Onkyo Receiver Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-29-2007, 02:57 PM - Thread Starter
plat_spirit's Avatar
Sorry to get attention but I have a onkyo 504 receiver. I have a RS meter attempting to calibrate my Surround. What volume indication is 75 db? Zero on the receiver is no sound. Do I just increase volume to 75 and calibrate from there?
v.y.
Say Wha Wha....
plat_spirit is offline
post #2 of 5 Old 03-29-2007, 04:34 PM
mel22b's Avatar
yup. if you are trying to balance the speakers, that is what you do.
Once you set a volume, just make sure the sound meter shows the same for all the speakers.
Some people run there center channel a bit higher (+1 or 2) and others the sub a bit higher. Personal preference.
When I did mine I was surprises how far off my auto setup was with my rears.
Stephen
My Setup
mel22b is offline
post #3 of 5 Old 07-21-2014, 07:56 AM
Liked: 0
i have a onkyo Tx- er600 need to find out why it turns on and then right back off
lambow1 is offline
post #4 of 5 Old 07-21-2014, 08:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Remove all cables but the power cord and see if it still turns off right after you turn it on. If so, it is seriously broken and needs repair.
If not, check your speaker wiring. Add it back a pair at a time until the receiver starts failing. The last line added is probably shorted.
arnyk is offline
post #5 of 5 Old 07-21-2014, 11:28 AM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
v.y.
You have two options for volume reading. Absolute (0-100) and relative (-80 dB or so up to 0 dB and a bit more like +15-18 dB). Look up the Manual of your AVR for details on setup.
When you have set you volume reading to relative the 75 dB SPL (Sound Pressure Level) should correspond to -30 dB MV (Master Volume) setting. Hope this helps.
mogorf is offline
