14-2007, 07:32 PM - Thread Starter
Is there an easy and clean looking way of printing labels to put on the bezel should I paint it black?
post #5 of 9 Old 02-14-2007, 07:58 PM
EC
EC's Avatar
I actually got rid of my BFD for an analog PEQ. Then replaced the PEQ with the SMS-1. If you want to keep the BFD, you could get a blank plate and bolt it in front of the BFD with some spackers. I was considering this not for aesthetics but so people wouldn't mess my settings.
Eric Chong
My HT Pictures
EC is offline
post #6 of 9 Old 02-14-2007, 08:52 PM - Thread Starter
Sorry, I know most people are able to keep up with all this, but I am still behind on what all these acromins are. What is PEQ and SMS-1?
post #7 of 9 Old 02-15-2007, 12:07 AM
CharlesJ's Avatar
Quoted: 423 Post(s)
Liked: 248
Yes, you are right, sorry.
-It is best to have those labels. There might be a way to anodize the face plate, more $$, and just block off the labels? You could look around the area where you live for such service.
-Or, someone who is into painting computers fancy. They would know how to mask off those labels and paint the plate..
-Or, how about a smoked glass in front of it. You can still see what you have set, yet not look silver and have easy access to change settings?
CharlesJ is offline
post #8 of 9 Old 02-15-2007, 07:27 AM
EC
EC's Avatar
PEQ=Parametric EQ
SMS-1= Velodyne SMS-1 which is an auto calibrating PEQ for subs
Eric Chong
My HT Pictures
EC is offline
post #9 of 9 Old 02-16-2007, 08:04 PM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 63
I've toyed with this idea myself, painting the BFD. I'd first scuff it up with some #400 sandpaper before shooting it with some satin black spray paint.
For the labeling, I'd try scanning the front faceplate and printing stick-on labels on a good-quality printer (if you don't have one, you could take the files to Kinkos or something). I wouldn't worry about every little bit of labeling, like the line between the L and R engine, the Couple and Midi labels etc.- just basic labeling. I wouldn't worry with all the superfluous wording on the left side of it either. I'd also buy some flat aluminum stock and cut some side covers for the holes that are left when you take off the rack ears.
Really, the only iffy part will be the stick-on labels, making the lettering small yet extremely sharp. If you can get that, the rest would be easy.
Someday I'm going to give it a try.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
