Help with multi-zone setup - AVS Forum
post #1 of 5 Old 06-26-2007, 12:17 PM - Thread Starter
rocksolidsr's Avatar
I'm trying to setup a multi-zone system using a Onkyo TX SR674 with 6 8 ohm speakers, 4 of the speakers are in the house and 2 of them are outside, I would like to have separate volume control for the two sets the 4 inside, and 2 outside. My question is do you think the Onkyo receiver could power these speakers (the speakers are 75 Watt max), and how should I wire this all together. I attached a picture of what I was thinking...
i186[dot]photobucket[dot]com/albums/x222/rocksolidsr/wiringdiagram
copy and paste that address into your browser and add .jpg on the end and replace [dot] with .
[IMG]wiring diagram.bmp[/IMG]
rocksolidsr is offline
post #2 of 5 Old 06-27-2007, 12:46 PM - Thread Starter
anybody?
post #3 of 5 Old 06-27-2007, 08:44 PM
ross's Avatar
You need to be careful when you do this as the volume control if placed between the speakers and the receiver will alter the impedance which the receiver sees. This may or may not be a problem depending upon the impedance curve of the speakers, for one thing. In general, you should be fine. Look for a volume control which doesn't change the impedance (resistance) if there is such a thing.
I assume that you have a "second zone" setting on the receiver so that you don't have to play the same thing everywhere. I am not familiar with that particular receiver, but I'd look to see if there isn't a second volume control for a second zone which would be a much better choice. I have a Denon which works exactly that way.
Rgrds-Ross
ross is offline
post #4 of 5 Old 06-29-2007, 08:52 AM - Thread Starter
thanks for your response
I have looked at volume controls that have impedance matching is that what I would need?
post #5 of 5 Old 06-30-2007, 03:55 AM
ross's Avatar
Yes those are the ones you want. Simple volume controls put additional resistance between the speakers and the amp and that's not good for the amp. With those in place you should have no trouble at all. Make sure that they're rated for the amount of power (watts) you plan to put through them. That's why you're better off just enough power to make a loud sound in the first place.
Rgrds-Ross
ross is offline
Reply Audio theory, Setup and Chat
User Tag List
