Which speaker wire is +, which -? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-31-2007, 02:05 PM - Thread Starter
Rossco04's Avatar
I'm hooking up an aiwa xr-m200u shelf system. The speakers are connected by a plug in cable for high freq and regular speaker wire for the low freq.
My question is which wire goes to the red and which to the black?
one wire has nothing written on it. The other has long gray bars on it, about a quarter inch in length. Generally speaker wire i've had in the past has the positive w/ some kind of + mark on it. I've never seen the negative marked before though. Is this a negative sign or just a marking to signify the positive wire?
Does it even matter?
Ross
Rossco04 is offline
post #2 of 15 Old 03-31-2007, 02:29 PM
Kevin12586's Avatar
It is up to you, whichever you insert into the + port on your Aiwa goes into the + port on the speaker. Using the marking on the wire you will be able to tell which one you used for + and -.
Kevin12586 is offline
post #3 of 15 Old 03-31-2007, 02:29 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
It doesn't matter as long as the wires are "matched" on each end. So, use the "marked" wire as + (red) and "unmarked" - (black) on each end.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #4 of 15 Old 03-31-2007, 02:32 PM
whoaru99's Avatar
Liked: 69
Ross
This is what the manual says -
"Connect the speaker cord with the white stripe to the
SPEAKERS LOW FREQ + terminal and the black cord
to the - terminal."
If all else fails, use a small battery like a AA, C, or D cell and momentarily connect the speaker wires to it. As you make the connection, observe the movement of the woofer cone, when the cone moves out, the wire touching the + terminal of the battery is the positive lead. If the cone moves "in" on the first try, reverse the wire and try it again - that way you can see the difference.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #5 of 15 Old 03-31-2007, 02:37 PM
whoaru99's Avatar
Liked: 69
Yeah, but looking at the manual, it seems they are hard wired on the speaker end.
whoaru99 is offline
post #6 of 15 Old 03-31-2007, 02:42 PM - Thread Starter
Rossco04's Avatar
Thanks for your input guys.
Yeah it is hard wired and I can't see through the backing plate that the wires go through.
I lost my manual and couldn't find one online. Where did you find it?
Thanks again. I appreciate it.
Rossco04 is offline
post #7 of 15 Old 03-31-2007, 02:52 PM
whoaru99's Avatar
Liked: 69
Here is the link. It was on the Aiwa website in the product support area.
whoaru99 is offline
post #8 of 15 Old 03-31-2007, 03:27 PM
sivadselim's Avatar
Quoted: 269 Post(s)
Liked: 227
Even if they're "hard-wired" on the speaker end, it still doesn't matter what is used as the (+) and (-) as long as it's done identically for both speakers.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #9 of 15 Old 03-31-2007, 04:07 PM - Thread Starter
Rossco04's Avatar
True, but the problem I have is I can't see inside the speaker cabinet, so I can't tell how they are wired up.
Rossco04 is offline
post #10 of 15 Old 03-31-2007, 06:01 PM
maxcooper's Avatar
Since one speaker has a plug, and thus offers no control over which is + and -, it probably is somewhat important to plug the low freq speaker(s) in with the correct polarity to match (to avoid cancellation from reversed polarity near the crossover freq).
-Max
maxcooper is offline
post #11 of 15 Old 03-31-2007, 07:53 PM
sivadselim's Avatar
Quoted: 269 Post(s)
Liked: 227
It doesn't matter as long as you use the same convention for both speakers. So pick which wire, marked or unmarked, you want to be (+) and which you want to be (-) and connect both speakers to your receiver's (+) and (-) terminals accordingly.
BTW, the FAQ in the link that someone gave you says to use the marked cord for (+) and the unmarked for the (-). But again, it doesn't matter, as long as you connect the speakers identically.
post #12 of 15 Old 03-31-2007, 07:53 PM
sivadselim's Avatar
Quoted: 269 Post(s)
Liked: 227
-Max
Huh?
post #13 of 15 Old 04-01-2007, 01:57 AM
maxcooper's Avatar
Huh?
From the OP: "I'm hooking up an aiwa xr-m200u shelf system. The speakers are connected by a plug in cable for high freq and regular speaker wire for the low freq."
He has no control over the polarity of the HF speakers, since they have a plug. So he does need to be careful with the polarity for the LF speaker(s), so that he doesn't get cancellation (between the HF speakers and the LF speaker(s)) in the crossover frequency region.
-Max
post #14 of 15 Old 04-01-2007, 03:28 AM
whoaru99's Avatar
Liked: 69
Huh?
Perhaps a biamped setup...
Regardless, maxcoopers previous post explains why it does matter in this case.
Besides, who could stand to know their speakers were wired backwards (assuming both speakers, that is)?
whoaru99 is offline
post #15 of 15 Old 04-01-2007, 08:52 AM
sivadselim's Avatar
Quoted: 269 Post(s)
Liked: 227
OIC Sorry.
What a weird setup.
In that case, follow the directions exactly as they're written on page3 of the manual.
