HT of the Month: The Envelope - AVS Forum | Home Theater Discussions And Reviews
 76Likes
post #1 of 66 Old 07-09-2015, 08:51 PM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1621 Post(s)
Liked: 4375
Like most DIY home theaters, this was a labor of love for its owner, who built almost everything himself, including the subs and screen.
Mike Rosinski (mtbdudex) is a prolific AVS Forum member with over 5200 posts to his name since he joined in 2007. I wonder how he could possibly have time for so much posting when he's Manager of Engineering at the Nissan Tech Center near Detroit, MI, and he has a family with his wife and three kids, ages 9, 11, and 13.
Mike Rosinki's family—and basement home theater—live in this beautiful log home.
Even more remarkable is his home theater, which he built entirely with his own hands except for the drywall and carpet installation. Mike's primary goal was to balance the acoustics for all seats; as he puts it, "Every seat a good seat, but no single great seat." His secondary goal was visual immersion, which he achieved by building his own ginormous curved screen that we'll take a closer look at shortly.
Given his busy life, it's no surprise that Mike's theater was a long-term project. After two years of research, construction began in late 2004 and occupied his weekends for the next three years. "I had to pay as I went," he says, "then it got more serious in late 2007 and 2008, when most of the build was completed." Mike is quick to point out that he was finishing the entire basement at the same time, with a fourth bedroom, full bath, craft room, and rec room in addition to the theater.
This floor plan shows where every element of the theater is located.
In the theater, Mike used 2x6 wood sill plates and 2x4 staggered studs with insulation between them to form the walls. The back wall adjoins the hallway to the upstairs, so he had double layers of drywall installed on both sides of that wall for extra mass.
Mike is seen here hammering a stud into place with the help of his father.
Speaker and high-current wires run through the walls; Mike kept them at least two feet from each other for the most part, crossing at 90 degrees when necessary.
When he started this journey, Mike understood the importance of acoustics in a home theater, but not the specifics. "I knew in 2008 there was much I needed to learn in order to do it right, so I decided not to apply a cookie-cutter approach. Instead, I started with a bare-bones home theater and then add the appropriate treatments as I learned about them. Part of that decision was to use movable/hanging treatments, not the integrated type. That way, I could add them as needed and also easily do A/B comparisons." For more on that, see this thread.
"My first acoustic treatment was making my second-row riser a broadband bass trap. The opportunity to do that arose when I discovered it wasn't deep enough, so while I was fixing that, I decided to turn the riser into a bass trap, which is documented in this thread.
"Next, I decided to apply the RFZ [reflection-free zone] concept to the front soundstage for both rows of seats. I used ray-tracing software to determine where to apply the absorbers, and I verified the results with the mirror method and later with ETC [energy time curve]charts. I was very cautious to not over-treat the room; my goal was to apply treatments where they were specifically needed as determined by objective measurement and subjective listening." This also led to several absorptive ceiling clouds.
This front-view screen shot shows where the first reflections from the front speakers are located, which is where Mike put absorptive panels.
Here's a view of the first reflections from the side.
"Then, I added the rear-corner broadband bass traps, which I wanted to double as display shelves for the Star Wars and Star Trek stuff I've collected over the years, so they are my own design. I applied heavy craft paper to the front-facing portion, as I did not want to absorb too much sonic energy; rather, I wanted to reflect the mid-highs back into the space."
Here's a YouTube video of Mike and his corner bass traps:
In this view, you can see the right-rear corner bass traps, side and rear surround speakers, and the massive, 4-foot-wide, solid-core entrance door with seals on the sides and top and an auto-drop seal on the bottom.
"Finally, I added a floor-to-ceiling corner broadband bass trap on the left side of the front wall and another along the wall/ceiling boundary. This was also my own design. I've now got the modal issues pretty well managed. The IB sub is on the right side, so no bass trap there."
Speaking of the IB (infinite-baffle) subwoofer, it turned out to be his biggest challenge. "I wanted to do a DIY sub, and after much research, it seemed that an IB sub was truly the best for LFE and clean sound. After looking at the options, I found that I needed to cut through my engineered concrete-foundation wall. I consulted with the engineer who did my load calculations and got his approval to modify the foundation."
The plan was to install a vertical line array IB subwoofer to the right of the screen. Fortunately, the structural engineer gave thumbs up.
Mike cut a large rectangular hole in the concrete wall to accommodate a baffle plate with four 15" IB15-8 drivers from Acoustic Elegance in a vertical line array. The backwave from the drivers vents into a utility room that is closed off from the rec room with a sealed door. "I did more isolation with 1-inch styrofoam/sealant at the HVAC duct locations, but I was concerned about the bass booming in the HVAC ducts, since my geothermal system is in the utility room and it has sheet-metal HVAC supply/return main lines entering/exiting the room. If there had been a duct boom, I thought I might add some damping to that area, but it wasn't necessary." For more on Mike's IB sub, check out this thread. Later, he decided to add two more DIY subs in sealed cabinets—one with an 18" driver and the other with a 15" driver, both from Stereo Integrity—to help flatten the low-frequency response in the first row; you can read more about that here.
In addition to aural immersion, Mike wanted visual immersion as well. "Initially, I was going to use a 16:9 screen. However, I soon realized that a true home-theater experience required a 2.35:1 'scope' screen. After doing research on AVS in the CIH (constant image height) forum, I decided to build the screen myself.
"There is so much info on AVS about DIY screens, but I found nothing I liked in the way of a scope screen, so I decided to design and build my own. It was fun, especially learning about the proper curvature needed for using an anamorphic lens. The material I chose was Designer White laminate from Home Depot, mainly because I have young kids, so I wanted a robust material that still gives great viewing experience—no hot-spotting, etc.
"The frame is a composite/hybrid metal frame for the structural flat backing with pine board for the curved portion that the DW laminate is attached to. The hardest part was attaching the laminate to the wood. I made a temporary setting jig to guide the laminate onto the frame. My wife helped and we went through three dry runs before applying the contact cement." For more on Mike's screen, see his post about it here.
Here, Mike's DIY curved, 2.35:1 screen is about ready to be mounted on the wall.
Mike outfitted a Sony VPL-VW60 projector with a Panamorph UH380 anamorphic lens; he even designed and built the lens slide! For more on that, see his thread here.
In 2012, the speaker system expanded from 7.1 to 11.1 channels with front wide and height speakers, all from Paradigm. "After that upgrade, AVS member Ed Flower visited me and heard the theater. Listening to various movie clips, he was very impressed with the increased envelopment provided by the wide/height speakers, even knowing those channels were upscaled by DTS Neo:X, not true discrete channels—this was well before Dolby Atmos or Auro. Plus, my front LR speakers are just outside the screen and toed in; along with the side-wall acoustic treatments, Ed thought this produced better imaging than his speakers pointed directly forward behind his acoustically transparent screen. By the end of our visit, he had named my theater 'The Envelope,' which I really liked; it never had a name before, and that one was quite fitting."
Here you can see two of the acoustic panels, equipment rack, and right front main, wide, and height speakers. The IB sub is behind the main speaker covered with grille cloth.
What were Mike's greatest moments in the process of building his dream theater? "One of the best moments was when I hung the screen and watched in scope for first time; that was very cool! Another was when I fired up the IB sub for Kung Fu Panda and heard that great 'ska-doosh!' at the very end."
The left wall is treated with several DIY acoustic panels—and some stuffed toys on the secondary sub.
After more than 10 years and about $30,000 of directly related expenses, Mike's basement home theater is finally finished—or is it? "Every time I'm in there, I'm still giddy at the sound quality, acoustics, and overall sense of immersion. Still, I'm looking forward to late 2016 or 2017, when I'll tackle the next upgrade to 9.2.8 Dolby Atmos." Talk about pushing the envelope!
A brightly colored rec room leads to the theater.
Four Berkline motorized recliners comprise the front row, while four Billy Bob manual recliners occupy the second row.
For much more detail about how Mike's home theater came together, check out the main build thread, which includes links to several related build threads about the sub, screen, acoustic treatments, and other aspects of his theater.
If you'd like your home theater considered for HT of the Month, PM me with the details and a link to your build thread if available.
EQUIPMENT LIST
Sources
Sony PlayStation 3 game console/Blu-ray player
Comcast cable box
Samsung DTB-H260F OTA tuner
Channel Master CM 3020 UHF/VHF/FM antenna
Channel Master CM 7777 Titan2 antenna amplifier
AV Electronics
Denon AVR-4520CI AV receiver
Emotiva XPA-3 power amp (powers front LCR speakers)
Behringer EP2500 power amp (for main IB subwoofer)
Behringer iNuke NU6000DSP power amp (for other two subs)
Processor
Darbee Darblet DVP-5000 video processor
Projector
Sony VPL-VW60
Panamorph UH380 anamorphic lens on DIY slide
Screen
DIY (Designer White laminate surface, 130" diagonal, 2.35:1, curved, 1.1 gain, non-acoustically transparent)
Speakers
Paradigm Monitor 9 (2, front LR)
Paradigm CC-390 (center)
Paradigm ADP-390 (4, side and rear surround)
Paradigm Mini Monitor bookshelf (4, front wide & height)
DIY IB subwoofer (4 Acoustic Elegance IB15-8 15" drivers in vertical line array)
DIY subwoofer (1 Stereo Integrity HT18 18" driver in DIY Sound Group 4-cu-ft sealed enclosure)
DIY subwoofer (1 Stereo Integrity HT15 15" driver in DIY Sound Group 3-cu-ft sealed enclosure)
Cables
Parts Express speaker cables (14ga/4 for original 7.1, 12ga/2 for wides and heights)
Parts Express HDMI cable for projector (35 feet)
Control
Logitech Harmony 890
Power Conditioning
Panamax M5300-PM power conditioner
Furman PS-Pro II power conditioner/sequencer (subwoofer amps)
Seating
Berkline 12006 powered recliners (4, first row)
Billy Bob manual recliners (4, second row)
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
Scott Wilkinson
Editor, AVS Forum
Scott Wilkinson is offline
post #2 of 66 Old 07-09-2015, 08:53 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Mike,
I have a question about this:
What program is that? Cost ?
oneeyeblind likes this.
Mfusick is offline
post #3 of 66 Old 07-09-2015, 08:57 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
BTW- Congrats Mike on HTOTM.
Well earned. You are literally one in a million. Meaning there is a million guys out there with DIY theaters that don't sound as good because they didn't put in the effort you have to learn what you are doing.
I was just mentioning this to @TMcG yesterday in an email. He agreed it was one of the best, if not the best sounding DIY theater's he's heard. I asked his opinion because I kind of could tell that with the amount of effort you've put into certain areas it probably has paid off.
Well deserved. Congrats!
BTW- Can't wait for the baffle wall upgrade soon Good isn't good enough...
mtbdudex likes this.
Mfusick is offline
post #4 of 66 Old 07-09-2015, 10:25 PM
popalock's Avatar
Quoted: 1317 Post(s)
Liked: 1814
Congrats Mike!
I've always liked your theater.
The ONLY thing that really bugs me about your set up...is that I am a sucker for symmetry.
maxsl8er and mtbdudex like this.
popalock is offline
post #5 of 66 Old 07-09-2015, 10:37 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 1005 Post(s)
Liked: 1013
Very nice, wood and cushy seating, and Paridigms. Must sound as good as it looks
"Ich spreche Klingon und du?"/ "Ich spreche auch Klingon"/ "Und sie ?"/ "Wir sprechen Klingon! "
tenthplanet is offline
post #6 of 66 Old 07-09-2015, 11:01 PM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
Congrats Mike! I enjoyed talking to you at Nick's HEMI meetup a few years ago.
After a little bit of Googling try this:
*free* software to help determine your first reflection points
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #7 of 66 Old 07-10-2015, 04:00 AM
TMcG's Avatar
Quoted: 1186 Post(s)
Liked: 1002
Congratulations, Mike! Very well-deserved recognition!!
A few months ago I had the great privilege of experiencing this theater in-person. It is a testament to Mike's DIY skills and his determination to build his own personal reference quality home theater.....AND the incredible community and available resources here on the AVS Forum for anyone else thinking of taking on such an endeavor.
I look forward to my next visit!
Mfusick and mtbdudex like this.
TMcG is offline
post #8 of 66 Old 07-10-2015, 04:26 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
You did a good job. Make sure you set aside some time to enjoy it.
KidHorn is offline
post #9 of 66 Old 07-10-2015, 04:37 AM
comike's Avatar
Quoted: 32 Post(s)
Liked: 7
Very well done. I'll bet it sounds marvelous...
Mike O
comike is offline
post #10 of 66 Old 07-10-2015, 05:10 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1134 Post(s)
Liked: 3606
Awesome Job!
Greetings,
Mike, thanks so much for sharing your terrific home theater with us. Congrats and job well done my friend.
Mfusick, mtbdudex and nwmusicman like this.
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #11 of 66 Old 07-10-2015, 05:47 AM
JKR1963's Avatar
Quoted: 260 Post(s)
Liked: 115
This proves that hard work can pay off !!! Great theater........screen looks great with the space cadets on there !!
JKR1963 is offline
post #12 of 66 Old 07-10-2015, 06:54 AM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
Free.
Check post #215 to download the file.
EDIT: Oops, almost forgot. Congrats on the HToTM! You have a beautiful home and theater.
Yippee-ki-yay...
cesar123 is offline
post #13 of 66 Old 07-10-2015, 07:41 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Guys-(and gals) don't re-quote the entire first post write up just to say congrats.
sdurani and Taxi like this.
Mfusick is offline
post #14 of 66 Old 07-10-2015, 07:50 AM
frankie2075's Avatar
Quoted: 458 Post(s)
Liked: 110
Mike,
I'm curious too?
frankie2075 is offline
post #15 of 66 Old 07-10-2015, 08:07 AM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
^^ See my post (#12).
Yippee-ki-yay...
cesar123 is offline
post #16 of 66 Old 07-10-2015, 08:36 AM
blastermaster's Avatar
Quoted: 501 Post(s)
Liked: 633
Grats on HTOTM! I really like that you put in the effort to treat your room acoustically first and foremost. Looks great and probably sounds even better.
blastermaster is offline
post #17 of 66 Old 07-10-2015, 08:49 AM
BornSlippyZ's Avatar
Quoted: 1851 Post(s)
Liked: 1566
Congrats on HTOTM!
BornSlippyZ is offline
post #18 of 66 Old 07-10-2015, 10:02 AM
Quoted: 3901 Post(s)
Liked: 3333
Mike O
Thank you for repeating the entire article in your post, I didn't have a chance to read it when Scott posted it but your response provided that opportunity.
post #19 of 66 Old 07-10-2015, 10:54 AM
stef2's Avatar
Quoted: 423 Post(s)
Liked: 258
I was just thinking the same thing...
Congratulations! You must be very happy with the results!
Those DIY home theaters mean so much more to me than those extremely expensive rooms built for customers who have money to burn but don't really care.
stef2 is offline
post #20 of 66 Old 07-10-2015, 11:08 AM
comike's Avatar
Quoted: 32 Post(s)
Liked: 7
My bad... Must have been the 'quick reply' as I wouldn't otherwise have intended to do that...
Mike O
comike is offline
post #21 of 66 Old 07-10-2015, 11:17 AM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Wooow. Absolutely amazing. I can't even imagine how this HT sounds. I'm very sure that going to local theater to watch a movie just won't do it. Only IMAX ;-).
I was thinking of going to curve screen but then decided to hold back based on some reviews where viewers didn't like curve screen. Would love to hear how your experience has been? What difference do you see going from flat to curve screen?
SherazNJ is offline
post #22 of 66 Old 07-10-2015, 11:42 AM
DavidK442's Avatar
Quoted: 619 Post(s)
Liked: 457
Great theater but best of all is when he drug much of that high end gear outside. I love this picture. Family and friends enjoying the movie experience in an amazing outdoor setting. What could be better!
KBMAN, mtbdudex and ControlZ like this.
DavidK442 is online now
post #23 of 66 Old 07-10-2015, 12:42 PM
Chris Young's Avatar
Quoted: 39 Post(s)
Liked: 34
Nice Build Mike. I've been sub'd and following you for some time with each and every thing you post about the build of this great HT. I'm glad to see you got HT of the month. Congratulations Mike.
Chris
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
My attempt living room build The Story Time Theater
14 M&K S-100B, 2 Servodrive Contrabass. 2 SVS PB12/2 Plus. 6 V.B.S.S., 2 Sunfire TrueSub's MkII Near field Fun all in one room.
Chris Young is offline
post #24 of 66 Old 07-10-2015, 12:49 PM
WebEffect's Avatar
Quoted: 98 Post(s)
Liked: 44
All that money spent on sound treatments and yet all the speakers are low-end budget ones from Paradigm's old "monitor" line? He's missing out on serious detail and dynamics if he doesn't at least go with "Reference Studio". The guy says sound is his top priority but he didn't consider his speakers? Another obsessed fanatic who goes overboard in one department and doesn't stop to think.
WebEffect is offline
post #25 of 66 Old 07-10-2015, 01:26 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 790
Reason for curved screen is I use a anamorphic lens to stretch the image (a-lens for short), which adds some distortion, the curve screen will make the image flat and true. The distortion depends on your throw ratio, some live with it via overscan into their black border if its small.
There is a basic "cool" factor having a curved screen, but it's really functional with a purpose here.
Re-purpose your equipment 501! Yea, we do that 2 weekends a year in late August/Early September.
Good old fashioned family fun.
Mike O
If you could edit your 1st post to remove the quick quote that would suffice...thx
Here's a shout out to the many-many people here on AVS who I've learned and shared lots with over the years.
Can't list all the names, so here's off the top of my head in no specific order, I'm sure some missed:
Dennis E, Glenn K, Jeff P (aka "Big"), localhost127 (sp), dragonfyr/SAC (acoustic expert), Nick G, Mike F, Mississippi Man, ErichH, granroth, arnyk, DonH50, Shawn (aka "SierraMikeBravo"), Axel, Itai ("cubesys"), Nyal M, Ethan W, J_P_A, lovinthehd, John (aka "aackthpt"), FOH, ThomasW (Mr IB sub himself!), fotto, GetGray, larrychief, TmcG, Amirm, Sanjay, Aussie Bob, Oman321, CAVX, Moggie, Bigus, tlogan, ... and many more ....
A special Thanks to Jeff P, "Big", who has helped so many-many people here over the years, I've silently taken his methods and applied them when I could.
mtbdudex is offline
post #26 of 66 Old 07-10-2015, 01:46 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 790
Yep - 2016/2017 will be my true leap into uber sound quality territory; Baffle wall, DIY Soundgroup 1099 mains up front, Volts in the ceiling, etc
Originally Posted by popalock View Post
Congrats Mike!
Agreed, if I knew in 2001 what I know now I'd have made a separate IB chamber in front of my front wall from engineered foundation and had symmetry (basement foundation), and total backwave isolation also, the only downfall of IB subs. As is, come 2016/2017 I'll balance the RH IB sub with a LH corner stack of (2) 18" SI HST subs, that will give me true symmetry up front.
Me to Tim, and we will watch a complete movie next time ...
Wow, feel the love....I'm a family man first and have to balance my want/needs with family stuff. Yes, I do stop and think, and balance everything.
Really "overboard", how? where?
You have open invitation to come over and critique.
I feel I've maxed the sound PQ from my speakers with the DIY treatments I've used. (ie, room speaker listener position interaction)
I realize at full 0db Ref volume they may have some slight distortion and truly we never listen that loud, mostly we listen at -16db or -18db, sometimes at -10db.
As stated above, come 2016/2017 I'll be upgrading my speakers to the DIY soundgroup high efficiency line-up 1099's for the front soundstage, http://www.diysoundgroup.com/home-th...sive-1099.html , volt's for ceiling http://www.diysoundgroup.com/coaxial-speaker-kits.html , and go with Fusion-8's for wides/heights/surrounds http://www.diysoundgroup.com/wavegui.../fusion-8.html
Peace.
mtbdudex is offline
post #27 of 66 Old 07-10-2015, 01:49 PM
rms8's Avatar
Quoted: 499 Post(s)
Liked: 326
Congrats mike on HToM !!
Well deserved.
Says the troll who has zero experience in audio/video.
mtbdudex and DavidK442 like this.
rms8 is offline
post #28 of 66 Old 07-10-2015, 04:45 PM
comike's Avatar
Quoted: 32 Post(s)
Liked: 7
If you could edit your 1st post to remove the quick quote that would suffice...thx .
Done... Apologies.
comike is offline
post #29 of 66 Old 07-10-2015, 06:15 PM
laeriq's Avatar
Quoted: 72 Post(s)
Liked: 91
I stole many ideas on curved screen and a-lens mount from this build and am thankful I did. Awesome stuff and congrats.
laeriq is offline
post #30 of 66 Old 07-10-2015, 07:59 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Congrats.......... accolades deserved!!!
Welcome to the HToM club!
BTW, have said this many times......love your style and home!!!
doublewing11 is offline
Reply Community News & Polls
frontpage , Home Theater Of The Month
