Will KDS Remote Control PS3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-17-2008, 06:38 PM - Thread Starter
xd40owner's Avatar
I have a Sony TV (KDS 60A3000), and I'm wondering if anyone knows if there is a code that will allow me to use the TV remote (universal/stock) to control the Blu Ray part of my PS3, or would I be forced to buy a "Learning Remote"?
Thanks in advance.
xd40owner is offline
post #2 of 2 Old 04-18-2008, 04:25 PM
kefer's Avatar
If you want to control the PS3, then you need a bluetooth remote. Most universla remotes do not have bluetooth (actually, none that I am aware of).
There are several solutions, the cheapest being the Nyko Blu-Wave remote, which is an infrared remote with a USB adapter for the PS3. As long as your universal remote has code for the PS2, it will work fine. I bought the Nyko, plugged in the adapter, threw out the remote that came with it, and programmed my Harmony One to send the PS2 commands. Works great, althought it won't control the power on/off, but everything else works.
kefer is offline
Reply Remote Control Area
