Can I plug 2 rear surround speakers into my 1 rear surround port on my stereo? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-10-2007, 02:15 PM - Thread Starter
drunkpenguin's Avatar
Quoted: 1145 Post(s)
Liked: 1090
I'd like to have 4 surround speakers, will it hurt anything if I join 2 speakers into 1 speaker jack?
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is online now
post #2 of 9 Old 06-10-2007, 02:51 PM
jlcool007's Avatar
depending on how you wire the speakers, (parallel or series) it will affect the resistance that the receiver sees. The power each speaker sees will be cut in half... just get another cheap amp to run the 2nd set...using the pre-am,p from the reciever to send the same signal to the back
jlcool007 is offline
post #3 of 9 Old 06-10-2007, 03:24 PM - Thread Starter
Liked: 1090
I would wire them parallel and could adjust the volume accordingly. Is this bad for the speakers or the receiver? If so maybe I'll just run 1 back there.
post #4 of 9 Old 06-10-2007, 05:39 PM
whoaru99's Avatar
Liked: 69
No real concern for the speakers, but the receiver could be an issue. It depends on how well it handles 4 ohm loads - assuming two 8 ohm speakers in parallel, that is.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #5 of 9 Old 06-11-2007, 05:02 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
You can also buy a transformer which has an 8 ohm primary winding for the receiver and dual 8 ohm secondaries for the two speakers.
- Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #6 of 9 Old 06-11-2007, 09:41 PM
stevdart's Avatar
If in doubt, wire in series. I'd wire series without a second thought. Your amp will easily drive the 12 - 16 ohm load and the little bit of volume correction can be made with the amplifier's settings.
stevdart is offline
post #7 of 9 Old 06-12-2007, 01:55 PM
ChrisWiggles's Avatar
Yeah you can do this, if in parallel the impedance drops. IF you have a competent receiver it shouldn't be a problem unless your rears are already low impedence speakers. I've done this before with no problem. Especially with rear backs there's usually not much going on back there anyway.
But you didn't mention the receiver or the speakers, so hard to say...
ChrisWiggles is offline
post #8 of 9 Old 06-12-2007, 06:49 PM - Thread Starter
Liked: 1090
The receiver is a kenwood VR 7080
The speakers in question Yamaha NS-5290. That is if I can find 2 more to match my existing 2. If I can't find em (so far I cant) then I'll buy 4 of something new. What kind of speakers would I look for knowing what I want to do with them?
post #9 of 9 Old 06-12-2007, 07:03 PM
jeffleonard's Avatar
Just wire them in a series.
You'll be fine.
jeffleonard is offline
