Spring Clip Terminal & banana plugs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-04-2007, 01:03 PM - Thread Starter
id24601's Avatar
I picked up an Onkyo R-340 receiver a little while ago. It uses spring clips for its speaker connections but I would prefer to use some kind of plug instead of just bare wire. Does anyone know if these banana plugs from monoprice would fit OK? Or would I have to try to find some kind of thinner plug (in Canada)?
http://www.monoprice.com/products/pr...ormat=2&style=
id24601 is offline
post #2 of 5 Old 11-04-2007, 01:16 PM
Jonomega's Avatar
i think the spring clip will crush and damage the banana plug, I would go with what is called "pin" termination.
example 1
Jonomega is offline
post #3 of 5 Old 11-04-2007, 01:54 PM
sivadselim's Avatar
Quoted: 159 Post(s)
Liked: 154
It's not that the spring clip would "crush" a banana; a regular banana won't even fit in the holes.
The connectors Jonomega linked will work, however I know from experience that spring-clips actually DO crush those, eventually either unravelling them, breaking them off, or both.
Something like THESE or THESE will work better.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #4 of 5 Old 11-04-2007, 05:04 PM
Jonomega's Avatar
Yeah, i really wanted the solid pins not the flex ones. I tried searching for a few minutes, but couldnt find them. Thanks!
Jonomega is offline
post #5 of 5 Old 11-04-2007, 06:43 PM - Thread Starter
id24601's Avatar
Thanks for the advice.
Monoprice doesnt seem to have that type. Ill check at Sayal and see if they carry something like that. If not, well its only for convenience. Anything over $2 a pair is not worth it IMO.
id24601 is offline
