Home Theater in the Olympics, what would the games be? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 07-23-2012, 08:21 AM - Thread Starter
David Bott's Avatar
Liked: 45
Ok, seeing we are right around the corner from the 2012 Olympic Games, we thought we would ask this fun question.
If Home Theater was in the Olympics....What would the games be?
Yeah, yeah, we know, sounds lame and would never happen, but come on, we could always dream. So what could some of the games be? I bet some of you could come up with some good ones.
I will be happy to start...
Video Throw Distance
You score points for each screen size and distance you can "properly" light up per an agreed upon set standard.
I would like to suggest Joel Silver, of Imaging Science Foundation, as the team coach. smile.gif
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
post #2 of 36 Old 07-23-2012, 10:41 AM
BeeMan458's Avatar
Liked: 813
Obviously, there has to be a dB sound challenge as to who can raise the SPL level the most, with the least amount of watts used.
nateo200 likes this.
BeeMan458 is offline
post #3 of 36 Old 07-23-2012, 10:47 AM
FestusGandhi's Avatar
Cool idea, David! I'll trow out the first hammer:
Sub Bass Clean and Press
Score points for: lowest frequencies with least amount of distortion; volume at lowest frequencies; articulation and richness.
Other speaker categories might have to be judged more like figure skating because they can be fairly judged only in qualitative terms.
FestusGandhi is offline
post #4 of 36 Old 07-23-2012, 11:23 AM
BMLocal175's Avatar
Quoted: 22 Post(s)
Find the Harmony One Remote in a couch then its a family relay handing the remote off like a baton jumping over coffee tables to the finish.
FestusGandhi and nateo200 like this.
BMLocal175 is offline
post #5 of 36 Old 07-23-2012, 11:35 AM
WagBoss's Avatar
who can cause their house to collapse first by blasting subwoofers while watching movies
WagBoss is offline
post #6 of 36 Old 07-23-2012, 12:07 PM
popalock's Avatar
Quoted: 1235 Post(s)
Liked: 1720
Sub ball bearing vertical challenge.
Small 1lb ball bearing placed in the center of sub resting free air on the ground. Feed the sub a 240V wall socket for a burst of power.
Highest achieved vertical wins.
Must be all commercially available or mass produced subs available to the public. Performance enhancing coils and/or other aftermarket components would bring shame to the host country...
Wonder if most competitors would in fact be from China?
popalock is offline
post #7 of 36 Old 07-23-2012, 12:11 PM
IwantmyTHX's Avatar
Advanced Denon Receiver setup. Best time to set up a 7.1 surround system, including renaming and level matching inputs. Would probably work across most if not all brands but I have experience with Denon.
IwantmyTHX is offline
post #8 of 36 Old 07-23-2012, 12:17 PM
cgmv123's Avatar
Quoted: 40 Post(s)
Liked: 36
  • Build with the shortest amount of cable used
  • Highest speaker output power per amp ratio
  • Solar power challenge
Max Vrany
@cgmv123
cgmv123 is offline
post #9 of 36 Old 07-23-2012, 12:19 PM
stevenjw's Avatar
Quoted: 323 Post(s)
Liked: 346
I'd definitely try out for the long distance marathon! Wonder how many days can I park my rear in my HT recliner with minimal breaks? I've done extended LOTR trilogy, but that's nothing. Think I could get through entire collection of Lost, BSG, or X-Files. Avoiding nodding off is the challenge.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one."
My HT gear
stevenjw is online now
post #10 of 36 Old 07-23-2012, 12:47 PM
Manic1!'s Avatar
Quoted: 176 Post(s)
Liked: 75
Speed install/set up. Competitors walk into a room with a bunch of equipment and have to install it. The first person to have a HT up and running wins.
Manic1! is offline
post #11 of 36 Old 07-23-2012, 12:52 PM
bfreedma's Avatar
Liked: 51
Subwoofer shotput.
Closest landing to the sweet spot- sub tossed while sitting at the MLP.
bfreedma is offline
post #12 of 36 Old 07-23-2012, 01:19 PM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Just few that come to mind....
1. Green Glue Squirt. Who can suck up Green Glue from a bucket using the approved applicator and squirt the most by volume, weight and distance within an allotted time? An accuracy component for scoring is being considered for 2016.
2. Framing Fix. Who can frame a wall, have it "judged" (inspected) to be inadequate, tear it down and rebuild it the fastest?This event is, of course, open to interpretation by the "judges," particularly the Russian and French Judges.
C. Don't Shoot Yourself In the Foot Competition. Who can run in the most 16d nails with a framing nailer without shooting themselves in the foot. Nails to the head score extra points and nails through the roof of your mouth earn triple points. Nails in the hand are minus points (too easy to try to run up a score).
4. Is it live? Touch the black wire and find out! Loads of laughs (Oops, I mean EXCITEMENT) seeing who jumps the highest!
5. Post It Marathon. Who can post the most repeated questions without searching the forums first? This event is being considered for replacement in 2016 by the Head Slapping contest.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #13 of 36 Old 07-23-2012, 01:37 PM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
Fishing cables down a wall challenge.
dolphinc is online now
post #14 of 36 Old 07-23-2012, 01:50 PM
stlacmilanfan's Avatar
How about brightness in cost range. How about most depth in a 3d vgideo. Best lag input for video games. All spilt by cost cause we all know a 70000 dollard projector would beat the stuff I can afford. Best home made screen
stlacmilanfan is offline
post #15 of 36 Old 07-23-2012, 01:59 PM
ADDUpstate's Avatar
Bad Blu Ray Discus
ADDUpstate is offline
post #16 of 36 Old 07-23-2012, 02:05 PM
taxman48's Avatar
Quoted: 304 Post(s)
Liked: 297
taxman48 is offline
post #17 of 36 Old 07-23-2012, 03:52 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
Most construction completed before wife realizes what you are doing.
Mr.Tim is offline
post #18 of 36 Old 07-23-2012, 03:53 PM
MikeArms24's Avatar
How about a heptathlon: Black levels, lumens, 3d ghosting, contrast ratio, picture size, response time, refresh rate
MikeArms24 is offline
post #19 of 36 Old 07-23-2012, 07:26 PM
Seth89's Avatar
How about a speaker tossing contest?
So for example people from Sweden would have to toss a Genelec and someone from Britain would have to toss a B&W.... Some American dude tossing a Polk...
Be awesome!
Seth89 is offline
post #20 of 36 Old 07-23-2012, 08:14 PM
Jindrak's Avatar
Quoted: 51 Post(s)
Liked: 122
There would be no contest for this. Danley would win. They would also win in the category of making the heaviest cabinets in the world relative for their size.
If one is going to make a simplistic assessment of the value of different alignments, it would be that sealed/IB goes the lowest, at the highest cost per dB; horns have the lowest cost per dB at the expense of size, and vented box characteristics lie in between the other two. None is inherently superior across the board, neither is any inherently inferior across the board. The one to use is the one that fits your response and output needs, available space and bank account. -BFM
Jindrak is offline
post #21 of 36 Old 07-23-2012, 09:58 PM
nateo200's Avatar
Best multichannel soundtrack created in X amount of time with a X concept in mind. Categories would include Best Dolby Surround mix, Best 2.1 mix, Best 4.0 (Quad) mix, best 5.1 mix, Best 6.1 mix, Best 7.1 mix. Oh yeah and the sample rate would have to be 48khz with a bit depth of 16 biggrin.gif Audiophiles would cringe. The final would be burned onto a Blu-ray disc in DTS-HD High Resolution (not master audio) with the lowest bit rate set (2046kbps). Oh this would be a nerds joy AND it would probably shock allot of people, er I mean audiophiles who need everything lossless (nothing against lossless but Im all for a lossy track that sounds great than a PCM track that sounds crap, IE: We Were Soldiers DTS-ES Discrete 6.1 vs Delta Farce or Dirty Dancing's original 7.1 PCM track :O)
Fastest Home Theater Setup graded on quality. You'd have 30 minutes to set the systems up, calibrate, etc. It would be tested using Tron Legacy, Super 8 and other epic 7.1 master pieces.
nateo200 is offline
post #22 of 36 Old 07-23-2012, 10:13 PM
tkmedia2's Avatar
tkmedia2 is offline
post #23 of 36 Old 07-23-2012, 11:46 PM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Find a good movie within 5 hours.
MovieSwede is offline
post #24 of 36 Old 07-24-2012, 01:32 AM
Hello, World!
Mark_H's Avatar
Quoted: 262 Post(s)
Liked: 172
CRT Put (shot put): See who can "put" their beast of a CRT projector the farthest from a standing position.
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #25 of 36 Old 07-24-2012, 04:38 AM
popalock's Avatar
Liked: 1720
Just re-read the title.
HT Building in the Olympics...
Ummm, how about this.
Choose a very high end speaker design (think something like Focal Grand Utopia or anything else ridiculous from here).
5 Man teams.
Set timeline (i.e. - 3 Days or other depending on complexitity) to complete as much of the build as they can.
Teams judged on:
Build Accuracy (as close to the original copy as possible)
Audio Accuracy (as close to the original copy as possible) (i.e. - use the OEM as left speaker and built speaker as right in a 2 channel setup and have judges assess)
Build Cost (lowest cost wins)
Obviously this wouldn't be a non-stop action packed thriller 100% of the time, but as with all of the other build shows out there, the highlights could be edited into making a pretty entertaining segment...
popalock is offline
post #26 of 36 Old 07-24-2012, 07:18 AM - Thread Starter
David Bott's Avatar
Liked: 45
Yeah, bad choice of words on my part I guess, but it's all in fun. smile.gif (Title now edited.)
David Bott
Founder - AVSForum
post #27 of 36 Old 07-24-2012, 05:08 PM
thrang's Avatar
Quoted: 1613 Post(s)
Liked: 1387
DVD skeet shooting...
thrang is offline
post #28 of 36 Old 07-24-2012, 11:55 PM
nateo200's Avatar
Blu-ray disc ring toss. Dont worry we'll round up all the non-TrueHD Superman, non-remastered 5th Element Blu-ray discs so it won't hurt as much biggrin.gif
nateo200 is offline
post #29 of 36 Old 07-25-2012, 02:00 PM
larryep's Avatar
To build the most unsafe chair and sit in it. Just to get the feel of the risers that haven't been built yet!
larryep is offline
post #30 of 36 Old 07-25-2012, 02:15 PM - Thread Starter
David Bott's Avatar
Liked: 45
Ok, that was just funny and maybe should have also been submitted to what was your worst build mistake. wink.gif
David Bott
Founder - AVSForum
Reply Community News & Polls
