New Member Introductions - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 290Likes
post #61 of 1581 Old 09-13-2013, 01:05 AM
vivies's Avatar
Hi,
I'm really involved in sound production and hope to share experience and passion with you guys !
vivies is offline
post #62 of 1581 Old 09-13-2013, 06:46 AM
whitewolfpgh's Avatar
Finally a proud owner of a quality home theater receiver. Hoping to learn how to get the best out of it!
whitewolfpgh is offline
post #63 of 1581 Old 09-13-2013, 11:35 PM
StevenLyall's Avatar
Hi All - I just joined and will have a few questions soon about my Denon 4311 setup. I'll be sure to find the right forum for the questions.
StevenLyall is offline
post #64 of 1581 Old 09-14-2013, 10:05 AM
trek2112's Avatar
Hi everyone I just added TV calibration to my AV hobby. I always like to get the best out of my gear.
trek2112 is offline
post #65 of 1581 Old 09-14-2013, 10:58 AM
chiefsfan1981's Avatar
Hello everyone, I joined after seeing plenty of mentions on reviews in amazon, I just purchased a Panasonic tc55st560 after months of debating whether or not to get the vt model, anyway I settled on the st version, have not received it yet, but cant wait to check it out, anyway I appreciate all the help from all the calibrators and consumers as Ive been looking at buying a tv for the last year and finally settled on the st thanks to the reviews and research
chiefsfan1981 is offline
post #66 of 1581 Old 09-14-2013, 02:46 PM
fuskus's Avatar
Hi everyone,
New around here, so I thought I salute all the hi-fi people on this forum.
Cheers,
Fuskus
fuskus is offline
post #67 of 1581 Old 09-14-2013, 11:55 PM
DannyShem's Avatar
Greetings. I am opening a fast oil change business in Israel, and am looking for innovative lighting solutions, including substituting projection for buying static signs. I am not sure if this is feasable, and welcome anyone's input on the subject of in-store promotion.
Best regards,
Daniel
DannyShem is offline
post #68 of 1581 Old 09-15-2013, 02:35 AM
zuobohking's Avatar
Hi all!
I'm new to this forums.
I just started venture into big screen (70" and above) multitouch & collaboration solutions, more for classrooms & office/meeting rooms so signage products are not really my cup of tea.
zuobohking is offline
post #69 of 1581 Old 09-15-2013, 10:51 AM
MTZEE's Avatar
Hi all
this is MTZEE. am new and excited to be here
thanks
MTZEE is offline
post #70 of 1581 Old 09-15-2013, 01:44 PM
Tajmahal's Avatar
Hi! I'm Andrej from Croatia. I'm a electronic technology lover.
Tajmahal is offline
post #71 of 1581 Old 09-16-2013, 01:52 AM
MediaFan63's Avatar
Hello everyone,
I stumbled across this site yesterday while looking for a drive for my Panasonic DMR-EZ28 Dvd recorder. I want to thank DigaDo, and everyone who provided the information on cleaning the hub and spindle. My recorder stopped recording and would not release the disc after three days of turning on, turning off, trying to eject by reset button and eject button. I figured I had nothing to lose by cleaning the hub and spindle before ordering a drive. It was easy, so easy I couldn't believe it. I didn't even touch the laser figuring I could go back in if it didn't work. I took out the disc, cleaned the hub, and just lightly sprayed some can air around to blow out the dust. Everything else looked ok. I put the cover back on, plugged it in and tried the eject button. The tray wouldn't open so I pressed the reset button, it still wouldn't open so I pressed the stop and channel up buttons together for five seconds and it opened the next time I pressed the reset button. I have now recorded three -R's, recorded on a Ram disc and it works like new. Btw I use tdk, and memorex -R's and always have. My Ram discs are Panasonic. Thank you all again for buying me some time with this recorder as money is tight. I also have a Panasonic DMR-EZ48V but have a warranty through 11/14.
I remember when products were built to last.
MediaFan63 is offline
post #72 of 1581 Old 09-16-2013, 02:48 PM
pezbear1975's Avatar
Hello There All,
If anyone would shed some light on this issue that would be great.
I currently have the XBR55HX950 LED Backlit tv,( refurbished ), Which was replaced by Sony ( had KDL55HX750 which had awful ghosting/clouding )
Sony needs to replace the XBR55HX950 as it has small chip on screen.
They are having a hard time finding another XBR55HX950 so they are willing to give me a KDL-55W900A.
My question to you is : Does this TV have issues with the Ghosting/ clouding from the Edge lights like the KDL-55W900A ?
As i said before it looks very noticeable in dark scenes and worse with Bluray ..
If the KDL-55W900A does have this issue i will keep the XBR55HX950 as it does not have the issue
Sorry i realised i posted this in the wrong section too.. Off to a great start hey !!!
pezbear1975 is offline
post #73 of 1581 Old 09-16-2013, 10:44 PM
bwirum's Avatar
Hello all,
I'm from Norway, delighted to find this forum while searching for something spiffy (see my post in camcorder section...), as I'm actually adding a section to my house which I plan on fitting with a nice home theater system. Building new means I can do all sorts of cool stuff with it, but the interior part will probably not be done till next summer, so I'll be coming to you with a bit of questions and suggestions to get some feedback on through the winter smile.gif
Looking forward to drawing from your knowledge!
bwirum is offline
post #74 of 1581 Old 09-17-2013, 12:04 AM
tyke22's Avatar
Liked: 0
Thank you Scott and hello to the Group. I reside in the suburbs of Detroit, MI. I am retired. I like the technical aspects of this forum as well as finding and learning many things regarding products.
Best to All
.....Rob
tyke22 is offline
post #75 of 1581 Old 09-17-2013, 10:07 AM
corybooth's Avatar
Hello from Missouri. Just moved from Virginia to a home prewired with 7 zones and a Russound distribution. All the rooms have a LCD2 control pad. Came here to figure out all the ins and outs.
Sent from my SCH-I535 using Tapatalk 4
corybooth is offline
post #76 of 1581 Old 09-17-2013, 12:41 PM
torjs99's Avatar
Hello!
I'm new!
torjs99 is offline
post #77 of 1581 Old 09-17-2013, 06:09 PM
dmrazik's Avatar
Hello everyone, my name is Dave, near Emerald Isle,NC
I've been lurking this site for several years now and decided to become a part of the community. I started a business installing televisions and surround sound systems in 2010 and slowly it's been growing. I'm definately not at the level of "Home Theater Master" as some of you who bless this forum with your presence and wisdom. I do, however, like reading, and research and keeping up to speed with technology, which consequently makes me the guy that people go to for help with their systems.
Currently I own:
Samsung 55" 3D Television
Yamaha RX-V575 (which i don't care for unfortunately)
Episode 700 series in-ceiling speakers
Episode DUAL 8 in-wall sub
Pro-control 24-r remote
Outdoor Episode 6.5" speakers by the pool
Website if any would like to visit: www.FlatScreenMountingNC.com
This site has loads of information and materials that has helped me to build my own surround sound system, as well as plan systems for customers. I'd be glad to have a part in helping others on this site as I do in my area.
And a Thanks ahead of time for people who help me out when i'm in a bind!!biggrin.gif
dmrazik is offline
post #78 of 1581 Old 09-17-2013, 08:04 PM
gorio1961's Avatar
Greetings everyone!
I am Greg Williams. As I new homeowner, I had the luxury of having a home theater professionally installed (not a wire in sight). It's a 5.1 system using Klipsch ceiling mount studio reference speakers, Klipsch SW-310 Sub woofer with associated Bluetooth connection kit. The system is driven by the Yamaha RX-V673, I initially purchased the 671, but as soon as I found the 673, I upgraded... wanted the additional features. Needless to say, I now have a 671 sitting as a spare just in case... oh well, I digress.
After upgrading, I noticed that there was no signal going to the sub while streaming Pandora...VIOLA! visited this forum and quickly found the answer. Had to join this extremely knowledgeable group of folks.
Greg
gorio1961 is offline
post #79 of 1581 Old 09-17-2013, 09:25 PM
619liquid's Avatar
Longtime lurker figured it was time I registered. I’m a FNG when it comes to surround sound; I was recently using a Logitech Z-5500 from my college days and decided to finally buy a real surround system since I finally bought my own house. Seeing the high-end systems posted around the forum had me a bit apprehensive about posting what I finally bought: however it does work for me now and maybe when I get my next home, I’ll have a dedicated theater room.
Sony BRAVIA KDL55HX850
Yamaha RX-V773 (originally bought a V673 (still have it), but went with V773 for the extra HDMI output for the patio tv (soon) )
Infinity Primus PC351 Three-way dual 5-1/4-Inch Speaker
(2) Infinity Primus P163BK Two-way 6 1/2-Inch Bookshelf
(4) Yamaha NS-IW280CWH 6.5" 3-Way In-Ceiling Speaker
BIC America F12
For the patio:
OSD Audio PS520 Terra Cotta Planter Omni Speakers
I did purchase the Disney calibration bluray, but I still want to have it professionally calibrated, just unsure if it’s worth it?
619liquid is offline
post #80 of 1581 Old 09-18-2013, 09:49 AM
james2476's Avatar
Thanks for the welcome
james2476 is offline
post #81 of 1581 Old 09-18-2013, 07:18 PM
Mambosun's Avatar
Originally Posted by Scott Wilkinson View Post
Welcome to the AVS Forum community! We're delighted you've decided to join over 1 million fellow enthusiasts who enjoy sharing their passion about audio/video gear and technology.
Please take a moment to introduce yourself in this thread. What are your particular interests—displays, sound systems, movies, video games? What gear do you have in your system now? What do you hope to get in the future?
Once again, welcome aboard; we look forward to seeing you in the forums!
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
Follow AVS Forum on Google+
I have so much gear I don't have the time or the room to learn it all! Well, my home theatre in the living room consists of a Panasonic Viera 50" 3-D Plasma Vt-25 I believe. I own the Onkyo TNR-5007 receiver which I'm having trouble with ATM. No sound tried everything! Ill post more later but just wanted to say to you all! And thank you!
Mambosun is offline
post #82 of 1581 Old 09-19-2013, 07:43 AM
duodiscuss's Avatar
Hi Everyone,
I've just jump in the boat. I've already found many precious information. I am the happy owner of a Yamaha RX-V673 and a Sony BRAVIA KDL42HX850.
I just had trouble with the connection between the Aplle tv nad the yamaha. That's what brought me here.
See you.
Steve
duodiscuss is offline
post #83 of 1581 Old 09-19-2013, 12:48 PM
Splinterdog's Avatar
Greetings all, i am Jim and i am here to research my new epson 3020 projector as well as video game systems and really any and all electronics.
Hope to hear from some of you on finding a compatible wall mount for my epson 3020 projector, well i am off to search for one now.
Splinterdog is offline
post #84 of 1581 Old 09-19-2013, 01:41 PM
Bebling's Avatar
Thanks for the warm welcome! I was really into home theater about 15 years ago. Been enjoying that system for years and now that my Lexicon DC1 is getting outdated it is time to upgrade the receiver and look into revamping the entire setup. I have a Pioneer Elite 62" RPT with a complete set of Snell speakers, Velodyne sub and Parasound amps. Considering upgrading to a projector and possibly moving the sub to a new location.
Thanks and I look forward to meeting all of you "experts" out there.
Bruce
Bebling is offline
post #85 of 1581 Old 09-20-2013, 08:42 AM
jfreezee's Avatar
Hi Everyone,
Thanks for the welcome scott.
I am here to learn more about projectors. Trying to get a 1080p projector and thats the reason why I landed here smile.gif.
jfreezee is offline
post #86 of 1581 Old 09-20-2013, 09:49 AM
Dee02130's Avatar
Hi all. my name is David and I just joined. Happy to be here and eager to ask questions and look for suggestions.
I'm currently running a 5.1 surround system with following equipment.
Denon AVR 3313CI
Cambridge Sound Works mc 100 x4
Cambridge Sound Works mc 150 center channel
Cambridge Sound Works Bass Cube 8s
Samsung 46" LCD TV
Thinking of upgrading my surround sound speakers and sub as myreceiver was $1200 and the surround system was about the same price back when I bought it in 2006.
Dee02130 is offline
post #87 of 1581 Old 09-20-2013, 10:47 AM
trek68's Avatar
Hi everyone!
I'm a new projector user and generally a lover of new visual and audio technology! smile.gif
trek68 is offline
post #88 of 1581 Old 09-20-2013, 11:58 AM
PapaDilbert's Avatar
Happy Friday!
I'm just a typical IT geek with audio challenges.
PapaDilbert is offline
post #89 of 1581 Old 09-20-2013, 12:02 PM
patrucho's Avatar
Hi folks - my first post went right into the Panasonic discussion thread for my DMR-EH75V DVR - curious to see if it's repairable, or if I should just pony up and get a new Magnavox.
Been browsing the forums this afternoon after a frustrating 3 weeks with my DVR in the shop with absolutely NOTHING to show for it except an insane quote...
Hoping to find lots of great information on this site, especially once I move into the modern age (hopefully) this Winter, when I'm hoping to retire my Sony VEGA CRT TV smile.gif
patrucho is offline
post #90 of 1581 Old 09-21-2013, 08:57 AM
asankapro's Avatar
Hi Everybody,
asankapro is offline
Reply Community News & Polls
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P60s30 60 Inch 1080p Plasma Hdtv
