Setting Up Your Home Theater 101 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #181 of 205 Old 08-03-2011, 02:58 PM
Meetloaf13's Avatar
Quoted: 52 Post(s)
Mucho respect for all the work put in here.
Thank you for your time!
Samsung JU7100 75" 4K | Denon x2300 | Oppo UDP-203 | Pioneer Andrew Jones 5.0.2 | Klipsch Sub-12HG
Meetloaf13 is online now
post #182 of 205 Old 09-23-2011, 12:14 PM
jlaavenger's Avatar
Quoted: 25 Post(s)
I need some help. I finally but a Receiver for my Pioneer 111fd and I'm not sure how to hook it up. Right now all my HDMI connection go straight to the TV and I use the TV's side speakers and an external sub. TV goes through a Dish 722VIP DVR. I also have a PS3 and X-Box 360 also connected through HDMI. So when I enter the Onkyo TX-nor709 Receiver into the mix all of the HDMI connection will connect to the receiver instead right? Leaving only one HDMI from the receiver to the TV right? So if that's correct then which HDMI input do I use? 4, 5, 6 or 7? The Sub also now connects to the receiver instead of the tv right? Does this mean the receiver has to stay on 24/7 to watch TV?
Does it mean the TV speaker get disconnected and that basically the only TV input connection I will use is one HDMI input and that's it?
jlaavenger is offline
post #183 of 205 Old 09-23-2011, 07:08 PM
centauro74's Avatar
You can use the HDMI Pass-through for the DVR, so you can watch and listen on the tv only without turning on the receiver.
centauro74 is offline
post #184 of 205 Old 12-18-2011, 07:01 PM
marz2max's Avatar
Hi all, sorry if I am posting this in an incorrect thread however I need help and I'm taking a stab at it. I have a Denon AVR 1312 reciever and I just bought a house that has (2) two outdoor Polk audio speakers on the deck and I have a 5.1 system in the living room. All the speakers work, I have tested them personally. I want to be able to hook up the (2) two outdoor deck speakers (which are run with speaker wire into the living room so i know the previous owner had them hooked up to his surround sound system) to the Denon AVR 1312 and turn them on when I want. Obviously this is possible or the previous owner wouldnt have had the hook up done but HOW??!!
Thank you very much!
marz2max is offline
post #185 of 205 Old 12-19-2011, 07:46 AM
steven_jc's Avatar
Looking for some help/advice. I just bought a new 50" HDTV and am looking to hook it up to my Cable, DVD and Receiver. The TV has 4 HDMI ports and my DVD has one HDMI port, but my receiver is a bit older (8 years maybe) and does not have HDMI connections. I want to use HDMI for the ease and "cleaner" signal/connection but also want to use my tower speakers and sub for better audio. Would I be able to connect my TV to my cablebox via HDMI and then use audio components to hook to my receiver. Similarly, I'd like to use HDMI from my TV to DVD. Could I then use optical to connect the DVD to my receiver for sound. I assume by doing so, I would get sound out both my TV and receiver. Would the above scenario work? Does it even make sense?? I'd rather not have to spend the money on a new receiver (need to save after my TV purchase) and would prefer the better/cleaner signal coming from HDMI vs. component. Any advice would be great! Many thanks!!
steven_jc is offline
post #186 of 205 Old 12-20-2011, 12:11 PM
Zag in AZ's Avatar
Just a guess here, but the prior owner probably had a dual zone receiver (2 amps - also called a 7.1 system), with one zone being the 5.1 system in the living room and the 2nd zone being the Polks, or at least a receiver with A/B speaker outputs. The 1312 has only one amp, does not support dual zone, and does not have A/B speaker outputs.
Your options:
1. You can buy a speaker splitter at Radio Shack and run the front output to the splitter, which you then would continue one set on the your fronts and one set to the Polks. That will allow you to run the fronts and turn the outside on/off when you want. The Polks will only play what the fronts are playing, so if you are watching a game, you may not get full dialogue, etc...
2. Upgrade the receiver to one that has A/B speaker output. May have the same issue as 1. for what you hear.
3. Upgrade the receiver to on that has dual zone (7.1 w/ 2 amps). 7.1 receivers can either be run in a dual zone setup, where the 2nd amp is assigned to another set of speakers outside of the main zone, or assign the amp to power the rear surround speakers in a 7.1 setup. In the Denon line you'll have to jump up to the 1712. This will allow you to watch a movie on the 5.1 system and listen to the radio/iPod/Pandora outside.
4. Buy another receiver to run the Polks. You'll have to deal with hooking up components to multiple receivers though.
Hope this helps.
Zag in AZ is offline
post #187 of 205 Old 12-21-2011, 09:59 AM
marz2max's Avatar
Your options:
Hope this helps.
Thank you for the detailed response. I really appreciate it. Guess I should have done my homework before I bought something. I'll take your advice.
marz2max is offline
post #188 of 205 Old 01-23-2012, 07:41 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Wrong thread
JHAz is offline
post #189 of 205 Old 04-13-2012, 12:55 PM
raffi526's Avatar
I have a few questions regarding setting up a system. I purchased the Jamo S606 HCS3 speakers, which to me is a steal as far as HT speakers. I also got as a present a Klipsch KSW-10 Subwoofer. First, I would like to know everyones opinion if I made the right decision as far as speakers and Subwoofer. Second, when I connected the subwoofer via monster cable. I connected it from LFE lin-in, to the Subwoofer Pre-Out on my Onkyo receiver. However, I am not able to manually increase the bass or 'crossover' as you call it. It seems that the subwoofer or the receiver seemed to automatically set the frequency. I read that it might be due to the LFE connection. Can I bypass that?
raffi526 is offline
post #190 of 205 Old 04-14-2012, 03:48 AM
liefpj's Avatar
i'm not a spammer, gotta write 3 posts
liefpj is offline
post #191 of 205 Old 04-14-2012, 03:49 AM
liefpj's Avatar
liefpj is offline
post #192 of 205 Old 04-14-2012, 03:50 AM
liefpj's Avatar
1 post
liefpj is offline
post #193 of 205 Old 04-14-2012, 03:53 AM
Super Moderator
markrubin's Avatar
Quoted: 1302 Post(s)
Liked: 2797
Originally Posted by liefpj View Post
1 post
will you be posting any content?
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #194 of 205 Old 04-14-2012, 09:36 AM
Intelletto's Avatar
i wouldn't have imagined there was so much intricacy in setting it up though, nice post it was def helpful
Intelletto is offline
post #195 of 205 Old 09-03-2012, 03:15 AM - Thread Starter
DrPainMD's Avatar
Liked: 27
bump o matic
super dirty , super clean , pow
DrPainMD is offline
post #196 of 205 Old 09-06-2012, 08:58 AM
swarm87's Avatar
Quoted: 141 Post(s)
Liked: 106
if your SW has left and right inputs do you need to use a splitter to split the signal for use on both terminals or is just using one ok?
pcm=potato
bitstream=patato
swarm87 is offline
post #197 of 205 Old 09-06-2012, 09:36 AM
underminded999's Avatar
Quoted: 29 Post(s)
You can go either way.  If you only use one, most likely use the Left.  However, I have read that if you use both(which what I do, with a Y connector) that you will gain a few DB's with Gain.
I do not know if this is true, but I like the look of using both, and I am perfectly happy with the  splitter and the sound.
underminded999 is offline
post #198 of 205 Old 09-08-2012, 11:32 AM
trosell14843's Avatar
awesome thanks! sticky!
trosell14843 is offline
post #199 of 205 Old 09-09-2012, 11:56 PM
teckademic's Avatar
Quoted: 107 Post(s)
Liked: 114
hoping this is the right place to ask, but I currently have 4 bass traps to use and was wondering if it would be best to place one in each corner or two stacked in the front or rear of the room?
teckademic is offline
post #200 of 205 Old 09-10-2012, 02:14 AM
yaomizzle's Avatar
Liked: 27
So much info
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
post #201 of 205 Old 01-14-2013, 10:50 AM
eaamon's Avatar
Quoted: 74 Post(s)
Liked: 27
hi, dr painMD was looking at the WOW disc for HT set up. I noticed there was nothing listed for
amateur HT set up guides. I know there are several forums for each individual monitors. but
after viewing the disney WOW disc at amazon I noticed you do not have any Picture quality listing.
I do not know how many discs or even maybe on-line free down-loadable set up assistants there are.
I send many noobees here to get started. just though I would suggest it.
eaamon is offline
post #202 of 205 Old 01-14-2013, 11:00 AM
eaamon's Avatar
Quoted: 74 Post(s)
Liked: 27
sorry just noticed there is one under software, the DVE video.
maybe it would be a good place to ad the WOW too, as they
have a set up procedure for speakers.
eaamon is offline
post #203 of 205 Old 05-18-2014, 03:19 AM - Thread Starter
DrPainMD's Avatar
Liked: 27
bump
DrPainMD is offline
post #204 of 205 Old 10-19-2014, 12:57 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 791
Dr Pain;
are you going to re-do post#1 sometime soon?
It's starting to show it's age....
mtbdudex is offline
post #205 of 205 Old 10-20-2014, 02:41 AM - Thread Starter
DrPainMD's Avatar
Liked: 27
Dr Pain;
nope
DrPainMD is offline
