HT of the Month: Yellow Dog Cinema - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #1 of 59 Old 06-09-2015, 12:36 AM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1620 Post(s)
Liked: 4372
It took Tom Logan 10 long years to complete his home theater, building almost all of it with his own two hands. Then, it was party time!
AVS Forum serves as the inspiration for many home-theater dreams, and it provides an invaluable resource of information about how to turn those dreams into reality. So it was for Tom Logan (tlogan6797) over 10 years ago. "My initial goal was to create a second room to comfortably watch movies and TV. The plan was to finish the entire basement to include the TV, a bar, and a poker table. At that time, the 'big-screen' movement was really going mainstream, so I included the idea of adding a big-screen TV. Then, I came across AVS Forum, and next thing I knew, it was a projector and screen. It became not just a room, but a Theater with a capital 'T.' Like so many builds on AVS, I got my initial ideas from Jeff Parkinson [BIGmouthinDC]."
Tom's basement would not be typical of dedicated home theaters—it's an open layout, not a closed room. "After extensive reading in the AVS Soundproofing master thread and posting some questions, it became clear that an open-concept room would always involve tradeoffs in soundproofing. Fortunately, my wife, my adult son, and I are the only ones living in the house, so waking the baby was not a concern."
After three or four months of reading AVS, construction began. "I used Dricore as a subfloor, then regular wood studs and two layers of 5/8" drywall with a layer of Green Glue throughout the entire basement, not just the theater area. The studs are a standard 16" apart and decoupled using channels and RSIC-DC04 clips. All walls and ceiling are insulated, all electric boxes are backed with putty, and all light cans are IC-rated without backer boxes."
Here you can see the insulation Tom installed in the walls of the entire basement. Anyone who has built a home theater will certainly recognize the construction clutter.
Tom wasn't worried about extensive sound isolation, but he was greatly concerned about sound quality within the room. "My main goal was lowering the noise floor inside the room. After consulting with sound designer Bryan Pape [bpape] on AVS for advice on sound treatments, I covered the lower 42" of the side walls with 1" Linacoustic covered in GOM [Guilford of Maine] fabric; on the screen wall and the back wall, I used 2" Linacoustic covered in GOM fabric."
The bottom portion of the side walls is covered with 1" Linacoustic material.
Living in northern Virginia near Washington, DC, hurricanes are a real threat. "I had two floods in the basement after starting work on the room. The first occurred after the framing was up, but not the drywall. The remnant of a hurricane came through and the sump pump failed. Fortunately, I had added a flood rider to my homeowner's insurance, so they paid to replace the Dricore. However, because I built the stud walls on top of the Dricore, I had to cut around the perimeter of the room to remove it. With help from Jeff Parkinson and Mark Wright [BritInVA], we managed to remove the Dricore and get it to the dump on what turned out to be the hottest, most humid day of the year. I replaced the sump pump and added a battery backup.
"Then, three years later—almost to the day—a second flood hit from the remnants of another hurricane. This time, I was home and got the water out quickly. I believe the problem was that the float-type switch on the main pump got hung up in all the wiring in the pit and not only failed to fire the main pump, but also prevented the backup from firing. So, I pulled everything out, replaced the float with the vertical drop-type float and cleaned up everything inside the pit.
"I seriously considered giving up. The drywall was up, and I could imagine the problem if the finished floor and carpet were down. It was probably another year before I really got moving again. I wanted to make sure I had no mold issues, that everything was dry, and that the sump pumps were going to work. As the Dricore dried out, the edges swelled and created little raised edges between every section. Once I was sure it was dry, rather than remove it, I used my electric planer and shaved down the edges. Hard as it was on my back, it was a lot easier than picking it all up and putting it back down. It has been dry ever since, even through Hurricane Sandy."
Tom bought some SMX woven screen material to replace the material in a cheap retractable mechanism. Talk about DIY!
Once the basic room was done and protected from more flooding, it was time to install the AV equipment. "Initially, I was planning a 16:9 screen to accommodate TV, but like just about everything else along the way, that evolved; it became a 2.35:1 acoustically transparent screen. I bought a cheap electric-retractable screen and replaced the material with some SMX acoustically transparent woven material I bought from an AVS member. For the surround system, 5.1 was the norm at the time, but given the odd-shaped back of the room, and on advice of Axiom, the maker of my speakers, I added a third surround speaker in the middle of the back wall." He also installed ButtKicker transducers in the four main theater seats.
With the screen retracted, you can see the center speaker and SVS subwoofer behind it. The front LR speakers are placed outside the screen boundaries, hidden behind frames covered in black GOM fabric.
The screen is 16:9 natively, but Tom installed a black mask at the bottom so that the active image area is 2.35:1. He uses the Panasonic PT-AE4000 projector's lens memories to achieve a constant image height with content of different aspect ratios.
All in all, it took 10 years to complete Tom's theater. Why so long? For one thing, he did almost all the work himself. "Only the drywall was contracted out. Everything else was DIY, including the HVAC, plumbing, electrical, low-voltage, framing, cabinets for the bar, candy counter, and ticket booth. A buddy did the carpet install, but I helped out there too. And I should mention that Jeff Parkinson made several in-person 'consults' as we called them."
Tom and a buddy installed the carpet—with some encouragement from Tom's dog Max.
"The one thing I truly underestimated was the amount of time I had to work on this project. Each day, I left by 7:00 AM to go to work, and I didn't get home until after 6:00 PM, and I was often not in the mood to start working on it that late in the evening. Also, many weekends were spoken for between family, the band I was playing in, and golf. I also found that as time wore on, I could only work about six hours on a good day before my back started acting up."
Behind the theater area is a fully stocked bar.
Because of all the DIY work, the cost to build Tom's theater was surprisingly low. "All in, it was about $29,000." That includes the drywall contractor's labor, all construction materials, seating, and AV equipment. It's a lot less than many such rooms, even those the owners built entirely by themselves.
Four Berkline 2010 recliners put viewers' eyes 12 feet from the screen.
Once the theater—dubbed the Yellow Dog Cinema after Tom's beloved yellow Labrador Max—was finally finished, he decided to host a grand opening, complete with a red carpet and celebrity impersonators. "After 10 years of hard work, I wanted to throw a party to celebrate. As I talked with my wife Melinda—known to AVSers as Loganess—I said it would be really neat to have a red carpet for the guests to enter the house."
Tom rolled out the red carpet—and a covered walkway because of rain—for his guests at the grand-opening gala.
"Then we thought, wouldn't it be cool to have a Joan Rivers impersonator out there doing interviews? And if we're doing that, maybe we should have some other celebrity impersonators at the party, and Loganess and I would be the last 'celebrities' to arrive. And if we're doing that, we should arrive by limo!"
Tom and his wife Melinda (aka Loganess) arrived in style, protected from the rain by a "security guard"—actually, their son Bryan—with a huge umbrella.
"We have a bit of a reputation for throwing fun parties, and I am well aware of how much work it takes. I wanted Loganess to enjoy this party, so I thought we should have catered food, passed hors d'oeuvres and champagne, and a bartender. One thing led to another and it turned into a Gala Grand Opening."
Among the party guests were (L-R) Daniel Craig, Marilyn Monroe, and Jim Carrey—or at least close facsimiles thereof.
The party was a huge success, and now that it's over, Tom and his family and friends get to enjoy the fruits of his considerable labor at their leisure. And what sweet fruit it is!
For much more detail about how Tom Logan's home theater came together, check out the build thread here.
If you'd like your home theater considered for HT of the Month, PM me with the details and a link to your build thread if available.
EQUIPMENT LIST
Sources
Panasonic DMP-BDT330 Blu-ray player
Comcast cable box
Roku 3 streaming box
AV Electronics
Denon AVR-3806 AV receiver
ButtKicker BKA300-4 amp for ButtKicker transducers
Processor
VIP 3D Theatre video processor
Projector
Panasonic PT-AE4000
Screen
SMX (102" diagonal, 2.35:1, acoustically transparent woven, 1.1 gain, retractable)
Speakers
Axiom M60 v2 (front LR)
Axiom VP160 v2 (center)
Axiom QS8 (3, LR side surround, rear surround)
SVS Cylinder 39-20 PCi Plus subwoofer
Cables
Monoprice HDMI
Monoprice in-wall speaker wire
RG6 Quad Shield coax (component video, composite video, analog audio)
Control
URC 980 RF remote
Monoprice 4x4 HDMI matrix switcher
Insteon lighting control
Power Conditioning
None
Seating
Berkline 2010 (4; black leather/vinyl recliners)
Pastel Furniture Glenwood swivel barstools (6)
Room Dimensions
Main theater area: 12' 1" (W) x 17' (L) x 7' 3" (H)
Distance from screen to main seats: 12'
Bar area: 12' 1" (W) x 15' (L) x 7' 6" (H)
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
KBMAN, thehun, Aetherhole and 11 others like this.
Scott Wilkinson
Editor, AVS Forum
Scott Wilkinson is offline
post #2 of 59 Old 06-09-2015, 03:13 AM
MaxTemp's Avatar
Quoted: 37 Post(s)
You know you've made it when you have guests like Daniel Craig, Marilyn Monroe, and Jim Carrey attending your party
johnnygrandis likes this.
MaxTemp is offline
post #3 of 59 Old 06-09-2015, 04:18 AM
Otium's Avatar
Fantastic effort, Tom. Congratulations!!
Your HT looks great.
Hope you enjoy your movies for many years to come.
I have built my HT just by myself, and 15 years later on (with two upgrades) I am still loving it.
When I'm in my HT, I'm not even in my home.
Otium is offline
post #4 of 59 Old 06-09-2015, 04:52 AM
rms8's Avatar
Quoted: 499 Post(s)
Liked: 326
rms8 is offline
post #5 of 59 Old 06-09-2015, 05:38 AM
gamest's Avatar
Quoted: 126 Post(s)
Liked: 93
Congratulation man! Very stylish build. If anyone deserved home theater of the month, it was you. It might not have taken you ten years if it was not for all the time you were distracted LOGANATING people But I am sure they all appreciated the motivation.
gamest is offline
post #6 of 59 Old 06-09-2015, 06:09 AM
Pitbull0669's Avatar
Quoted: 75 Post(s)
Liked: 43
good job my man
Pitbull0669 is offline
post #7 of 59 Old 06-09-2015, 06:12 AM
J.Mike Ferrara's Avatar
Quoted: 153 Post(s)
Liked: 179
Well deserved praise for a job well done.
The opening party looks awesome!
Enjoy.
J.Mike
Those who die with the most toys ... are still dead!
J.Mike Ferrara is offline
post #8 of 59 Old 06-09-2015, 06:27 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
Thanks for the kind words! It was a LONG haul, but I am extremely happy with the way it turned out.
I could not have done it without the help and support I received, both online and in person, from all the great and dedicated members of AVS. For that, I am truly greatful.
Here's a link to my Photobucket Library if you're interested to see more pictures of the completed room, various stages of the build and the Gala Grand Opening.
Yellow Dog Cinema Photobucket Story
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #9 of 59 Old 06-09-2015, 06:34 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I guess the term getting LOGANED has just been broken
Awesome tom. Since mostly finishing my project I don't cruz the construction threads as much anymore so this news was a bright spot in my day
tlogan6797 likes this.
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #10 of 59 Old 06-09-2015, 06:36 AM
willmo's Avatar
Quoted: 12 Post(s)
Nice and a testament to perseverance.
willmo is offline
post #11 of 59 Old 06-09-2015, 06:45 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
No, it just means now I REALLY get to sit back and kick your poor, pathetic butts into gear.
I'm just sayin'.
Nick in Manitou likes this.
Tom Logan
post #12 of 59 Old 06-09-2015, 06:52 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Fast build!
doublewing11 and Rengozu like this.
Mfusick is offline
post #13 of 59 Old 06-09-2015, 07:00 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
^^^^ EVERYBODY is a comedian.
Mfusick likes this.
Tom Logan
post #14 of 59 Old 06-09-2015, 08:53 AM
Exist_To_Resist's Avatar
Quoted: 333 Post(s)
Liked: 176
That home theater looks amazing, the fully stocked bar really adds a nice touch too.
tlogan6797 and yukinok25 like this.
OLED is a game changer.
Exist_To_Resist is online now
post #15 of 59 Old 06-09-2015, 08:59 AM
AXLCMT's Avatar
Quoted: 182 Post(s)
Liked: 69
OMG!
You've thought you've seen it all, then you see a Opening Night with red carpet and celebrity impersonators.
This thread has inspired me to go back to 1" Linacoustic up to 42" on the side walls, instead of my proclaimed plans of 1" OC703 with
air gap.
Awesom with the red carpet opening night party! Wow!!!
Everytime I check into this forum, I see you guys taking it to a whole new level!!!!!!!!
tlogan6797 and LDizzle like this.
AXLCMT is online now
post #16 of 59 Old 06-09-2015, 09:04 AM
Djoel's Avatar
Quoted: 548 Post(s)
Liked: 422
Nicely done, it those matter how it took to build, as you know Rome was build in a day. Enjoy the fruits of you hard labor!
Djoel
Mfusick and tlogan6797 like this.
Djoel is offline
post #17 of 59 Old 06-09-2015, 09:07 AM
WebEffect's Avatar
Quoted: 98 Post(s)
Liked: 44
Great job on making an amazing theater by using only what you need without falling prey to propaganda about power conditioning, double subwoofers, Oppo bluray players and other such nonsense.
WebEffect is offline
post #18 of 59 Old 06-09-2015, 09:20 AM
GreySkies's Avatar
Quoted: 620 Post(s)
Liked: 436
GreySkies is offline
post #19 of 59 Old 06-09-2015, 09:35 AM
HTmarket's Avatar
Quoted: 241 Post(s)
Liked: 59
I love the opening party with red carpet. It looked like a fun night. Great job sticking with it.
Regards
Alan Hutchinson
HTmarket is online now
post #20 of 59 Old 06-09-2015, 09:38 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
Looks great.
KidHorn is offline
post #21 of 59 Old 06-09-2015, 10:39 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
Like
Actually (in real-life reality, as opposed to Dimension X reality), an Oppo just might be my first upgrade, you know, when I get around to it.
Tom Logan
post #22 of 59 Old 06-09-2015, 10:45 AM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
Love it! And what a cute dog
Yippee-ki-yay...
cesar123 is offline
post #23 of 59 Old 06-09-2015, 11:02 AM
mo949's Avatar
Liked: 1184
Your perseverance and patience is admirable and the true gem in this story to me. Felt like I was reading about a sea captain battling the storm to achieve his aims without succumbing and turning around. Congratulations!
mo949 is offline
post #24 of 59 Old 06-09-2015, 11:14 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
^^^^ Funny, for a while there I FELT like a sea captain battling the flood waters.
Tom Logan
post #25 of 59 Old 06-09-2015, 11:20 AM
stef2's Avatar
Quoted: 422 Post(s)
Liked: 257
Post
Congratulations! I can't help but notice many similarities between your HT and mine. Dimensions, riser, black leather seats, insteon lighting. Even building time (it took me 10 years too...).
Enjoy!
stef2 is offline
post #26 of 59 Old 06-09-2015, 11:24 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
So where are YOUR Grand Opening pictures?
Tom Logan
post #27 of 59 Old 06-09-2015, 12:04 PM
DavidK442's Avatar
Quoted: 618 Post(s)
Liked: 456
Congratulation on completion.
Fitting that you played the role of a celebrity for your grand opening, being an AVS celebrity in real life and all.
Looks like your family and friends are really going to enjoy (or maybe continue enjoying) the completed rec room.
DavidK442 is offline
post #28 of 59 Old 06-09-2015, 12:13 PM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
awwww...you make me blush.
I know I enjoy it! Last Sunday, some of LOGANESS' family came in from California, and as nice of a day as it was (after 4 days of near constant rain), we spent the entire afternoon at the bar. So I guess THEY enjoyed it , too.
Tom Logan
post #29 of 59 Old 06-09-2015, 02:52 PM
Liked: 2
wow i am super jealous of this beautiful theater. It puts mine to shame.
Darrel Chavez is offline
post #30 of 59 Old 06-09-2015, 03:37 PM
Barry C's Avatar
Quoted: 290 Post(s)
Liked: 173
Absolutely beautiful
Barry C is offline
Reply Community News & Polls
frontpage , Home Theater Of The Month
