Save power in your home cinema - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 02-08-2010, 11:10 AM - Thread Starter
TelevisionsFlo's Avatar
Home cinemas can produce annual energy bills that run into the hundreds but it's not always the obvious offenders that do the most damage.
Turning off your TV at the socket might only save you a couple of bucks each year, while the hidden consumers continue to draw tens of watts without the user realising.
Chargers and power supplies are especially worth keeping an eye on: Many people don't realise that the transformers used in these will keep drawing approximately the same amount of power, whether or not the actual device is switched on.
Satellite receiver systems and active subwoofers are another one to watch, since both are often hidden away out of sight, out of mind. According to our example calculations, switching the entire home cinema off at the socket can reduce the amount of power wasted by around 80 percent.
But where else are there savings to be made? One option that people mightn't think of immediately is to calibrate their TV. In our tests, we reduced the TV's annual power consumption by 20 percent.
You can also choose a TV with power saving in mind new technologies such as LED backlights and local dimming mean TVs now consume far less power than their predecessors.
Never trust the power-consumption values in the manufacturer's specifications. Although the standby power consumption is now limited by (european) law to one watt, and this value can therefore be trusted, manufacturers still try all kinds of tricks to make the operating power consumption seem lower. As with all such measurements, it's best to rely on independent reviews.
Read more about reducing your home cinema's power consumption in Televisions.com's article Power-Saving TV Technologies.
Please let us know when you have additional tipps to save power in hometheaters.
Florian Friedrich,
CEO of www.avtop.com, journalist from munich, germany. Co-founder of www.Quality.TV, a joint project for UHD test- and demomaterials together with Joe Kane.
TelevisionsFlo is offline
post #2 of 21 Old 02-09-2010, 05:19 AM
docrings's Avatar
From my testing using a Kill-a-watt meter, most of my transformers drop to near zero power consumption without the electronic device pluggged into it... just my experience.
I had my entire home theater system power conditioner/UPS plugged into my Kill-a-watt meter.
The readings were:
1094 total hours monitored
71.03 kwh total used.
So, in the 1094 hours (or 45 days) I used about $7.00 of electricity.
That is about $5 a month for a 61" LED RPTV Samsung, PS3 for blu-ray, Xbox 360 for gaming, a Harmon-Kardon HK635 5.1 amplifier and a monster power conditioner. The only thing not plugged into the meter was my SVS subwoofer..
Doc Rings
Home cinemas can produce annual energy bills that run into the hundreds — but it’s not always the obvious offenders that do the most damage.
Chargers and power supplies are especially worth keeping an eye on: Many people don’t realise that the transformers used in these will keep drawing approximately the same amount of power, whether or not the actual device is switched on.
Satellite receiver systems and active subwoofers are another one to watch, since both are often hidden away — out of sight, out of mind. According to our example calculations, switching the entire home cinema off at the socket can reduce the amount of power wasted by around 80 percent.
But where else are there savings to be made? One option that people mightn’t think of immediately is to calibrate their TV. In our tests, we reduced the TV’s annual power consumption by 20 percent.
You can also choose a TV with power saving in mind — new technologies such as LED backlights and local dimming mean TVs now consume far less power than their predecessors.
Never trust the power-consumption values in the manufacturer’s specifications. Although the standby power consumption is now limited by (european) law to one watt, and this value can therefore be trusted, manufacturers still try all kinds of tricks to make the operating power consumption seem lower. As with all such measurements, it’s best to rely on independent reviews.
Read more about reducing your home cinema’s power consumption in Televisions.com’s article Power-Saving TV Technologies.
docrings is offline
post #3 of 21 Old 02-09-2010, 04:49 PM
golffnutt's Avatar
Quoted: 85 Post(s)
In your statement above, "switching the entire home cinema off at the socket", are you suggesting that I/we unplug every electrical component from the wall socket when we are not watching/listening to it?
Thank you.Golffnutt"GO DAWGS" !!!!!!!!!!!!!!Panasonic PT-AE 8000U Projector with 10' Screen // Samsung 65" TV UN65KS9500F // Denon X6200W Receiver // Oppo 203 4K Player // Pioneer Elite BDP-05FD Blu-Ray Player (Great CD Player and Excellent Blu-Ray Player) // PSB 9.2 speaker setup with 2ea. M&K 12" Subs // Panasonic Surge Protector // Monoprice Premium Cabling
golffnutt is offline
post #4 of 21 Old 02-10-2010, 03:05 AM
SlackerX's Avatar
If you installed some x10 or other home automation devices that have either IR or RF control, you could use a universal remote to turn off all appliances or devices that are plugged into various outlets in the home. You could also utilize them for turning on/off and dimming lights as well as other useful tasks.
There's a fairly rich forum right here on AVS that discusses all sorts of things related to automating the home theater. These devices themselves are also very low power. An alternative to using a remote could be making sure that everything that doesn't require constant power is connected to a switched outlet so you could just make sure to turn off the switch when the devices are not in use.
Here's the link to the AVS home theater automation forums. It's a very good resource: http://www.avsforum.com/avs-vb/forumdisplay.php?f=10/
SlackerX is offline
post #5 of 21 Old 02-11-2010, 04:41 PM
irfan's Avatar
Or you could flip the switches on the surge protectors
irfan is offline
post #6 of 21 Old 03-07-2010, 08:18 AM
Fabricator's Avatar
Quoted: 30 Post(s)
i always turn mine off. in case of lightning etc.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
post #7 of 21 Old 03-07-2010, 11:24 AM
mjg100's Avatar
I don't think you can use x10 for amps. I buy mechanical relays and build them into short extension cords or power strips and use those. I need them because I use pro amps that do not have a remote control option and my equipment is in a rack in a mechanical room on another floor. I just built another one last Friday. The relay cost $2.50 plus $1.50 for shipping (I bought 3 so I prorated for 1). I bought a box for it for $3.21. I already had a piece of 12 gauge extension cord, romex clamps, old two prong power cord and female plug. So was able to built a switched outlet for $8.21. The relay is 120 volt activation so you can plug it into the switched outlet on your AVR and use it to power another outlet or another power strip.
In my rack I have three pro amps, two HT amps, AVR, TV tuner, DVD player and a remote control eye. The only items in stand by power mode are the remote control eye and the AVR. Everything else is off until the AVR is powered on.
mjg100 is offline
post #8 of 21 Old 03-21-2010, 12:50 PM
kateross's Avatar
The tips above are very useful. Thanks a lot.
kateross is offline
post #9 of 21 Old 03-22-2010, 04:25 PM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1685 Post(s)
Liked: 924
Send a message via Skype™ to CINERAMAX
Don't buy a digital cinema xenon based projector should be tip number one if you are conscious of your carbon footprint.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is online now
post #10 of 21 Old 05-10-2010, 04:58 AM
darren111's Avatar
do you have a forum or can you share a post where i get the information about what to do in high voltage or over voltage condition or a spike in voltage.
darren111 is offline
post #11 of 21 Old 05-10-2010, 10:06 AM
duvetyne's Avatar
Where does all the energy go when it's switched off, yet stll "consuming the same amount of power"?
duvetyne is offline
post #12 of 21 Old 05-12-2010, 01:28 PM
apexdown's Avatar
Mostly turned into heat via resistance. Though that's the well designed equipment some manufactures are much worse. I remember reading about a plasma screen that used around 200 watts when turned off.
apexdown is offline
post #13 of 21 Old 05-13-2010, 03:12 PM
duvetyne's Avatar
No, when something is turned off it doesn't consume the same amount of power as when it was on. Lightbulbs would never go dark....that's magic!
duvetyne is offline
post #14 of 21 Old 05-14-2010, 08:43 PM
vanslide's Avatar
It's true that lightbulbs don't use any power when turned off because the switch would eliminate all current, but I have tested transformers that can use almost the same power without the unit being turned on. For example, chargers, modems, routers, landline phones, etc. Basically anything with the big box that plugs into the wall. Your tv, recievers, amps, subs would likely also have internal transformers. Most of these still use around 5-10 watts even when off. And if you touch them you can feel a bit of heat that is essentially wasted energy. Some units are worse than others. Newer units tend to target 1-2 watts.
However, if I saw a TV that was using 200 watts while off I would seriously question if it was a defective unit.
vanslide is offline
post #15 of 21 Old 05-27-2010, 01:42 PM
Alanp's Avatar
Good ideas, but in my main system when turned off, the largest power draw is the DVR at over 30 watts! And there's really no way to cut it's power, since I need it making it's timed recordings.
Alanp is offline
post #16 of 21 Old 05-27-2010, 05:39 PM
duvetyne's Avatar
You must have tested one that had a load connected or was faulty.
duvetyne is offline
post #17 of 21 Old 05-28-2010, 04:49 AM
Austin Kort's Avatar
True fact. I always switch off mine. Saving electricity is a must.
Austin Kort is offline
post #18 of 21 Old 07-08-2010, 09:23 PM
pinseeker's Avatar
great thread, very informative.
pinseeker is offline
post #19 of 21 Old 07-13-2010, 07:55 PM
Cap'n Preshoot's Avatar
The kill-a-watt meter (about $25 or so) was the best investment I ever made! With it I discovered that our entire home theater system (MITS 65" RPTV, Wii, Yamaha tuner-amp, Sub, blu-Ray and 1400-va Tripp-Lite UPS) pulls 80 watts with everything "turned off". The big TV stays on an average of 12 hours every day and with all combined was pulling 475 watts! The major energy pig is the RPTV itself, so we're looking for a buyer and planning to replace it with a 55 or 60" led backlit set and already have a very small UPS to hold just the Sat DVR through brief interruptions of 15 mins or less, just to avoid those nuisance power bumps. Not there yet, but our goal is to cut HT consumption by 50% when viewing (all day) and to cut standby/off consumption by at least that same amount. The big RPTV also generates a LOT of heat.
The problem that arises for Comcast/Xfinity is that they allow the mode of improvement to get in the way of actually improving.
Cap'n Preshoot is offline
post #20 of 21 Old 07-16-2010, 08:53 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
I shut all the HT breakers at the electrical panel when not in use.
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #21 of 21 Old 07-18-2010, 01:29 AM
Troopa's Avatar
My fat PS3 draws up to 40w when idle
Im guessing its so that Bluethooth can still bring the unit out of standby
Tom
Troopa is offline
Reply Community News & Polls
