Can I use any IR receiver with a PS3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-15-2008, 06:54 PM - Thread Starter
chuckvb's Avatar
I'd like to use a IR reciever with my PS3 that is on a cord so I can move it to a better location. Can I use any IR receiver with my Harmony 880 and PS3?
chuckvb is offline
post #2 of 4 Old 03-15-2008, 08:03 PM
tiger_qc's Avatar
If you can wait a few weeks the IR2BT will be out and that's would be the best pick for a ps3 IR solution. IR2BT will be an IR add on that would make you able to do everything you need. It will be a separate IR-BT station and won't need any physical USB connection if you use batteries. (you can connect it too) Your PS3 won't have an IR signal. The base will get the IR and send it BT to your PS3. Should be around 50-60$ a piece.
Hope this help.
tiger_qc is offline
post #3 of 4 Old 03-16-2008, 05:47 AM
McRed's Avatar
Try the NYKO dongle instead.
McRed is offline
post #4 of 4 Old 03-16-2008, 06:18 AM
SaltiDawg's Avatar
Or this: http://www.schmartz.com/main.sc
Or This: http://www.buy.com/prod/intec-ps3-bl...204954437.html
SaltiDawg is offline
Reply Remote Control Area
