What Is Your Main Speaker Configuration? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What Is Your Main Speaker Configuration?
Soundbar 4 0.26%
Soundbar w/subwoofer 20 1.32%
2.0 31 2.05%
2.1 36 2.38%
3.1 47 3.10%
4.1 20 1.32%
5.1 637 42.05%
6.1 31 2.05%
7.1 540 35.64%
9.1 78 5.15%
11.1 29 1.91%
More than 11.1 42 2.77%
Voters: 1515. You may not vote on this poll
 3Likes
Old 05-06-2014, 01:02 PM
retro124's Avatar
Quoted: 1078 Post(s)
Liked: 782
Originally Posted by bass excavator View Post
I have 7.1 with an AVR as a pre pro running the surround backs and a 5 channel Outlaw 7500 running the main 5. Also an SVS PB13 Ultra. More than enough in a 1700 sq ft room.
Retro, I am using Klipsch Reference and in my room I use RS 42s and they work fantastic. On the surrounds, depending on your room the RS-52s will be fine. The RS-62s would be needed if your room is extra big. I don't really feel height speakers are necessary with a proper set up but if you have RF 82s as mains then I would go for the RB61s as height speakers otherwise your big towers may be drowning them out. Your RC-62 is a great compliment for the center. Only if you are sitting far back would you need the 64.
Thanks for post, so what kind of Reference speakers arou you using? Wow for 1700 sq ft room is pretty big so I will be fine with RS-52II for sure then. I'm running now Pc12-Plus but I have for add test at home now secound Plus and also single Ultra so I need to figure out what to keep and do some measuring REW and Umik-1. I got it yesterday so it will be little chalenge for me biggrin.gif.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is offline
Old 05-06-2014, 01:05 PM
retro124's Avatar
Liked: 782
Originally Posted by CaptinCrunch View Post
Hello,
The RS 52II's come with the RF 82II speaker package, so they are by default the surrounds to have. As for the Front Heights I wanted the equal to RS 52II"s and the RB 51's were that. The benefits are a more 3D effect to the front sound stage and adds to the over all ambiance around the screen.
The RS 62II's match better with the R7's with a RC 64II. The RB 81"s would work as surrounds, but I like the bi-directional of the RS over the RB's.
Thanks for your post. Yes I like RS also more over RB so I will get pair RS-52II's
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
retro124 is offline
Old 05-06-2014, 02:12 PM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
Originally Posted by BNestico View Post
What's up with all the "phantom" centers? To me that is possibly the single most important speaker in the entire system. Without the center it's just glorified stereo.
I would say the center is the most important channel in the system, but there's more that one valid way to reproduce it.
Two truly great speakers, with sufficient power, with a single listener in the sweet spot, have the potential to generate perfect reproduction of the center channel -- whereas a separate speaker may not, unless all three front speakers are identical and identically installed.
If you can rig a way to feed a mono source to your L+R speakers, and then switch instantaneously to your center speaker (after level-matching), it can be instructive. Listening to the signal via the mains, you're hearing the timbre of the sound as your mains reproduce it. Does switching to the center speaker sound exactly the same? If not, then you've demonstrated that the phantom center actually offers a better timbre-match than the center speaker does.
Phantom center is not a universal solution of course. It can work well for single viewers in small rooms, though.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 05-06-2014, 03:52 PM
The Mice's Avatar
Quoted: 95 Post(s)
Liked: 193
Whilst I am still in my condo, I will remain with my 2.0 bookshelf stereo setup, or sometimes I just use the speakers built into the TV. At some point this year or maybe next year, I plan to buy a detached dwelling at which point I will upgrade to 5.1 surround sound. Can't wait to be honest.
The Mice is offline
Old 05-06-2014, 05:17 PM
BNestico's Avatar
Quoted: 152 Post(s)
Liked: 221
I agree that two stereo speakers can sound like there is sound coming from between them. I'll admit that I've actually had to stand up and put my ear near the center to make sure there was nothing coming out of it. I find the center to be most noticeable during certain panning sequences, for instance when a character walks across the screen and the sound follows.
Panasonic P60U54
Marantz SR-7009
Polk Audio RTi8's, CSi5, RTi6's, OWM3's
SVSound PC12 Plus, PC Ultra (12")
Sony BDP-S7200
BNestico is offline
Old 05-06-2014, 05:39 PM
Benjitb's Avatar
Looks like I am the odd one out here.
I don't use a subwoofer, so none of the options apply in the strictest sense (AVR sets fronts to big). I always have the fronts on (LCR) and in a day or two the surrounds will be back up and running after waiting for new cable.
So a 5.0 for me. But voted 5.1.
Yamaha RX V-475 - Monitor Audio Bronze BX2 L/C/R - BRFX Rears
FAT PS3
Benjitb is offline
Old 05-06-2014, 06:11 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Unless you have a fairly linear frequency response down to 20hz at your listening volume, you are missing out... Even for stereo music. It's worth the effort/cost. Even my B&W 802D cant come close to pressurizing my 5000cuft room with linear in-room bass response...
Blazar!
blazar is offline
Old 05-06-2014, 06:24 PM
dnoonie's Avatar
Quoted: 267 Post(s)
Liked: 216
I lived without for quit awhile,l I got a sub last year.  It worked fine without but on many LFEs I had to turn things down.  I've lived with and without a sub for many years.  A sub is fun I've built a number myself but got one already built this time.
My mains go down to 38Hz -3db with good extension below that.  The benefit I found with a sub is for LFEs on movies and a vary few music tracks I have that have similar FX, I went with a sub that is flat to 20Hz since my mains went pretty low already, couldn't see getting a sub that only went to 28Hz, it didn't seem very sub-(terranean, audible, FX like).
dnoonie is online now
Old 05-06-2014, 06:40 PM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1320
7.1
  • Definitive Technology Pro Monitor 1000 fronts
  • Definitive Technology Pro Monitor 800 rears
  • Hsu VTF 15" sub
  • Denon X3000 receiver
- System calibrated by Chad B.
DavidHir is offline
Old 05-06-2014, 06:58 PM
Benjitb's Avatar
Hi blazar and dnoonie, thanks for your comments. I initially researched stereo speakers with a view to upgrade to a full 5 speaker surround at a later date. I bought the MA BX2's and AVR and then found a very cheap centre to match in great condition. The same can be said of the rears, although they are from the previous MA Bronze line to my fronts. I did not plan on getting a sub as i thought the noise would be too much for the house size/ not worth the cost, plus those things  can be pretty big.
Can't say i fully understand your comments but the bass on my fronts is very good and for the moment i can't justify getting a decent sub, but by all means change my mind!
FAT PS3
Benjitb is offline
Old 05-06-2014, 08:41 PM
wse
wse's Avatar
Quoted: 1977 Post(s)
Liked: 740
Originally Posted by Scott Simonian View Post"What are the best 11.2 receivers with HDMI 2.0 that don't totally break the bank?" Nothing.
Not yet but I suspect we will see them at CEDIA in September
wse is offline
Old 05-06-2014, 09:49 PM
Dave Moritz's Avatar
Quoted: 77 Post(s)
Liked: 59
I used to have a 5.1 system but have since upgraded to a 7.1 system. Hopefully when money situation gets better I can start thinking about a new receiver with hdmi 2.0 and 4k pass through. But for now am totally enjoying what I have!
Supporter of 1080p & 4K/UHD video (173 480p DVD Titles, 280 1080p Blu-ray Titles - 16 UHD 4K Blu-ray Titles - 75 HD-DVD's & 173 DVD's)/ Supporter of Lossless PCM, Dolby True HD and DTS HD Master Audio. Samsung UHD 4K Blu-ray Player UBD-K8500 / Coming in Mid 2018 to early 2019 Dolby Atmos & DTS-X / Thorens Turntable Coming Early 2017
Dave Moritz is offline
Old 05-07-2014, 01:22 PM
cgaffman's Avatar
Liked: 29
7.1 with dual subs. Martin Logan Sequell 2's (mains), Martin Logan Scripts (back and side surrounds), Martin Logan Logos (Center), Velodyne 12" and 15" (Subs).
cgaffman is offline
Old 05-07-2014, 05:33 PM
wse
wse's Avatar
Liked: 740
wse is offline
Old 05-07-2014, 05:48 PM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
Install a shelf on the wall; place the speaker on the shelf. The speaker weighs 68 pounds; make it a really strong shelf.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 05-07-2014, 05:57 PM
wse
wse's Avatar
Liked: 740
Originally Posted by rdclark View PostInstall a shelf on the wall; place the speaker on the shelf. The speaker weighs 68 pounds; make it a really strong shelf.
That won't work as the tweeter needs to be inverted.
HTM2 Diamond at Abbey Road Studios?
wse is offline
Old 05-07-2014, 06:34 PM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
Klipsch rf82ii towers, rc64ii center, rb61ii x 4 rears, svs pb1000 x 2 subs.
pcweber111 is offline
Old 05-07-2014, 08:23 PM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1331 Post(s)
Liked: 3875
Originally Posted by sdurani View Post
Wish the poll hadn't put ".1" in the choices, since it seems to have been taken literally by a couple of people, and simply listed speaker counts (2, 5, 7, etc).
Perhaps I shouldn't have included the ".1" in these options and just stuck with main channels. But as I said in the OP, "Many sophisticated systems include more than one subwoofer (the ".1" in all these designations), but there is little content with more than one subwoofer channel...Some systems include more than one subwoofer, in which case, select the option that reflects the number of main speakers in your system."
From the comments here, it's clear that many people have more than one sub, but for the most part, all subs in a given system reproduce the same sound, so in terms of audio channels, they are still ".1" systems. If I'm not mistaken, there are a few sophisticated pre/pros that can bass-manage the front left and right independently, in which case there are two distinct sub channels. I don't know of any pre/pros that can bass-manage more than the front left and right channels. In any case, I think such products are rare, so I deemed it unnecessary to include these configurations in what was already a long list of choices.
Scott Wilkinson
Editor, AVS Forum
Scott Wilkinson is offline
Old 05-07-2014, 10:37 PM
mgavsf's Avatar
Quoted: 30 Post(s)
Liked: 33
B&W Nautilus speakers, HTM1, 803s, 805s
mgavsf is offline
Old 05-08-2014, 08:50 AM
GLBright's Avatar
Quoted: 64 Post(s)
Liked: 84
Infinity Interlude IL60s/IL36c mains and center
Cambridge Soundworks "The Surround 5.1" bi/dipolar surrounds
RCA dumpster bookshelf rears
DefTech PF1500 sub
Onkyo TX-SR702 receiver
Certainly not the latest and greatest, but it still impresses me every day.
HT: Onkyo TX-SR702,Infinity IL60s/IL36c,LG PF1500,Draper92"screen,SonyBDP-S570,Dish622
Stereo1 Denon PMA-630 amp,TechnicsSL-1300TT,ToshibaSD-4960 uni-player,Infinity Overture 3s
Stereo 2 OnkyoTX-8222,HitachiHT-61S TT,YamahaDV-S586 uni-player,Large Advents (1972)
GLBright is offline
Old 05-08-2014, 09:02 AM
BrolicBeast's Avatar
Quoted: 1088 Post(s)
Liked: 1131
Triad CinemaPlus Platinum (LCR channels)
Triad Gold LCR (Surround side and back channels)
Emotiva XPR-1 Monoblocks (Amplification)
Seaton Submersives (Subwoofers)
Pre/Pro (TBD)
Auro 3D channels (TBD)
The system has recently entered a state of flux with the Pre/pro.
BrolicBeast is online now
Old 05-08-2014, 09:04 AM
Liked: 1131
Scott, I think you were absolutely right to put ".1" in the options instead of relegating the poll to speaker-counts only.  Whether a person has one subwoofer, or four, they are still being fed by a single encoded LFE channel (the .1).
Old 05-08-2014, 10:34 AM
bljdb's Avatar
Voted 7.1 but setup is actually 7.2 although the two subs aren't really getting anything different to each channel.  All Ariel Accoustics except rear which are Linn and Velodyne sub.  It can really shake the house!  Everything is bi-wired except subs.
bljdb is offline
Old 05-08-2014, 11:11 AM
AuroraGT's Avatar
Liked: 49
7.1 with 4 Subs.
AuroraGT is offline
Old 05-08-2014, 11:39 AM
Previous Member's Avatar
7.1 here with VMPS large woofer; Paradigm Studio 1 mains; Mission center; 3D Acoustic Sides and rear sub; Polk Audio rear speakers. Driven by a 1999 vintage Denon 7 X100 Watt receiver and an added 100 watt Haffler subwoofer amp and a 100 Watt Classe main amp with an Audio Control Richter Scale 3 subwoofer crossover/equalizer. Drivers include a Marantz Blue Ray player; Denon turntable with Grado cartridge; Mitsbishi VCR recorder, Scott dual audio cassette player. Toshiba CD and DVD player and Zenith Lazer Disc player. The wiring is a maze and when I moved a dozen years ago, all the wiring labels fell off and nobody can figure out how I had put it together (including my son who is an electronics technician and my son-in-law who is an electronic engineer.) I have to go into a manic state to psych myself up to figuring out for myself someday.
Previous Member is offline
Old 05-08-2014, 01:08 PM
ButchP's Avatar
Paradigm Reference Studio 100 L/R v2 main L/R
Reference Studio Surrounds and Center in a typical 5.1 setup
Paradigm Servo 15 Sub
ButchP is offline
Old 05-08-2014, 01:29 PM
GregLee's Avatar
Quoted: 804 Post(s)
Liked: 259
11.1 with 3 subs, but sort of 9.1, since all 11 can't be driven at once.
7.1 with 2 subs in another room.
Mostly Axiom speakers.
Greg Lee
GregLee is online now
Old 05-08-2014, 01:34 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Why are people posting lists of gear they have. The question sin't what specific stuff you use, but it's configuration.
A9X-308 is offline
Old 05-08-2014, 02:06 PM
ButchP's Avatar
Read the last paragraph "I hope you'll leave a comment describing your speaker system, including brand, models, and placement."
ButchP is offline
Old 05-08-2014, 02:34 PM - Thread Starter
Liked: 3875
Yep; I find this info very interesting!
Scott Wilkinson
Editor, AVS Forum
Polls
