HT of the Month: Theater for Hobbits - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 01-15-2014, 08:34 PM
detailzman62's Avatar
Great job on new move theater Thanks for the inspiration
detailzman62 is offline
Old 01-26-2014, 12:59 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 186
Originally Posted by snowkarver View Post
I was aware of the 8350's spotty reputation - I actually have a good friend who's been through two himself due to the green blob issue. I got mine as an Epson refurb with full factory warranty for less than $800 however - and on such a tight budget, there simply wasn't any other option even in the same league. Here's hoping I have good luck.
And thanks again to everyone! I really appreciate the kind words.
I wouldn't worry too much about this. Epson has figured out what the issue with their bulbs failing early was. I believe they fixed this back in 2011-2012. smile.gif
Lumenlab "Community driven video lab".
blake18 is offline
Old 01-29-2014, 01:05 PM
sen_jey's Avatar
This looks super cool. Good job done!
sen_jey is offline
Old 03-06-2014, 06:30 PM
stevez32's Avatar
So very nice!
stevez32 is offline
Old 05-02-2014, 06:11 AM
mdrums's Avatar
Quoted: 14 Post(s)
Liked: 31
This is a really cool build! Awesome job...I wish I had the talents to do the build out myself like David did. I will never forget this build and one day when I downsize my house this build will definitely come back to me.
Mikes Stuff
McIntosh MC207 Amps.........................DarbyVision Darblet
Marantz AV8801 Processor.................Da-Lite Screen
Klipsch Reference Series 7.2................Panasonic BluRay BDT500
Epson Pro 6010 Projector.....................Sony Playstation used for SACD and BluRay
mdrums is offline
Old 07-14-2014, 08:13 AM
whokilledkaji's Avatar
Can somebody tell me what the table is? Is it from ikea? Maybe DIY? It's nice and simple!
whokilledkaji is offline
Old 07-14-2014, 09:34 AM
snowkarver's Avatar
Liked: 47
It's an Ikea PS Bruse coffee table from 2009. Unfortunately it was a limited edition and they don't make it anymore.
That said it would be super simple to DIY. Find a nice reclaimed plank, sand, urethane, and screw some nice powder coated trestle legs (ikea probably still has them) underneath. Done!
snowkarver is offline
Old 07-14-2014, 07:59 PM
Cool! Thanks for the reply!
Old 12-07-2014, 06:44 AM
Skylinestar's Avatar
Quoted: 1067 Post(s)
Liked: 186
Don't you think the screen is too high?
It's been a long time I visited a cinema (probably 10 years). I used to sit in the middle row and I don't recall that I have to look up that much. Is everyone looking up instead of looking forward or even down (at least till 2/3 to the back of the cinema)?
Skylinestar is offline
Old 12-07-2014, 09:17 AM
snowkarver's Avatar
Liked: 47
I built it to be the same as 1/4 to 1/3 of the way back in a modern stadium-seat cinema, which is where I usually sit. It's a little bit higher than some or most place the screen, but working in a small space always forces a compromise - in this case clearance for the subs and stack underneath.
The lowish basement ceiling and soffit also causes a bit of an optical illusion as it brings the room height down to about 7 feet at the screen. Long story short, a little high, but adults are looking straight not up.
Old 12-15-2014, 06:09 PM
Liked: 0
Very nice home theater room. Nice use of such a small space.
Evil Henchman is offline
Old 10-02-2016, 08:34 AM
mborland's Avatar
I see this a lot, and I have to wonder. With the equipment in a closed rack like that, behind a door, isn't heat an issue? I have an Onkyo that was open to the back, but closed on the front, top and sides, and the amount of heat it was pumping scared the bejeesus out of me. I eventually took off the glass doors in front. And the Onkyo has lost the ability to process codecs. As long as I feed it LPCM, it's okay, anything else I get sub thumps and tweeter twitters (my phrase).
mborland is offline
Old 10-02-2016, 09:38 AM
snowkarver's Avatar
Liked: 47
Active management is pretty critical in a confined space. In Hobbit 1, my rack was open at the front and back, with a single passive vent on top, and would get unacceptably hot - to the point where my PlayStation 3 would go into thermal shutdown during heavy gaming.
The rack in this theater is much more actively vented. I put a large passive intake vent underneath towards the front, and a 6" low velocity, high flow exhaust fan high in the rear door. Each shelf has air gaps at the front and rear edges, which forces cool air from the bottom vent across each component, and out the back. The overall airflow is bottom-to-top and front-to-back which works with the radiant heat pattern of most components.
The 5V fan is connected to the accessory USB port of my Onkyo, so that whenever the system is powered, the rack is being cooled. With this system, the equipment barely even gets warm in use.
Old 10-02-2016, 12:39 PM
Quoted: 54 Post(s)
Liked: 35
This theater is very cool and has really got me thinking. I'm about to embark on building a 23 x 23 family room with a cathedral ceiling that I've considered placing a pull down screen and projector in. However, as it will not be a dedicated HT room, light control etc will be very difficult. But my LR, which is 23 x 12 with 8' ceiling, which is probably going to be rarely used once the new room is built, may be ideal for a theater. Hmm. Nice work. Sir.
MDJAK is offline
Old 10-03-2016, 06:58 AM
mborland's Avatar
Thanks for the info.
mborland is offline
Old Today, 02:36 PM
Liked: 1
I love this. Nice & small....
sub_ohm is online now
Home Theater Of The Month
