If One Sub is Good, Are Two Better? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 129 Old 05-02-2011, 10:48 PM
m. zillch's Avatar
Quoted: 1974 Post(s)
Liked: 1263
If you listen to music/movies using a crossover of 80Hz or lower it's called "bass imaging imagining".
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #122 of 129 Old 05-03-2011, 03:08 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Originally Posted by hometheaterguy View Post
Three subs placed assymetrically, (staggered unequally in the room) are best to reduce standing waves and provide "bass imaging" and increase headroom and bass you can feel. In a tri-sub system, the LFE is more dedicated to the munition fire, space shuttle, 50cal bass. The the left and rights provide bass AND bass imaging.
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
I disagree with that. I find that two subs playing the normal bass, should be symmetrical to the centerline of the room. The LFE sub can be placed elsewhere, for max output, depending on the room.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #123 of 129 Old 05-03-2011, 09:02 AM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
Not that I'm an expert, but I believe that there's a significant body of research saying that <80Hz is not localizable. So in general I agree with you guys.
I doubt the research involved IB's with 12Hz response like some have around here, which I could see changing the equation some. However I'd still love to see blinded trials, taking the "I can tell bass direction" folks blindfolded into unfamiliar rooms and seeing if they can point to its location from the listening chair.
Experience wise, I can tell you that in my room I am 99+% sure the bass direction is not perceptible. However my subwoofers are fairly near my L/R, and their image is also very near the C. I'd guess that my setup would be very strong on the "steering" effect that is intended from the LCR even if there were any hint of bass direction information available psychoacoustically.
aackthpt is offline
post #124 of 129 Old 05-03-2011, 01:10 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
For playing music on a sat/sub system, if the sub(s) are not near (along the front wall) the L/R mains, then you have to make sure the phase is the same as the L/R, or the sound will be disjointed, as if it (they) is in the rear of a room.
4DHD is offline
post #125 of 129 Old 05-03-2011, 01:37 PM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 88
I'm not the expert. I thought you basically daisychained your subwoofers to the LFE output... when using an AVR like my SC-05?
See My System Here
Processor: Emotiva XMC-1
R/C/L Amps... (3) Emotiva XPR-1's (1750w x 3 = 5250w)
Surround Amps: Emotiva XPA-5 G2 (200 x 4 = 800w) not using 5th
Zone 2: Emotiva Mini-X a-100 driving 2 Boston Acoustics Voyager 70's
10050 watts total power.
mhrischuk is offline
post #126 of 129 Old 05-03-2011, 03:14 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
There are many ways to connect subs. When I was using 3 subs the two 15" were receiving the normal bass signal. The third sub was getting the LFE Channel.
When I moved to SA, I only brought the two 15" and I still have the main L/R speakers mounted to them. But right now I'm only running MCM, no theater, so no LFE, right now.
4DHD is offline
post #127 of 129 Old 05-03-2011, 07:10 PM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 88
Were do you get your signal for the two running on normal bass signal?
See My System Here
post #128 of 129 Old 05-04-2011, 01:46 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I use a Parasound P7 pre-amp, which has analogue bass management for two channel sources. For the MCM from the multi disc player provides bass management.
One can also run a full range signal to a sub using speaker wire and set the LP filter on the sub XO to 80 or whatever works best. Before MCM and AVRs with BM, that is how all subs were connected.
4DHD is offline
post #129 of 129 Old 05-04-2011, 07:16 AM
m. zillch's Avatar
Liked: 1263
^ Better still, I prefer the preamp level crossover in/out option built-in to the majority of subs, over the speaker level connections, for systems without external crossover bass division means (such as is found on modern day AVRs).
Reply Community News & Polls
