"Acoustic" popcorn ceilings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-28-2007, 05:33 AM - Thread Starter
hdmi4ever's Avatar
Quoted: 18 Post(s)
Why are popcorn ceilings often called "acoustic ceilings"? Do they have acoustically absorbent or diffusive properties?
Yes, the place I moved into last year has popcorn ceilings, even though it was built only about 4 years ago.
hdmi4ever is offline
post #2 of 8 Old 03-28-2007, 09:20 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
No, a typical popcorn ceiling is acoustically identical to a flat painted ceiling. There might be a tiny amount of diffusion at 30 KHz though.
--Ethan
Ethan Winer is offline
post #3 of 8 Old 03-28-2007, 09:08 PM
jwatte's Avatar
There is a special kind of popcorn texture which is made from acoustically absorptive material, and which will absorb some part of the first-bounce of mid-to-high frequencies. You can't paint those ceilings, though, or they'll lose their quality. Basically, it's a lamer, different-looking version of ceiling tiles. It's not going to do anything to control boominess in a room.
However, if your house has painted popcorn, it's not the acoustical kind, and it's not going to do anything at all, as Ethan says.
jwatte is offline
post #4 of 8 Old 03-28-2007, 11:30 PM
Soybean's Avatar
That's disappointing. Thankfully I don't have them in my current house, but I used to have them in my condo. Now I know that besides looking ugly and dated, they were also useless.
Soybean is offline
post #5 of 8 Old 03-29-2007, 04:56 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
Yes, not all popcorn ceilings are not created equally. They can absorb sound. But there is a lot of variation, and the materials used to obtain the texture has changed over the years. Perhaps the most effective ones were made with asbestos!
- Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #6 of 8 Old 02-25-2012, 08:40 AM
DoctorM's Avatar
Quoted: 652 Post(s)
Liked: 198
I'm going to revive this dead thread.
I currently have popcorn ceilings in my place. A flood has caused much damage and the insurance will be replacing them.
I've read that the more common replacement, knockdown, causes sound to travel through a place much more than popcorn ceilings do.
If not all popcorn ceilings are equal, can anyone recommend a type that does have favorable properties?
I don't want to put knockdown in and have my sound suddenly muddy.
DoctorM is offline
post #7 of 8 Old 02-25-2012, 10:36 AM
Quoted: 264 Post(s)
Liked: 359
I never heard of knockdown, but Google showed me some photos of a slightly textured ceiling. None of these slight textures have any acoustical effect at all. Not even a little. So do whatever you think looks better.
--Ethan
post #8 of 8 Old 02-25-2012, 11:54 AM
rdgrimes's Avatar
Quoted: 1992 Post(s)
Liked: 1320
Once painted, any small differences between textures are moot. The diffraction offered by different textures might be a factor, but again a very small one.
Given the issues presented by "popcorn" type textures, which have just been demonstrated following water damage, it's hardly worth messing around with.
A few absorption panels attached to the new ceiling would offer a great deal more benefit. But, if the rest of the room is adequately treated, it's still a relatively small benefit. Worrying about just one of six surfaces is mis-directed energy.
rdgrimes is offline
