Have You Heard Exotic Audio Cables Improve Sound Quality? - Page 22 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Have You Heard Exotic Audio Cables Improve Sound Quality?
Yes, and it was a big improvement 51 8.69%
Yes, but it was only a slight improvement 68 11.58%
No, I did not hear any improvement 323 55.03%
I don't have enough experience to say 145 24.70%
Voters: 587. You may not vote on this poll
 7Likes
post #631 of 662 Old 09-01-2013, 04:05 PM
A9X-308's Avatar
Quoted: 1283 Post(s)
Liked: 953
Originally Posted by olyteddy View Post
And what's wrong with that?
Capacitance.
A9X-308 is offline
post #632 of 662 Old 09-01-2013, 06:10 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Capacitance.
Just what do you mean by that? CAT5 is 15 picofarads a foot. (http://www.smarthomeusa.com/ShopByManufacturer/Genesis/Item/WG-4978210x/)
Speaker wire, well, is even higher:
Originally Posted by http://en.wikipedia.org/wiki/Speaker_wire#Capacitance_and_inductance
Ordinary lamp cord has a capacitance of 10–20 pF per foot, plus a few picofarads of stray capacitance, so a 50 foot run (100 total feet of conductor) will have less than 1% capacitive loss in the audible range. Some premium speaker cables have higher capacitance in order to have lower inductance; 100–300 pF is typical, in which case the capacitive loss will exceed 1% for runs longer than about 5 feet (10 feet of conductor).
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #633 of 662 Old 09-01-2013, 06:36 PM
A9X-308's Avatar
Liked: 953
15pF per pair. Start paralleling conductors and cables and it goes up very quickly and it can affect the stability of some SS amps, causing oscillation, overheating and in some cases damage to the amplifier (and maybe speakers). It would be pretty much instant death to Naim amps for example. This is a well known phenomenum to those of us who study amp design and I have actually seen a couple of examples in testing on my own bench and repaired severel more from audiophiles who simply read an article on doing this online and tried it to the detriment of their amps.
A9X-308 is offline
post #634 of 662 Old 09-01-2013, 07:31 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
That sounds more like an amp problem than a cable problem.
post #635 of 662 Old 09-01-2013, 08:51 PM
wse
wse's Avatar
Quoted: 1977 Post(s)
Liked: 741
Originally Posted by Jinjuku View Post
Ok here is a quote from the AQ website on the Ethernet cables: DIRECTIONALITY: All audio cables are directional. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. Arrows are clearly marked on the connectors to ensure superior sound quality. For best results have the arrow pointing in the direction of the flow of music. For example, NAS to Router, Router to Network Player. It's packet data! There are send and receive pairs. It's why Ethernet is a full duplex standard.
They are full of it! Monster does the same and they made a ton of money! I use to be ignorant, and bough some monster cables way back when I started in this expensive hobby. Then the Internet came and I educated myself, reopen my physics books as well smile.gif know I know better, I am just buying marketing smile.gif
Should I just challenge the corporate owner/s of AQ? What utter crap.
YES PLEASE, I would love the hear what he says!
wse is offline
post #636 of 662 Old 09-01-2013, 10:17 PM
A9X-308's Avatar
Liked: 953
If you have a system that's working fine and you swap it out for a highly capacitive cable that then causes damage, then it's a user problem. It's difficult for a designer to ensure stability into every load, especially when there are tight margins and low profits to be made. Especially just to sate the whims of a few foolish audiophiles.
A9X-308 is offline
post #637 of 662 Old 09-02-2013, 08:48 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
It's a user problem. When you have engineering teams with 100's of years of man hour experience designing amps they design to common standards and mantra's that hold true in the world of physics. They design and engineer accordingly.
Then you get some person that thinks they know 'better' then the hilarity ensues.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #638 of 662 Old 09-02-2013, 10:51 AM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 126
And what's wrong with that? 4 24 gauge strands in parallel is roughly equivalent to a 17.5 gauge wire and if you run two pieces that doubles the ampacity to a nearly 15 gauge wire! eek.gif Don't believe me? There's a chart on this page: http://www.powerstream.com/Wire_Size.htm
It doesn't matter if it makes sense or not - my attempt at humor was Audioquest found a market for it, but terminated it with RJ45 instead of speaker connectors.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is online now
post #639 of 662 Old 09-02-2013, 02:39 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
The real fun part is some one takes this stuff serious and others must be keeping Audioquest in business.
Phil17108 is offline
post #640 of 662 Old 09-02-2013, 05:48 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Well just sayin', BUT a lot of expensive speaker cables have much higher than 65pf per foot capacitance. It's the necessary trade off if you want to keep inductance down. Take a look at the table at the bottom of this article: http://diyaudioprojects.com/Power/Low-Inductance-DIY-Speaker-Cables/
post #641 of 662 Old 09-03-2013, 10:53 PM
wse
wse's Avatar
Liked: 741
Originally Posted by Scott Wilkinson View Post
This is one of the most hotly contested debates in all of audiophilia. Manufacturers make extravagant claims about how different materials and geometries affect the sound—and they charge extravagant prices for these innovations.
Pictured here is a cross section of the Stealth Audio Dream V10 speaker cable, which lists for $14,000 for a pair of 2.5-meter lengths.
Are such high prices justified? Have you heard exotic/expensive cables improve the sound quality of an audio system? What were the circumstances that led to your conclusion?
What a farce! Here is an other one: http://www.morrowaudio.com/
pathetic! By the way their cables are rebadged MOGAMI
wse is offline
post #642 of 662 Old 09-04-2013, 12:52 AM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Are you 100% sure?
audiofan1 is online now
post #643 of 662 Old 09-04-2013, 07:35 AM
wse
wse's Avatar
Liked: 741
wse is offline
post #644 of 662 Old 09-04-2013, 08:07 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Checked them out, and the most interesting thing found is a brown 20 AMP receptacle from Hubbell for 13 bucks. Had not seen the name before and googled that and part # and found this, http://www.hubbell-wiring.com
Its well built? very expensive stuff that only well be used if what?????? $13 was the cheapest price I found, must be counterfeit.
post #645 of 662 Old 09-04-2013, 12:03 PM
audiofan1's Avatar
Liked: 1666
??? nothing on the link you provided is solid core silver plated, or did I miss something! perhaps you could be a little more specific.
post #646 of 662 Old 07-27-2014, 04:01 AM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
I believe it!!!!
My wire stopped working and I had to change it between my VCR and AMP.... What garbage sound from the other cord!!!! -- More tinny sounding and not as much bass! (Sibilance,etc)
I finally found another lead with traditional wires and Ill see how that is....... I just watched something on VHS that wasnt HIFI and it sounded OK I guess.......
www.ebay.com/itm/121390553994
I have always been worried if something happend to my wire My sound would be screwed up and I was right
Dude111 is offline
post #647 of 662 Old 10-30-2014, 09:49 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is online now
post #648 of 662 Old 10-31-2014, 10:01 AM
uriah's Avatar
Quoted: 24 Post(s)
Originally Posted by EnjoyingMyRide View Post
The funniest claims are the ones made by Nordost, with their "Propagation Delay" ratings. Oh, the price you pay to move up from 95% speed of light to 98% speed of light... for some people that price difference is the same as the cost of a new car. Talk about diminishing returns.
<br><br>
Diminishing returns indeed! Per Einstein's TOR, the speed of light (186,000 m/sec) <b>is</b> the cosmic speed limit and can only be approached. So put that in perspective when upgrading a cable instead of a new car or an education.[/QUOTE]
Just to be persnickety about things, relativity specifies light in a vacuum. Through other media such as water, the speed of light is slower (By 25%). Check Cherenkov radiation that pretty blue you see in swimming pool reactors. But to the synapses in my brain a few thousand miles per second difference is, how shall we say, trivial.
uriah is offline
post #649 of 662 Old 10-31-2014, 10:06 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4953 Post(s)
Liked: 8377
I do see an opportunity for Nordost in the aftermarket video game controller cable category.
Mark Henninger
imagic is online now
post #650 of 662 Old 10-31-2014, 12:35 PM
EnjoyingMyRide's Avatar
Quoted: 45 Post(s)
Liked: 261
I stand corrected! I'm not ready to break the cosmic speed limit just yet.
Steve
EnjoyingMyRide is offline
post #651 of 662 Old 11-01-2014, 11:52 PM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 126
I was going to have a laugh at their exotic Ethernet cables, but remembered this thread is about exotic AUDIO cables.
post #652 of 662 Old 11-02-2014, 09:57 AM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
Dont laugh bud..... THE CABLE DOES INDEED MATTER!!!!!!!! (Dont cut us down just because your lucky enough to not have had it happen to you -- PLEASE TRUST US)
I have bought 4 or 5 more since my post above....... A friend finally told me of this place in my area that sells better quality cables (I hadnt ever been there)....... I got one and its the best I have had since my original went out.......
Dude111 is offline
post #653 of 662 Old 11-02-2014, 11:16 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I have been thru 4 or 5 more since my post above....... A friend finally told me of this place in my area that sells better quality cables (I hadnt ever been there)....... I got one and its the best I have had since my original went out.......
Trust who? Those still using VHS? People who imagine hearing things? Those who are very gullible? Why on earth would you go "thru" 4 or 5 cables?
MauneyM and Thatsnasty like this.
lovinthehd is offline
post #654 of 662 Old 11-03-2014, 06:16 AM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
Because the center conductor,etc was not good on all of them I had tried!
Everything has to be JUST RIGHT or it doesnt perform as well....... (Center conductor,shielding,etc)
I wasnt imaging anything.......
Dude111 is offline
post #655 of 662 Old 11-25-2014, 08:41 PM
Cargent05's Avatar
Liked: 1
There's a reason why Theoretical Physics is relevant. Someone has an idea that "could" be possible, and until it's proven otherwise, it has to be considered. That is where I put these outrageous cable companies. Sure, you can theorize all day long about how something might be happening. And if you can make money selling those notions, more power to you. But you sure as hell won't get any of my money. Dayton Audio - Thanks for all the excellent cables over the years!
Cargent05 is offline
post #656 of 662 Old 02-09-2015, 02:17 PM
brownsguy's Avatar
Liked: 2
I have not heard much difference, but then again I have Tinnitus after attending way too many rock concerts in my youth.
I need Jimmy Page to pay some of my medical bills?
brownsguy is offline
post #657 of 662 Old 02-10-2015, 09:51 PM
adrummingdude's Avatar
Quoted: 405 Post(s)
Liked: 270
I break the cosmic speed limit with 12 gauge speaker wire from radio shack.
In all seriousness though, I believe I can here a (extremely slight) difference in wire, but in my limited experience with "exotic" cables don't always agree that they sound better than the cheap stuff.
$14k cables to connect my $1500 speakers to my $1000 AVR though...yeah right. I'll keep the radio shack wire and put that money towards some Dynaudios or 800 series Bowers.
HT: B&W CM9 S2 - Martin Logan SLM-XL - DefTech XTR-20BP - Dual SVS SB-2000 - Parasound Halo A21 and A51 - Marantz AV7702 MKii - Samsung UN65JS8500
2CH: Sonus Faber Cremona Auditor M - Parasound Halo A23 - Bluesound Node 2 - Iomega NAS
WAF is currently at DEFCON RED
adrummingdude is offline
post #658 of 662 Old 02-11-2015, 05:09 PM
Splat50's Avatar
Liked: 0
I find that $14,000 cable absolutely fascinating, mostly because someone may have actually bought one. But hey, Kudos to the copy writers. "Para-vacuum" anyone? I wonder how many they really sell. I suspect it is actually an extremely low number. I also think that having an "exotic" super expensive cable in their product list may lead people to ultimately buy one of their least expensive cables. Again, good marketing tactic. However, from a physics standpoint, it's all about I = V/R.
Splat50 is offline
post #659 of 662 Old 03-29-2015, 08:30 AM
Quoted: 13 Post(s)
Liked: 0
Ok im after a bit of advice, i have just ordered the Pioneer VSX-924 and will be pairing it with either the WHARFEDALE DX1 HCP 5.1 Pack or Q ACOUSTICS 2000i 5.1 Pack (not sure if the double the price Acoustics 2000i are a better speaker as the Wharfedale's seam to get glowing reviews across the board!?) but not sure which speaker wire i should use. Know i know either of the speakers arent top of the line (or anywhere near) but would this speaker wire be good enough??.....
http://www.ebay.co.uk/itm/2809367495...463&rmvSB=true
and whats peoples views on Banana plugs are they really necessary if you dont intend to plug and unplug the speakers a lot?. Im thinking that there just another connection in the line and thus 'could' result in poorer quality than using no banana plugs?
BlockABoots is offline
post #660 of 662 Old 03-29-2015, 12:13 PM
A9X-308's Avatar
Liked: 953
That cable will be fine. Banana plugs offer nothing except convenience = use them if that's a factor for you, otherwise don't.
A9X-308 is offline
Reply Community News & Polls
Polls
