Setting Up Your Home Theater 101 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 03-19-2008, 05:22 PM - Thread Starter
DrPainMD's Avatar
Added a new Section:
Shakers, ButtKickers and Tranducers
AVS - Shakers - Simple/Cheap Hookup - Visual Guide
super dirty , super clean , pow
DrPainMD is offline
Old 03-31-2008, 11:54 PM
kinglerxt's Avatar
The correct spelling is HarmAn with an "a" not Harmon with an "o"
I used to work at Harman International in Northridge in the OEM Automotive division making speakers for Chrysler
http://www.harman.com/
Originally Posted by DrPainMD View Post
Loudspeakers and Rooms for Multichannel Audio Reproduction, Part 1 by Floyd E. Toole from Harmon
Loudspeakers and Rooms for Multichannel Audio Reproduction, Part 2 by Floyd E. Toole from Harmon
Loudspeakers and Rooms for Multichannel Audio Reproduction, Part 3 by Floyd E. Toole from Harmon
Audioholics - Speaker Placement: Setup Tips for Upgraded Home Theater Systems
"We each pay a fabulous price, for our visions of paradise. But a spirit with a vision, is a dream with a mission" - Rush
kinglerxt is offline
Old 05-04-2008, 04:22 PM
freemind's Avatar
I only would like to thank you for this subject , thank you again for your effort >
freemind is offline
Old 05-09-2008, 06:51 PM
rightslot's Avatar
Hello All,
I need some help.
I continually read on the back of my blu-ray discs, that the best sound is in uncompressed PCM 5.1.
However, when I choose this setting I get MUCH LESS sound than by using the Dolby or DTS settings.
I'm sure I've set something wrong or didn't set anything at all.
Help?
The only reason to live, is to LIVE!
rightslot is offline
Old 05-22-2008, 01:37 PM
jhan1000's Avatar
what type of player and receiver do you have?
Life is good.
jhan1000 is offline
Old 07-01-2008, 04:48 PM - Thread Starter
DrPainMD's Avatar
fixed all dead links
DrPainMD is offline
Old 07-02-2008, 05:22 AM - Thread Starter
DrPainMD's Avatar
I added a couple more links
Subwoofers: Optimum Number and Locations by Todd Welti
eCoustics - 68 Subwoofer Articles
DrPainMD is offline
Old 07-03-2008, 05:01 AM
enzo-ita's Avatar
I am not totally satified with sound of my sub.
It seems to me that it calls too much attention and that it does not melt very well with the rest of the system.
I have set the crossover for all satellites to 120Hz and the LPF of LFE to 120Hz either.
Gain is at 25% and sub level is -4,5 dB.
While it does tremendous shaking of the sofa to its left, the sound does not seem natural and too muddy.
Attached a drawing of the room and a rendering. Ceiling is 9 feet.
The rendering is somewhat old. The coffee table with the lamp on the south wall on the right of the sofa, is not there anymore. The sub is in its place.
Any suggestion is welcome.
enzo-ita is offline
Old 07-14-2008, 09:44 AM
Naxray's Avatar
Apologies in advance for the newb question and I hope this is in the correct thread, but I am setting up a new AVR and now have options for connecting my CD player. The player is a Marantz CD6000 OSE (about 8 years old) and I just picked up a Pio 1018 AVR. I've always used analog but now have the option of using the digital outs. I see it has 2 - one optical and one coaxial. The manual is not clear as to what the preferred connection should be. Any insights most appreciated!
Brad
Naxray is offline
Old 07-16-2008, 04:52 AM - Thread Starter
DrPainMD's Avatar
Brad
Use either.
I added these to the main list inline with your question.
Audioholics - Optical vs. Coaxial Digital Connections
TechFAQ - What are Digital Audio Cables?
DrPainMD is offline
Old 07-28-2008, 09:51 PM
danpass's Avatar
danpass is offline
Old 08-13-2008, 02:38 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Dr. Pain - Their is a thread over at HSU forum http://forum.hsuresearch.com/showthread.php?t=4003 Post #33, that gives a very good explanation on how to calibrate a true sub with a HSU MBM-12 mid bass sub. A lot of people are starting to go this route now and they need good info on how to properly these subs up. So could you include this info on this thread.
Thanx, Bill
bsoko2 is offline
Old 08-13-2008, 06:56 PM - Thread Starter
DrPainMD's Avatar
Thanx, Bill
thanks for the link,
Added it:
Subwoofer Setup, Placement and Theories
HSU - Calibrate A Sub With A HSU MBM-12 Mid Bass Module
DrPainMD is offline
Old 08-16-2008, 03:12 PM
Ryaneleven's Avatar
Hey all im looking for advice on what type of amp i should be looking for.
I will be using it to power two floorstanding speakers like the monitor rs6/rs8 or something similar. i will be using it for mostly music, and id like to run my Westinghouse LCD, Oppo dvd player(also as cd player), and xbox360 through it also. I do not plan to add any other speakers into the mix at this point, so does that make this a two channel system?? Also, since i will be running multiple sources through it, should i be looking at an integrated amp? That is what i have been told as it will provide more power to the speakers and as as a control center for the rest of the components.
also, I have one hdmi input on my TV, and hdmi output on all my components, do i need an amp with multiple hdmi inputs, ordoes that not matter?
thanks!
Ryaneleven is offline
Old 08-20-2008, 03:51 AM
Willis52's Avatar
I am new to this HT and I have a question. If I connect my blu-ray player with HDMI to the receiver, how can I just get sound from my tv and not 7.1? Will I have to use 2 inputs like HDMI for the receiver and component for the tv?
Willis52 is offline
Old 08-21-2008, 06:45 AM - Thread Starter
DrPainMD's Avatar
Yes
DrPainMD is offline
Old 08-22-2008, 07:40 AM - Thread Starter
DrPainMD's Avatar
Added:
Quick and Effective Sub Placement, Period! By Carl Kennedy
DrPainMD is offline
Old 08-22-2008, 09:45 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Now, if you could come up with a quick and effective sub placement for those 4 subs that Harman likes to talk about so that they're properly integrated, that'd be nice. As always, a hell of job Doc.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
Old 08-23-2008, 05:03 PM - Thread Starter
DrPainMD's Avatar
these?
http://www.sound-thinking.org/index.php?showtopic=2213
DrPainMD is offline
Old 08-25-2008, 05:49 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Maybe I missed something, but I don't see a simple method that the end user can employ to get the levels/phase right. Besides, is there really anything like a perfectly rectangular room for the majority of us? Regardless Doc, a hell of a job!
Chu Gai is offline
Old 08-25-2008, 06:21 AM - Thread Starter
DrPainMD's Avatar
maybe this?
http://www.hometheaterforum.com/htf/...-nousaine.html
DrPainMD is offline
Old 08-25-2008, 11:29 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
LOL. Yeah, I wrote that summary and it generally applies to one sub. I don't post there anymore, even under a different name because I managed to get myself booted off permanently. I saw other writings by TN where he talked about the work by Harman with respect to multiple subs and was of the general opinion that properly integrating them into the whole scheme of things was not a trivial excercise in the least with most people opting for what they thought was best without the requisite measurements. If I'm not mistaken, TN uses a series of subs in an infinite baffle approach in his home. Tom does love his low frequencies!
Chu Gai is offline
Old 08-26-2008, 10:33 PM - Thread Starter
DrPainMD's Avatar
I'll be adding this soon:
Gotta clean up the whole thread, and re vamp it.
DrPainMD is offline
Old 08-27-2008, 09:24 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
What about color coding key articles in the various sections for the novice. The basic stuff they need to get them going without wading into anything too technical?
Chu Gai is offline
Old 08-27-2008, 10:22 AM - Thread Starter
DrPainMD's Avatar
sounds good on paper.... wanna help me out?
DrPainMD is offline
Old 08-27-2008, 10:58 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
I could. I also have no problem deferring to your choices. You're the originator of this useful compilation and as such ought to receive the proper recognition and not have it diffused. I simply suggested color coding which has already been adopted the US Department of Homeland Security!
Chu Gai is offline
Old 08-27-2008, 11:22 AM - Thread Starter
DrPainMD's Avatar
I would be to objective and not make the right choices. Thus I need to hire outside help (Halliburton, don't know where I'm going with this...) to do the work. Go ahead and color my world!!
DrPainMD is offline
Old 08-28-2008, 01:06 PM
DLP-Lag's Avatar
First thank you for anyone who cares to reply. I hope I am placing these questions in the right place. I will shortly build a home, and I'm in the planning stages of a doing a nice setup in my family room which is 19X13. The room is connected to a wide open kitchen and nook.
The only part I am decided on at the moment is to recess the new 1080p 52 inch LCD Sammy 750 based on my research here, with the typical recessed speakers around it. My first question is because of the open house lay out, can the 2 or 3 rear speakers be ceiling mounted? Am i compromising something here with the rears by doing this?
From a design standpoint, my next question is I don't want the equipment in the same room. Does an IRC remote solve this issue? The wall bordering this room is the garage where I can have all the equipment on shelves.
And last does anyone have any links that is dedicated to flat panel decor and design?
I saw a few of the galleries but really want to go the distance and I was hoping someone knew of a designer or place where I can check out multiple setups and designs.
My fear is not knowing what to do around the TV and the speakers.
Thank you again
B
DLP-Lag is offline
Old 10-08-2008, 01:40 PM
bigbadbob's Avatar
Thanks for the great thread. Very helpful!
Klipsch Rocks!
bigbadbob is offline
Old 11-10-2008, 02:09 PM
AvGeek07's Avatar
is anyone gonna update this sticky? I notice that new gear that is out now that has new sources. Like,eq,hdmi etc.
AvGeek07 is offline
